Old 11-06-2009, 03:29 AM   #1 (permalink)
Drives: 1992 3000GT VR4
UCSB VR4 is an unknown quantity at this point
Default Coolant flow to throttle body - still necessary?
I'm currently mid engine rebuild, and while the engine is out, I'm looking for ways to keep the intake (specifically intake plenum) temperature down. There are many direct contact hot parts which serve as heat transfers, allowing the intake plenum to get really hot -- and I've blocked all of them off except for one (coolant through the throttle body). To make a long story short, I've purchased these two items from 3SX (among other things):
Phenolic plenum spacer:
3SX Phenolic Plenum Spacer 3000GT/Stealth*-*Mitsubishi 3000GT*/*Dodge Stealth Parts
Phenolic throttle body spacer:
3SX Phenolic Throttle Body Spacer*-*Mitsubishi 3000GT*/*Dodge Stealth Parts
It makes sense that the second spacer would be necessary b/c coolant flows through the throttle body, but what if it didn't??? My question is:
Is it still necessary now that I have the plenum spacer for coolant to flow through my throttle body? My thought is that coolant might actually be heating up my throttle body instead of cooling it now that I have the spacer installed. Can I delete/remove the coolant tubes flowing to / from the throttle body? I just don't see why flowing coolant through there is necessary anymore now that the manifold should be much cooler.
Thoughts??
- Jeff
1992 RED 3000gt VR4
Engine Management:
MAFT-PRO v5.13a (SD mode w/ Electronic Boost & Load-Based Timing Control, GM 3 BAR MAP Sensor, GM IAT Sensor, & AEM UEGO WB O2).
Air:
DR-650s, DSM SMICs w/ 1 3/4" piping, 2" DN Performance intercooler hard pipes, IPS no-MAS intake pipes w/ dual K&N filters, ported & polished upper & lower intake manifolds, GReddy Type-S BOV (open loop), ET-Performance krank vents.
Fuel:
Supra fuel pump (hotwired), Labonte ISG-25 stage II water/meth kit w/ Snow Performance Boost Juice, 720cc Denso injectors, AEM FPR @ 45psi base pressure.
Ignition:
MSD 8.5mm superconductor wires, Denso iridium IK27 plugs @ .030", Odyssey PC925 battery.
Engine:
DR stage ]|[ heads, .50mm overbore, '99 lifters.
Exhaust:
Swain Tech White Lightning coated OBX headers & O2/pre-cat eliminators, ATR 3" downpipe, 3'' test pipe, ATR 3" catback.
Drivetrain:
RPS 6-puck disk, RPS lightweight flywheel, 3SX lightweight crank pulley, 3SX polyurethane motor mounts, stillen drilled and slotted rotors, 18x9.5 5Zigen FN01RC rims, BF-Goodrich KDW-2 tires, Cusco rear strut bar.
Miscellaneous:
Corbeau seats, short throw shifter, presidential alarm system, 300lbs of miscellaneous weight reductions... "who's your daddy?" license plate
Audio:
Kenwood headunit, Alpine PDX-4.150 amplifier, Polk MM6501 components, Polk MM691 3-way triaxial, 8 inch bazooka tube.
Future Mods:
1 Piece PST CFDS, Carbon Fiber Hood
UCSB VR4 is offline   Reply With Quote
Old 11-06-2009, 03:50 AM   #2 (permalink)
Stuff and Junk and Things
EvanH's Avatar
Drives: NO PASSENGERS!!
Trader Rating: (7)
EvanH is an unknown quantity at this point
Default Re: Coolant flow to throttle body - still necessary?
I don't know why the coolant is routed thru the throttle body. Only concept I can think of is in extreme cold so the engine gets to temp faster? I don't even know. Honestly I don't think it is necessary at all. And I don't believe in the slightest that it would actually hurt anything to leave it capped off and be free of hot coolant flowing thru it.
EvanH is offline   Reply With Quote
Old 11-06-2009, 06:56 AM   #3 (permalink)
linchpinjoe's Avatar
Drives: 99VR4
Trader Rating: (21)
linchpinjoe Level 2linchpinjoe Level 2linchpinjoe Level 2linchpinjoe Level 2
Route the coolant flow INTO the throttle body. It will cool your pistons down.
linchpinjoe is offline   Reply With Quote
Old 11-06-2009, 09:48 AM   #4 (permalink)
Hawks are faggots
Ben_Pow!!'s Avatar
Drives: Turbo Timebomb
Trader Rating: (6)
Ben_Pow!! is an unknown quantity at this point
I may be off a bit, but the coolant runs through to warm idle speed control motor. I have heard of people deleting the coolant to the TB, some have cold start problems, others don't. If you do, you can always plug them back in.
