Old 04-23-2008, 12:36 AM   #1 (permalink)
King Detail
ProwlerGT's Avatar
Drives: 95 3000GT Base DOHC
Trader Rating: (11)
ProwlerGT is an unknown quantity at this point
Exclamation Compression Testing Correctly and Cold vs Warm engine
I have done searches and not seen any real hard data as to the differences in psi observed doing this test COLD vs WARM. I have my engine bay apart tonight and as you could imagine I don't really want to put it all back together to obtain WARM temp to do the test and of course nor do I like working on a hot engine bay for obvious reasons.
So please answer to what you have SEEN cold compression tests show vs warm ones on the SAME ENGINE. This isn't a thread to bicker as I've seen some of the other compression threads do. This is a thread to try and find possibly an established PSI range difference that cold testing would show vs hot testing AS WELL AS TO CLEAR UP HOW COMPRESSION TESTING IS DONE ON OUR CARS for those that need to know.
Kicking questions/comments off right here is the official procedure from the manual (with a few added remarks) and yes I realize it says to test warm so I don't need to hear it. I know everyone isn't testing warm.
Procedure:
Page 11-14 ENGINE - On-vehicle Service
COMPRESSION PRESSURE CHECK
(1) Prior to inspection, check to ensure that the engine oil, starter motor and battery (good charge on it) are in proper condition. Place the vehicle in the following conditions:
  • Engine coolant temperature: 80-95°C (176-203°F)
  • Lights, electric cooling fan and accessories: OFF
  • Transaxle: Neutral (P for A/T)
(2) Remove the spark plug cables.
(3) Remove all of the spark plugs.
(4) Disconnect the crankshaft position sensor connector.
NOTE: By so doing the engine control module stops performing ignition and fuel injection.
(5) Cover the spark plug mounting holes with a shop towel, crank the engine, and then check for foreign substances deposited on the shop towel.
Caution
1. When you crank the engine, keep away from the spark plug mounting holes.
2. If a compression measurement is performed with water, oil, fuel, etc. in the cylinder due to the cracks in the cylinders, these substances heated to a very high temperature will blow off the spark plug mounting holes and could be dangerous.
(6) Install a compression gauge in a spark plug mounting hole.
(7) Set the throttle valve in a fully opened position (unless the plenum is off already), and crank the engine to measure the compression pressure.
Standard value:
Non-Turbo 1,270 kPa (185 psi) [250-400 rpm]
Turbo 1,080 kPa (156 psi) [250-400 rpm]
Limit:
Non-Turbo min. 959 kPa (139 psi) [250-400 rpm]
Turbo min. 792 kPa (115 psi) [250-400 rpm]
(8) Measure the compression pressure in each of the cylinders and check that the difference in compression pressure between the individual cylinders is less than the limit value.
Limit: max. 98 kPa (14 psi)
INFO LINKS FOR EVERYONE:
 ProwlerGT's Revival Thread | My Service Log | IAC | SENSORS | Hesitation Tracking List | NO3S.com
Lata,
ProwlerGT
"Those who know me, know my real name and more importantly how to say it right."
ThinkAbtIt on AIM | searcherrr on Yahoo IM | Email in profile
ProwlerGT is offline   Reply With Quote
Old 04-23-2008, 02:32 AM   #2 (permalink)
Drives: Red 1991 VR-4 (#3)
ZephTheChef Level 4ZephTheChef Level 4ZephTheChef Level 4ZephTheChef Level 4ZephTheChef Level 4
Default Re: Compression Testing Correctly and Cold vs Warm engine
The difference between cold and warm measurements is going to vary greatly engine to engine, or even cylinder to cylinder...it's not really a good practice to guess at what that difference is.
"why its a tubloidial butt noid!" - Ray Pampena, 2006
ZephTheChef is offline   Reply With Quote
Old 04-23-2008, 02:44 AM   #3 (permalink)
Forest Gump
cbehnken's Avatar
Drives: 1992 Stealth TT
Trader Rating: (42)
cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7
yep, on my personal car it has varied as much as 15 PSI cold to warm.
There is no accuracy when you check the engine cold, so you may as well not bother. All it will tell you is if your rings are totally shot or not.
Power: DSM 13G/DR650 Combo, DSM 450 cc bluetops, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback,
no cats, DN Y-Pipe, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead 8.07 @ 85.55 1/8th mile 1.84 60FT
Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, AWS Delete
Drivetrain: RPS Street Max, M.W. 300m O/S, Seattle F&R Poly Mounts
Etc: Roller Bearing Short Shifter Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit
Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing/sideskirts/doorcaps
Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings.
