Old 01-23-2007, 01:54 PM   #11 (permalink)
TajMan's Avatar
Drives: Z28
Trader Rating: (25)
TajMan is an unknown quantity at this point
Default Re: Check out my Damage on the Clutch and Flywheel
Yeah I was like WTF all those attachments lol.
Get a used fllywheel from someone on the forum.
Where is the case cracked? The bellhousing could be welded back together if it was just clutch damage.
former 3/Ss: '92 R/T, '94 3KGT, modded '92 R/T TT
'87 Jeep Comanche truck
'94 Camaro Z28 convertible - buy me $1,700 below bluebook!
TajMan is offline   Reply With Quote
Old 01-23-2007, 02:28 PM   #12 (permalink)
15t's ... ? yep
DigiiManDan3KGT's Avatar
Drives: 80Gig WesternDigital
Trader Rating: (7)
DigiiManDan3KGT Level 2DigiiManDan3KGT Level 2DigiiManDan3KGT Level 2
With the transmission you have the Bellhousing, Case, and End Cap.
The Middle section is the Case. Its cracked in a straight line from the bell housing to the End cap just below the motor mount. This was damaged that happened befor the clutch failed. I'm thinking about just taking the case section to an Aluminum welder and having it repaired.
Green 1995 3000GT FWD-TT 8:1 // 15t Turbos // ATX to MTX // NA to TT // Purchased 11/12/02
White 1999 3000GT Black Dash/Tan Leather Interior // SOHC // MTX // Stock Daily Driver Purchased 7/25/07
Red.._1992 Stealth RT/TT Twin Turbo AWD // Organ Donor // Purchased 05/19/08
<-- Click Here Join FL3S
DigiiManDan3KGT is offline   Reply With Quote