May find info here...
Stealth 316 - ISC Servo Motro
92 Black Stealth TT
Forged Wiseco Pistons : Forged Crank : 99' Lash Adjusters : Custom 3" Exaust, Deleted Cats : Hotwired Fuel Pump : FPR : FMIC : TurboXS H-RFL BOV : TD04HL-15G's : Denso 720cc : PalmIII w/pocketlogger software : Speed Density MAFT Pro
91 White Stealth TT
Forged Venollia Pistons 7.5:1 Compression : Forged Crank : 99' Lash Adjusters : Denso 720cc Injectors : 3" Custom Bent Exhaust w/DP : Hotwired Walbro 255 : K&N Intake : Greddy E-Manage : PalmIII w/ Software
waiting to Install Freshly Rebuilt TD05-14B's w/ bullseye Exhaust housings : Custom Headers, O2 housings, DP
92 Burgundy SL *FOR SALE* - $1,000 OBO
93 Stealth Base w/ R/T Rear End *FOR SALE* - $2,200
The only thing that old bag is fighting is the angel of death as he moon walks into the bedroom carrying a pillow with two handles. -Jim Norton
I know a guy with a foxbody (none the less) that once said my TT stealth was and I quote "a big pussy 'cause its got a weedeater motor and can't do no burnout". -BondoB
Ben_Pow!! is offline   Reply With Quote
Old 11-06-2009, 11:35 AM   #5 (permalink)
soccermania688's Avatar
Drives: Mitsubishis
Trader Rating: (7)
soccermania688 is an unknown quantity at this point
I have mine capped off. No problems. Anything to free up the engine bay lol.
1992 3000GT VR4 10:1 comp, Fidanza FW, RPS PP & Stock disc, Air Filter, Greddy type S BOV, gutted precats, AWS Delete, Vac Reduc, MBC-not set yet, Autometer BG.
Coming Soon: Maximal Single Shot(hopefully), MBC, Downpipe, FMIC.
1993 3000GT SL(PARTING OUT-PM FOR PARTS!!!)
-Junking this car soon so if you want really CHEAP PARTS PM me now!!!!!
'93 Sl ECU rebuilt 100$ shipped
soccermania688 is online now   Reply With Quote
Old 11-06-2009, 11:41 AM   #6 (permalink)
Hawks are faggots
Ben_Pow!!'s Avatar
Trader Rating: (6)
Yeah, I've got the vac line/EGR reduction done, speed density running open turbos, etc.
Is all I need to do is remove the lines, & cap the outlets on the coolant housing? I can leave the throttle body nipples alone correct?
Old 11-06-2009, 11:57 AM   #7 (permalink)
never a dull moment
DCIV's Avatar
Drives: 93vr4 & 92vr4
Trader Rating: (13)
DCIV Level 1DCIV Level 1
uh...yeah, not helping there man.
I deleted mine. you can get a plate to cover it from slowboy racing, same as the DSM ones. Screws are a pain in the ass to get out and you will prob have to drill them out. Capping off the water neck is somewhat of a pain and I suggest welding it. If your in cold climate you may also find that it will have a little more prob idling till it gets really warm.
Coop
To many mods to list.
Old 11-06-2009, 12:07 PM   #8 (permalink)
good synchros ftw
Intropy's Avatar
Drives: 2nd Gen RT/TTs
Trader Rating: (28)
Intropy is an unknown quantity at this point
Well first of all, what the coolant flowing through the throttle body does is operate the FIAV (fast idle air valve). It allows a higher idle when coolant temps (and therefore engine temps) are cold. It's all pretty negligible compared with the efficiency of your intercoolers. If you really want to drop combustion temps, spray some meth.
In my opinion, deleting the FIAV on a street car is dumb (no offense Coop, lol). It serves a useful purpose and it's not like it's a huge eyesore.
Intropy is offline   Reply With Quote
Old 11-06-2009, 12:13 PM   #9 (permalink)
Mr. Hammer
jackhammer's Avatar
Drives: RC46
Trader Rating: (60)
jackhammer Level 2jackhammer Level 2jackhammer Level 2jackhammer Level 2
I have a hose going between them so it just loops around, not blocked off
yes
The traveling 3S mechanic, Manual trans rebuilding, using only genuine Mitsu/Getrag parts.
jackhammer is offline   Reply With Quote
Old 11-06-2009, 12:14 PM   #10 (permalink)
never a dull moment
DCIV's Avatar
Trader Rating: (13)
no prob man ~500 miles in 2 yrs I wouldnt call mine a street car right now anyways lol. When I first got the car I would never take it out if it was below 50 and so thats prob why I never really had ill effects anyways.
Coop
