Old 08-11-2008, 01:06 PM   #41 (permalink)
Certified White Boy
92stealth15g's Avatar
Drives: 1992 Stealth RT/TT
92stealth15g Level 392stealth15g Level 392stealth15g Level 392stealth15g Level 3
Default Re: Clutch Problems: Things to do before pulling the transmission.
Originally Posted by foriscali10 View Post
Same thing happened to my car. First, the stock clutch popped a spring causing me to be locked out of the gears. I replaced the clutch with spec stage 2 which had two springs already popping out!! This weekend I replaced the stage 2 with a spec stage 4 unsprung. Good luck with your car and I hope u get a unsprung clutch this time.
yup thats what im going to do.. screw southbend.
"Clutch-Eater"
-1992 Dodge Stealth R/T Twin turbo AWD, Dynamic Racing stage II heads, 99 lifters, 6-speed Getrag from 99 vr4, SPEC Stage 4 clutch, TEC 15g's, Greddy blow off valve, Dejon Powerhouse Blow-Thru Intake Pipes, DSM sidemounts, Denso fuel pump, 550cc fuel injectors, Apexi SAFC, HKS VPC, Apexi AVCR, msd ignition dis-4, MSD 8.5mm wires, NGK coppers 1 stage colder, alamo y-pipe, custom exhaust from turbos back, highflow cat, Lowered, Nitto tires.
"Knockin' Beater"
-1996 Mitsubishi Eclipse GS
Originally Posted by TitanGenesis View Post
"That thing got a hemi?"
"No, it's got a V6 TT with AWD sup?"
92stealth15g is offline   Reply With Quote
