custom OBD1/MUT scanner/boost controller - Page 16 - 3000GT/Stealth International Message Center
Old 12-15-2012, 09:13 PM   #151 (permalink)
BlackStealth's Avatar
Drives: 93 RT/TT
BlackStealth Level 1BlackStealth Level 1
Feedback Score: 235 reviews
Default Re: custom OBD1/MUT scanner/boost controller
Firmware 3.01 is now made available. I made an emphasis on datalogging, such that you can pick whatever you like to datalog and it won't slow down. It will maintain high speed. I also took advantage of some parallel processing such that when Boost, WBO2, Oil Pressure or EGT sensor is being measured it does not halt the microprocessor, so the microprocessor can keep on working. Chrome 2.0 mod is supported for 98/99 flashECU users. This means the special 2-Byte Airflow and 2-Byte Load are supported. The Load vs Dutycycle will automatically switch to 2-Byte load when Chrome ECU is selected in the setup config.
BlackStealth is offline   Reply With Quote
Old 12-23-2012, 11:50 AM   #152 (permalink)
Drives: 1994 3000gt vr4
mschwantz is an unknown quantity at this point
Feedback Score: 5 reviews
does anybody have the info on the installation and setting it up from the website saved, I didn't save it and now the site does not work
mschwantz is offline   Reply With Quote
Old 12-23-2012, 12:02 PM   #153 (permalink)
Drives: 93 RT/TT
Here's a duplicate website I made in the meantime.
http://www.lcdbc.xp3.biz
Old 01-14-2013, 12:13 PM   #154 (permalink)
Drives: 93 RT/TT
Firmware 3.03 is available. http://www.lcdbc.xp3.biz
For 96-97 ECU users (OBD2): Screen changes are now nice and quick, and much improved datalogging speeds for you too.
For MUT connection users: Modified connection routine (attempts 3 and 4 now use different method of connecting).
For users with enhanced OBD2/MUT cables: If disconnected from ECU, the reconnection routine will now take advantage of the new enhanced OBD2/MUT cables by simulating a physical cable removal and reinsertion.
Old 02-03-2013, 12:16 PM   #155 (permalink)
luvness018's Avatar
Drives: 93 3000GT VR4
luvness018 is an unknown quantity at this point
Feedback Score: 1 reviews
So when hooking up a wideband, do you need the sensor and controller or just the sensor wired into the box?
luvness018 is online now   Reply With Quote
Old 02-03-2013, 12:23 PM   #156 (permalink)
AF Medic
NickS VR4's Avatar
Drives: 01 Eclipse GT,94 VR4
NickS VR4 is an unknown quantity at this point
You need a controller to convert the signal, like my AEM UEGO Wideband (has controller inline). In the for sale thread ;-). Brand new.
Mitsubishi ASA Price List
1994 VR4 3000GT #2 - Under Restoration
2001 Eclipse GT
2005 Civic EX SE - Totalled
1994 VR4 3000GT - Sold
NickS VR4 is offline   Reply With Quote
Old 02-03-2013, 12:24 PM   #157 (permalink)
RealMcCoy's Avatar
Drives: 92 RT/TT, 96 Cobra
RealMcCoy Level 2RealMcCoy Level 2RealMcCoy Level 2RealMcCoy Level 2RealMcCoy Level 2
Feedback Score: 35 reviews
You need a controller... It doesn't have to be a gauge style though. There are inline controllers that are designed solely to feed a data to a logger or ECU.
Because One broken Stealth just wasn't enough... I made twins..
RealMcCoy is offline   Reply With Quote
Old 02-03-2013, 01:30 PM   #158 (permalink)
luvness018's Avatar
Ok thanks guys! I'm sure when I get my box in ill have a lot more questions, I'm kinda learning as I go and I sure appreciate the help!
Old 03-02-2013, 07:44 PM   #159 (permalink)
luvness018's Avatar
Quick question, do you think it would be possible to somehow incorporate the mmcdroid Bluetooth adapter? The instructions say to use the obd1 port but that will be occupied with the lcdbc. I don't want to splice any wires. Do you think I could modify an rs232 cable out of the datalog port on the box?
Old 03-02-2013, 09:09 PM   #160 (permalink)
HLxDrummer's Avatar
Drives: 1993 VR4
HLxDrummer Level 1HLxDrummer Level 1
Feedback Score: 42 reviews
Do I have to update for my LCDBC to work with chrome V2? I got mine sometime last summer I think so..
HLxDrummer is offline   Reply With Quote
