Old 08-11-2008, 08:37 PM   #1 (permalink)
Computer Wiz
doggie504's Avatar
Drives: 93 SL,90 XJ6 75k mi.
doggie504 is an unknown quantity at this point
Default clutch dropping
i'm not sure if this jsut happens when a car sits, but after a day or so of not hitting the clutch i have to pump it up 2 times, and it works 100%.
just wondering, and was not sure where to put this
doggie504 is offline   Reply With Quote
Old 08-11-2008, 08:55 PM   #2 (permalink)
Texan94SL's Avatar
Drives: 94 Pearl White SL
Trader Rating: (16)
Texan94SL Level 2Texan94SL Level 2Texan94SL Level 2
Default Re: clutch dropping
Mine did the same.
The seals in the clutch master cylinder on mine had failed and it was leaking internally. I rebuilt the master cyl. with a $12 kit from NAPA. It works great and was easy to do.
NAPAŽ Online
You will need a 10 mm flare crowfoot to get the line off the master cyl. Carquest sells a set of metric crowfoots for $30.
There is no need to buy a new or remanufactured master cylinder for over $100 for OEM or around $45 for made in Taiwan stuff.
The rebuild kit is made in the USA.
Texan94SL is online now   Reply With Quote
Old 08-11-2008, 09:00 PM   #3 (permalink)
Computer Wiz
doggie504's Avatar
thanks, but do you know if this is serous, need to get some other things first. like could i drive it around safely?
Old 08-11-2008, 09:10 PM   #4 (permalink)
Texan94SL's Avatar
Trader Rating: (16)
The gears will get harder to get into until the system fails completely.
There is no "danger" but you could get stranded somewhere and the pedal will be dead....no getting into any gear or getting out of one you are in.
Worst case....you will stall it and be unable to move in traffic then need a tow home.
Old 08-11-2008, 09:29 PM   #5 (permalink)
Computer Wiz
doggie504's Avatar
thought as much ty for the help