Mobile 1 10w40, Redline MTL in trans, 85w90 Coastal GL5 in transfer case and rear
Complete 1G datalogger/cable/software for sale
cbehnken is offline   Reply With Quote
Old 04-23-2008, 06:05 AM   #4 (permalink)
oohnoo's Avatar
Trader Rating: (146)
oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7
You'll be fine. Should be around 130psi cold. You'll still be able to tell if there's an issue such as a gross compression, valve leak, etc.
oohnoo is offline   Reply With Quote
Old 04-23-2008, 10:04 AM   #5 (permalink)
Warning: I'm an asshole
SkortchGT's Avatar
Drives: 1992 3000GT VR4
Trader Rating: (10)
SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7
I had 160 across the board on a semi warm motor on a new shorty
1992 3000GT VR4
--Completely rebuilt 5/06-4/07. Everything new. For a list see: http://www.3si.org/forum/showthread.php?t=372579
--First time on dyno: 364AWHP@16psi with a 10.3AFR (now tuned at 11.4-11.6 with timing control, time for another dyno run soon)
--Mods: DR Stage I heads, 3rd gen lifters, TD04L 13Gs, DSM SMICs, PTE 550s, Apexi SAFC, Apexi SITC, Walbro FP, IPO hotwire, Robbeck adapter & AEM FPR, 3SX underhood fuel gauge, 3SX fuel rail loop, DN Y-pipe, HKS SSQ BOV, K&N FIPK, Greddy Profec Spec S, AEM WB02, Autometer C2 boost, egt, oil press & water temp gauges, MSD wires, NGK BCP7ES's, TEIN FLEX coilovers, Maximal performance control arms, solid engine mounts & powdercoating, RPS Streetmax Clutch, RPS Flywheel, NBT Tranny (cryotreated OS, shift forks & rails), updated speedo gear, solid shifter bushings, full 2nd gen brake conversion, 3SX SS brake & clutch lines, Carbotech Panther+ pads in the front & Bob Cats in the rear, 3SX clutch vac delete, EGR delete, vac reduction, Ebay DP, gutted pre cats, Bronze FN01RCs 5Zigen 18x8.5 + 30 offset, Pirelli P-Zeros, engine dress up kit, Bigtyla ground wire kit.
--Daily Driver: 98 Malibu, 4cyl, auto
SkortchGT is offline   Reply With Quote
Old 04-24-2008, 09:56 PM   #6 (permalink)
King Detail
ProwlerGT's Avatar
Trader Rating: (11)
Talking Re: Compression Testing Correctly and Cold vs Warm engine
Thats a lil high for a turbo though probably due to mods right?
I'm gonna cold test mine tonight and post the cold vs warm figures for others to have a basis to go off of. I may not do the rear bank warm... depends on how I feel. lol
Old 04-24-2008, 10:34 PM   #7 (permalink)
Pearl White 92 Stealth TT
mike92stealthtt's Avatar
Drives: 100+ IDC's
Trader Rating: (12)
mike92stealthtt Level 3mike92stealthtt Level 3mike92stealthtt Level 3mike92stealthtt Level 3
I did a cold compression test on my 110K motor after doing my 120K and all the cylinders were between 150-160 psi.
mike92stealthtt is offline   Reply With Quote
Old 04-25-2008, 05:49 AM   #8 (permalink)
King Detail
ProwlerGT's Avatar
Trader Rating: (11)
Exclamation Re: Compression Testing Correctly and Cold vs Warm engine
Well, in my case my engine has been sitting for several months with no crank. I don't know if that affects the test or not, but what I do think affects the test is debris inside the spark plug bore where the compression tester fitting/gasket meets with the metal to make a good seal to receive the pressure.
I did each test on a COLD engine and tightened as much as I could and cleaned as best I could first. Here are the results:
Cyl 1: 213 & 169 Cyl 2: 183
Cyl 3: 135 Cyl 4: 139
Cyl 5: 135 Cyl 6: 147
Cylinder 1 had some oil on the plug threads and in the bore before I loosened it. The 2nd test I did on it was done after retightening the fitting for the compression tester. I didn't realize it till later, but that was the bore with the most debris in it hence me needing to tighten it more.
I have reassembled the beast, but I am not starting it up because if things don't run right I'm gonna be HELLA pissed after I spent the entire AM hours till dawn putting her back together. I will do a HOT test on the front bank when I awake later today and if the car is running good I will not do the rear bank. Its just too much to do especially if things are running good.
In any case if I were to go by the cold numbers it looks like I'd have some problems, but this is a good test to show you probably cannot as others have said.
Old 04-25-2008, 07:26 AM   #9 (permalink)
SkortchGT's Avatar
Trader Rating: (10)
Na thats not high, I have a brand new stock short block. The manual calls for 156psi within 14 psi of eachother. It's possible that the head resurfacing might have upped the compression 4psi due to an extremely slight loss in head height, but I doubt it. Everything is just nice, new, and tight like a virgin.
Old 05-01-2008, 04:03 PM   #10 (permalink)
King Detail
ProwlerGT's Avatar
Trader Rating: (11)
Question Re: Compression Testing Correctly and Cold vs Warm engine
I know proper procedure is to remove ALL plugs before doing testing, but is that just because the manual wants you to test all cylinders or because it changes the pressure results?
I ask cause I'm about to test the front bank after I take the car for a spin and of course I would rather not remove all the junk to test the rear bank again if the car seems to be running fine.
