Old 11-08-2009, 05:27 PM   #31 (permalink)
Zzzzzzz
Fbc 978's Avatar
Drives: a smurf
Trader Rating: (51)
Fbc 978 is an unknown quantity at this point
Default Re: Coolant flow to throttle body - still necessary?
Put me under the "likes to delete crap" category. When I deleted the lines to the throttle body I just filled the hole for the fiav with epoxy. Works like a charm. I just enjoy having an empty bay.
Different strokes for different folks.
Pampena Stroker + 5857's...oh yes
Broomfield Racing - MADE IN USA
Billet Transfer Case Housings - Billet End Cases - Timing belt tools - and much more to come.
Fbc 978 is online now   Reply With Quote
Old 11-08-2009, 06:16 PM   #32 (permalink)
xsputnikx's Avatar
Drives: 92 VR4
Trader Rating: (20)
xsputnikx is an unknown quantity at this point
holly hell thats one sexy engine bay
I need rebuild parts feel free to pm me
Originally Posted by Echo419 View Post
get a donkey and pull your shit Oregon Trail style!
xsputnikx is offline   Reply With Quote
Old 11-08-2009, 08:12 PM   #33 (permalink)
resident evil
wraith's Avatar
Trader Rating: (16)
wraith Level 2wraith Level 2wraith Level 2wraith Level 2wraith Level 2wraith Level 2
I kept all my solenoids and such because they dont hurt performance and only serve to make the car more efficient and happen to make it more environmentally friendly for which I would not go out of my way to achieve but not going to mess it up if I get no gain out of it. Cars run more efficiently with things like recirculating BOVs, EGR and in this case the coolant to throttle does only good so why get rid of it. I got 400 miles to my last tank (17 gallons) punching it frequently and idling alot checking the tune...a good mix of highway and local streets. My Pontiac GTO gets about 240miles to 15 gallons. My VR4 gets over 400awhp, my GTO about 320-330rwhp, both on super. If I need to sell my car, it just needs stock injectors, downpipe with cats and plug the stock ECU back in and its good to go. The EGR dillutes intake charge at idle and cruise so your using less fuel in the combustion chamber. I wish the AEM operated that like OEM, I would be getting even better mileage.
wraith is offline   Reply With Quote
Old 11-08-2009, 09:30 PM   #34 (permalink)
Paid Member
Milkshakes is an unknown quantity at this point
I'd hump your leg if you do that to my engine bay.
1992 RT/TT
Condition: Broked.
Modifications: None.
Mileage: 132,000
Milkshakes is offline   Reply With Quote
Old 11-08-2009, 09:57 PM   #35 (permalink)
Zzzzzzz
Fbc 978's Avatar
Drives: a smurf
Trader Rating: (51)
Money talks
Old 11-10-2009, 08:00 PM   #36 (permalink)
Drives: 1992 3000GT VR4
UCSB VR4 is an unknown quantity at this point
Thumbs up Re: Coolant flow to throttle body - still necessary?
Thanks for the input guys. I actually wasn't aware that the coolant flow to the TB operated the FIAV, so I'm glad I posted this thread. Personally, I love the way my car idles right now in all conditions hot or cold, so I'm not going to take any chances with the delete, for now.
Thanks again,
Jeff
1992 RED 3000gt VR4 @ 17PSI
Engine Management:
MAFT-PRO v5.13a (SD mode w/ Electronic Boost & Load-Based Timing Control, GM 3 BAR MAP Sensor, GM IAT Sensor, & AEM UEGO WB O2).
Air:
DR-650s, DSM SMICs w/ 1 3/4" piping, 2" DN Performance intercooler hard pipes, IPS no-MAS intake pipes w/ dual K&N filters, ported & polished upper & lower intake manifolds, GReddy Type-S BOV (open loop), ET-Performance krank vents.
Fuel:
Supra fuel pump (hotwired), Labonte ISG-25 stage II water/meth kit w/ Snow Performance Boost Juice, 720cc Denso injectors, AEM FPR @ 45psi base pressure.
Ignition:
MSD 8.5mm superconductor wires, Denso iridium IK27 plugs @ .030", Odyssey PC925 battery.
Engine:
DR stage ]|[ heads, .50mm overbore, '99 lifters.
Exhaust:
Swain Tech White Lightning coated OBX headers & O2/pre-cat eliminators, ATR 3" downpipe, 3'' test pipe, ATR 3" catback.
Drivetrain:
RPS 6-puck disk, RPS lightweight flywheel, 3SX lightweight crank pulley, 3SX polyurethane motor mounts, stillen drilled and slotted rotors, 18x9.5 5Zigen FN01RC rims, BF-Goodrich KDW-2 tires, Cusco rear strut bar.
Miscellaneous:
Corbeau seats, short throw shifter, presidential alarm system, 300lbs of miscellaneous weight reductions... "who's your daddy?" license plate
Audio:
Kenwood headunit, Alpine PDX-4.150 amplifier, Polk MM6501 components, Polk MM691 3-way triaxial, 8 inch bazooka tube.
Future Mods:
1 Piece PST CFDS, Carbon Fiber Hood
UCSB VR4 is offline   Reply With Quote
