Old 05-02-2008, 12:18 AM   #11 (permalink)
King Detail
ProwlerGT's Avatar
Drives: 95 3000GT Base DOHC
Trader Rating: (11)
ProwlerGT Level 1ProwlerGT Level 1
Question Re: Compression Testing Correctly and Cold vs Warm engine
BUMP - No one knows the answer on this?
INFO LINKS FOR EVERYONE:
 ProwlerGT's Revival Thread | My Service Log | IAC | SENSORS | Hesitation Tracking List | NO3S.com
Lata,
ProwlerGT
"Those who know me, know my real name and more importantly how to say it right."
ThinkAbtIt on AIM | searcherrr on Yahoo IM | Email in profile
ProwlerGT is offline   Reply With Quote
Old 05-02-2008, 12:49 AM   #12 (permalink)
modding addicted
Turbo Powered's Avatar
Drives: at high g's
Trader Rating: (23)
Turbo Powered Level 7Turbo Powered Level 7Turbo Powered Level 7Turbo Powered Level 7Turbo Powered Level 7Turbo Powered Level 7Turbo Powered Level 7
Default Re: Compression Testing Correctly and Cold vs Warm engine
Originally Posted by ProwlerGT View Post
I know proper procedure is to remove ALL plugs before doing testing, but is that just because the manual wants you to test all cylinders or because it changes the pressure results?
I ask cause I'm about to test the front bank after I take the car for a spin and of course I would rather not remove all the junk to test the rear bank again if the car seems to be running fine.
The plugs are all removed so that the starter motor is only having to compress the air in one cylinder. The engine will turn over slower with some of the plugs installed, so the readings will be slightly lower.
Turbo Powered is offline   Reply With Quote
Old 05-02-2008, 03:47 AM   #13 (permalink)
King Detail
ProwlerGT's Avatar
Trader Rating: (11)
Thank you. So when ya say "slightly" do ya think thats like maybe 5 psi lower? lol - I know I know.... i should just do it right, but it really would just be only for the sake of the test cause I "think" the engine is running right.
Old 05-02-2008, 06:52 AM   #14 (permalink)
oohnoo's Avatar
Trader Rating: (156)
oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7
Just do the test already, it's only a compression test. Make sure you have a battery charger on it cause if your battery isn't healthy it'll slow down which will result in slightly lower numbers.
oohnoo is offline   Reply With Quote
Old 05-02-2008, 09:30 AM   #15 (permalink)
King Detail
ProwlerGT's Avatar
Trader Rating: (11)
I know I know huh? lol ok ok - I just didn't want anything all skewed to happen.
Old 05-02-2008, 10:18 AM   #16 (permalink)
HLxDrummer's Avatar
Drives: 3000GT, '71 Mustang
HLxDrummer level 6HLxDrummer level 6HLxDrummer level 6HLxDrummer level 6HLxDrummer level 6HLxDrummer level 6
I was just wondering this SAME exact question, how convenient lol
Anyhow, we tested the compression on the VR4 that hasn't ran in a few weeks (so it's obviously cold and no oil pressure). Most cylinders were around 115 and one was slightly lower (5-10psi off). I was hoping the warm figures would be a decent amount higher since these are kind of low (service limit).
How are you guys getting 150psi cold!? lol
From my research it seems that from warm to cold there is a difference of around 10-15 psi but I have no hard proof, just from what I've read.
1994 3000GT SL - Old Daily Driver SOLD
Custom Paint, Full Custom Exhaust, etc.
1993 VR4 with 150K miles - Daily Driver/Weekend Warrior/Sole Method of Transportation
Go: eBay Tanabe Concept G Blue Replica TBE, Metal Evo DV, Maximals TC Bracket, PST Two Piece Steel/Aluminum Driveshaft
Monitoring: Palm M100 with MMCD, STRI X-Line Boost Gauge
Maintenance: 120K with oil pump and main/rod bearings, MSD 8.5MM wires, NGK Platinum plugs, Redline/Castrol Fluids, New ECU, Lowes Pressure Tester, New IAC/PVC/etc.
Show: '99 Garnish, Alan's Snake Eyes, Stealthy Wiper Mod, 3SX Aluminum Pedals
HLxDrummer is offline   Reply With Quote
Old 05-03-2008, 07:44 PM   #17 (permalink)
King Detail
ProwlerGT's Avatar
Trader Rating: (11)
Did the warm compression test earlier on the front bank:
Cylinder 1: 184
Cylinder 3: 180
Cylinder 5: 179
Will post the remaining bank later.
As you can see so far testing warm vs cold can variate greatly and really doesn't show a pattern (refer to post#8 for cold test #s). The idea that it'll only be 15lbs difference or any set psi difference is just false. Just gotta do the test correctly. I wasn't even comfortable doing the test warm without the 3 rear plugs out, instead I just removed all front plugs.
I'm probably going to retest again all 6 once all plugs are out and its warm. Would've done it all at once earlier, but had a friend stop by and supper and tonight the NEW ORLEANS HORNETS are playing in the semi-finals so car will sit !!!! lol
Old 05-03-2008, 08:38 PM   #18 (permalink)
oohnoo's Avatar
See, nothing to be afraid of........Great results.
Old 05-03-2008, 11:34 PM   #19 (permalink)
King Detail
ProwlerGT's Avatar
Trader Rating: (11)
LOL - I just hope the rear bank is just as good and I have a hunch it will be.
