Old 08-03-2008, 02:41 AM   #1 (permalink)
Certified White Boy
92stealth15g's Avatar
Drives: 1992 Stealth RT/TT
92stealth15g Level 392stealth15g Level 392stealth15g Level 392stealth15g Level 3
Default Clutch Problems: Things to do before pulling the transmission.
**CHECK OUT THE VIDEOS**
Well my clutch is acting funny, hopefully we can get this figured out. It was making a rattling noise (TOB) and then it started locking me out of gears. I first noticed it when i launched and went to hit second and it wouldnt let me in. At first it went away but then it came back a second time and its worse now. I cannot get it in gear now unless I turn the car off, put it in gear and then start it (it pulls forward while im starting it).
The best way to explain it is that the clutch is not fully disengaging. My question is what things should I check before pulling the transmission off? I have already checked these things:
-pedal adjustment
-the slave and master are not leaking
-bled out the system
-checked fluid level in transmission
Is there anything else I should do or check before pulling the transmission off? Any ideas what it could be that is causing this? If it is internal do you think I need a whole new clutch or just a TOB? Thanks!!
"Clutch-Eater"
-1992 Dodge Stealth R/T Twin turbo AWD, Dynamic Racing stage II heads, 99 lifters, 6-speed Getrag from 99 vr4, SPEC Stage 4 clutch, TEC 15g's, Greddy blow off valve, Dejon Powerhouse Blow-Thru Intake Pipes, DSM sidemounts, Denso fuel pump, 550cc fuel injectors, Apexi SAFC, HKS VPC, Apexi AVCR, msd ignition dis-4, MSD 8.5mm wires, NGK coppers 1 stage colder, alamo y-pipe, custom exhaust from turbos back, highflow cat, Lowered, Nitto tires.
"Knockin' Beater"
-1996 Mitsubishi Eclipse GS
Originally Posted by TitanGenesis View Post
"That thing got a hemi?"
"No, it's got a V6 TT with AWD sup?"
92stealth15g is offline   Reply With Quote
Old 08-03-2008, 03:20 AM   #2 (permalink)
SOHC you in the FACE
Ondontii's Avatar
Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7
Default Re: Clutch Problems: Things to do before pulling the transmission.
does the car creep forward when you have it in gear with the clutch pushed in (and you rev the motor).
Brent
1992 Duster -12.7@114 - 14psi boost -13.9@107.4 - 5psi - 6g72 3.13L "built" SOHC, Precision T67 P-trim, Tial 38mm open dump, 3" downpipe, 20x12x3" evo style intercooler, 7:1 compression, balanced, shot peened rods, heavily ported heads (+40% on flowbench), Ferrea Competition Plus +2 +1 stainless valves, Nielson Vintage 278 duration custom turbo cams, RPW Cam gears, Custom Ram Style short runner intake manifold, Walbro 255hp, 6*47# injectors, +0.096" Forged Venolias, Total Seal chrome gapless top rings, Fidandza Flywheel, Clutchnet 3 puck solid hub, OBX Helical LSD, Zeitronix wideband/EGT/Boost sensors, 100watt DevilsOwn Meth Kit.
1994 Spirit - 13.987@101.89 - 5psi- 6g72 SOHC, K27 Turbo
Ondontii is offline   Reply With Quote
Old 08-03-2008, 08:43 AM   #3 (permalink)
Damage Control
Stealthee's Avatar
Drives: 1994 Stealth
Trader Rating: (78)
Could be a bent release fork.
Basically if its bent it wont depress the clutch enough to fully disenage. Its either that or damaged fingers on the pressure plate if all the hydraulics are checking out.
Old 08-03-2008, 01:08 PM   #4 (permalink)
Certified White Boy
the car pulls forward pretty violently if you start it in gear. Otherwise it will not even go into gear if you try putting it in while started already.
how would I go about diagnosing a release fork? Would the tranny need to be pulled? So its possible I need a new clutch, but also possible I only need a new fork? The clutch has only around 1000 miles on it. same with the flywheel.
Old 08-03-2008, 01:55 PM   #5 (permalink)
Vorsath is an unknown quantity at this point
Even if the slave and master cylinders are not leaking they can still be bad, sometimes they start not working well enough. Are the noises only when you put it in gear or all the time while driving? If it's just when you are trying to shift then it might just be the gears grinding a bit.... Also if the fluid's get dirty in the master cylinder then it's probably bad. You can also push on the slave to see how fast it returns and if it returns all the way to where it should be on it's own. I know with my stealth I changed the trans fluids a couple times and and that helped for a while...eventually I had to replace the master and it was good for a long time...then it happened again and I replaced the slave and replaced the lines with the 3si steal braded and it's good to this day. But if it makes noise just driving, then that's nothing to do with the hydraulics or dirty fluid.
Vorsath is offline   Reply With Quote
Old 08-03-2008, 02:29 PM   #6 (permalink)
Certified White Boy
Thanks for the advice. Slave was replaced recently. The rattling noises happen when driving or sitting at an idle with the clutch not pushed in. The noises used to go away when the clutch was disengaged but now it is constantly there because the clutch is not disengaging.
Old 08-03-2008, 02:32 PM   #7 (permalink)
Profesional Insomniac
veerfour05's Avatar
Drives: 93 VR4
veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7
Sounds like a release problem, not a clutch problem. Like they said check to see how far the slave is actually moving when the pedel gets pressed. Could be a bad master or slave. When you bled it was any air coming out or did it seem like there wasn't much in the system. If you were hearing the TOB noise before though I would imagine that it's the fork. Check the other stuff first and if that checks out pull the trans.
veerfour05 is offline   Reply With Quote
Old 08-03-2008, 02:35 PM   #8 (permalink)
Damage Control
Stealthee's Avatar
Trader Rating: (78)
A thought just occured. The rattling could be the release fork itself. It may have somehow popped off the little ball it attaches to in the bellhousing.
Old 08-03-2008, 02:38 PM   #9 (permalink)
Healther Stealther's Avatar
Drives: '91 Stealth R/T TT
Healther Stealther is an unknown quantity at this point
I'm going through this same issue right now. My problem was the slave cylinder leaking and the fluid going low. It went low on fluid the first time and I had trouble getting in and out of gear just as you describe, car creeping forward, difficulty shifting, everything. I topped the fluid of fand was good for a few weeks then low again. The last time it went low I nearly did make it home. Fortunately I had the forsight to carry fluid with me in the car. I had to stop twice to add fluid, pump vigorously, and drive in 3rd gear as much as possble to minimize depressing the clutch to make it home.
I just removed the slave cylinder last night, cleaned it, and hit it with a hone to spooth out some pitting and corrosion. I just ordered a repair kit from Cherry Hill Triplex for $9.77 + $7.00 Shipping. A cheap fix. I had to remove the air filter box and some of the plumbing for the turbos. I did not remove the battery or washer fluid tank but wish I had. It would have been much easier. I was worried about disconnecting the battery and loosing use of the radio since I don't have the security code yet from the dealer.
My leak was obvious. I strongly feel from your description you have the same issue either on the slave or master cylinder.
Good Luck.
Healther Stealther is offline   Reply With Quote
Old 08-03-2008, 03:09 PM   #10 (permalink)
Certified White Boy
this seems likely... it happened first during a harrdd launch against a terminator cobra. then it went away and happened again when i shifted hard to second....
My slave was recently replaced. I bled out the system and there was no air.
