Curious thought on Coolant. - 3000GT/Stealth International Message Center
Old 12-13-2012, 05:50 PM   #1 (permalink)
Drives: 94 3000GT VR4
Notanothersk8ter is an unknown quantity at this point
Feedback Score: 0 reviews
Mitsubishi Curious thought on Coolant.
Is it bad to store your car without Coolant fluid during the winter?
Notanothersk8ter is offline   Reply With Quote
Old 12-13-2012, 06:06 PM   #2 (permalink)
Drunk as a lord
Forest Gump's Avatar
Drives: 1995 Stealth TT
Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2
Feedback Score: 100 reviews
Default Re: Curious thought on Coolant.
if the block is drained it is okay.
Forest Gump is offline   Reply With Quote
Old 12-13-2012, 06:44 PM   #3 (permalink)
mas
mas's Avatar
Drives: 95 R/T TT
mas is an unknown quantity at this point
Feedback Score: 4 reviews
could split the block. could split the radiator end tanks. could pop out freeze plugs..
could put some coolant in it.
1995 RT TT Galaxy white Pearl. 1 intercooler delete. 1 exhaust delete. More fuel
If SHTF, I want to be out of the room before then.
mas is offline   Reply With Quote
Old 12-14-2012, 06:52 PM   #4 (permalink)
Mitsubishi Re: Curious thought on Coolant.
What do you mean? And I would put coolant but it leaks. And I don't have the time to repair it at this time of the year.
Old 12-14-2012, 07:34 PM   #5 (permalink)
^^My name is April^^
dbest671's Avatar
Drives: Spyder VR4, SRT8
dbest671 Level 2dbest671 Level 2dbest671 Level 2dbest671 Level 2dbest671 Level 2
Feedback Score: 72 reviews
You're not going to be able to drain the block without moving the front turbo to get to the drain plug, the rear is a little more accessible but still not a task I would want to do... trust me it's a PITA. I would be worried about rust/corrosion TBH.
dbest671 is offline   Reply With Quote
Old 12-14-2012, 08:11 PM   #6 (permalink)
Grandpa Poser's Avatar
Grandpa Poser is an unknown quantity at this point
What would worrie me more than rust is the water pump seal drying out and becoming brittle, think there's a conditioner you can add first.
When life throws you a curve......Drive Baby, Drive.
Grandpa Poser is offline   Reply With Quote
Old 12-14-2012, 10:15 PM   #7 (permalink)
Curmudgeon
Steve '93ES's Avatar
Drives: '92 ES, '92 TT
Steve '93ES Level 2Steve '93ES Level 2Steve '93ES Level 2Steve '93ES Level 2
Feedback Score: 1 reviews
Not just the seal, the bearings themselves are at risk. I'm not 100% sure about ours but many (most?) water pumps have the bearings exposed to the coolant, and use the coolant to lubricate and cool the bearing. Draining the coolant for long periods runs the risk of pitting and corrosion ruining the bearing which will make sort work of the pump.
Where's it leaking? Any chance you could temporarily seal it up?
Steve '93ES is online now   Reply With Quote
Old 12-15-2012, 06:00 AM   #8 (permalink)
It's been over a month. Think it'll be rusted by now? If it is. What are some solutions to get rid of it? And what conditioner?
It's leaking in the O ring behind the thermostat. The water plump housing. Could I seal that up temporarily? Or what should I do?
Old 12-15-2012, 06:23 AM   #9 (permalink)
Andele, andele!
speedy25's Avatar
Drives: Various Japanese
speedy25 Level 1speedy25 Level 1
Feedback Score: 3 reviews
Pull off the right side manifold. After that you can remove the tube and replace your o-ring.
While someone else may know better All the water pumps I have removed over the years only had their bearings expose to coolant after failure. I recognise in the quest to make things super crappy cheap that may have changed.
The best part about an antifreeze product is that there are additives to protect from corrosion. Mostly corrosion clogs up heater cores and then radiators, but it also interferes with cooling efficiency. Use a flush product to clean things out after repairing your leak(s) and then fill with antifreeze.
-SP
