Old 01-23-2007, 10:39 AM   #1 (permalink)
2 Time Member of SBC
DigiiManDan3KGT's Avatar
Drives: 80Gig WesternDigital
Trader Rating: (7)
DigiiManDan3KGT is an unknown quantity at this point
Default Check out my Damage on the Clutch and Flywheel
The clutch and flywheel had about 8,000 miles on it. I was driving my Girlfriend home from a club at 2am and I lost the clutch.It wouldn't come out of gear. A spring blew out of the clutch and locked it to the flywheel.
I dont trust the flywheel any more, It could be warped. This sucks that flywheel is god damn expensive. The clutch was in GREAT shape. It barly had any wear on the meat. I'm so mad that was over 1k$ worth of damage. I don't know if this was my fault or not, It doesn't look like it. Whats your feedback?
Camera Phone action.
BTW, I have a Crack in my AWD Getrag, I need a new case section so if any one reads this and has one let me know.
Green 1995 3000GT FWD-TT 8:1 // ATX to MTX // NA to TT // Completed in 2005 // Purchased 11/12/02
White 1999 3000GT Black Dash/Tan Leather Interior // SOHC // MTX // Stock Daily Driver Purchased 7/25/07
Red.._1992 Stealth RT/TT Twin Turbo AWD // Project Car for AWD // Purchased 05/19/08
<-- Click Here Join FL3S
DigiiManDan3KGT is offline   Reply With Quote
Old 01-23-2007, 12:22 PM   #2 (permalink)
"The Fisherman"
pyun's Avatar
Drives: around scaring birds
Trader Rating: (75)
pyun is an unknown quantity at this point
Default Re: Check out my Damage on the Clutch and Flywheel
Why don't you see if it's warped or not for real then? Same thing happened to my RPS Flywheel and I still used it with no ill effects.
Brian
pyun is offline   Reply With Quote
Old 01-23-2007, 12:26 PM   #3 (permalink)
Verified
jackhammer's Avatar
Drives: RC46 / IS300
Trader Rating: (55)
jackhammer Level 1jackhammer Level 1
Get it balanced and check for flatness and it should be fine
My name is not Jack
jackhammer is offline   Reply With Quote
Old 01-23-2007, 12:40 PM   #4 (permalink)
lover of everything Greek
Linebckr49's Avatar
Drives: 93 3000GT base
Linebckr49 is an unknown quantity at this point
Originally Posted by DigiiManDan3KGT
The clutch and flywheel had about 8,000 miles on it.... I dont trust the flywheel any more, It could be warped. This sucks that flywheel is god damn expensive. The clutch was in GREAT shape. It barly had any wear on the meat. I'm so mad that was over 1k$ worth of damage.
unfortunately, i think he already spent the money and got it all fixed. $1,000 is a LOT of money. this was probably your daily driver, but in the future, there are many of us here on 3Si that can help you out to save you many unnecessary expenses. you could pick up a used stock tt flywheel for probably $50 here.
93 3000GT base
K&N | plenum spacer | 3SX Long Tube Headers | testpipe | 3sx lightened crank pulley| Addco front/rear sway bars (3SX) | RVM rear strut bar | front 3-point strut bar (by JonVr4) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (TRE) | H4 conversion | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Linebckr49 is offline   Reply With Quote
Old 01-23-2007, 12:48 PM   #5 (permalink)
Trader Rating: (7)
wow 3si is a piece of crap. the browser timed out and i had no idea that this thread was even up. damnit here are the other pictures.
I wasted my entire 20 minute break at work trying to make 1 EFFING post im so mad. my initial post looks retarded because i didnt finish it.
Old 01-23-2007, 12:49 PM   #6 (permalink)
Trader Rating: (7)
look at what happened.. your not even allowed to upload more then 3 images. Those are all the same image thanks VB!
Old 01-23-2007, 12:51 PM   #7 (permalink)
Verified
jackhammer's Avatar
Trader Rating: (55)
I thought that looked a little suspect
Old 01-23-2007, 12:51 PM   #8 (permalink)
Trader Rating: (7)
last pic of clutch
Old 01-23-2007, 12:53 PM   #9 (permalink)
"The Fisherman"
pyun's Avatar
Trader Rating: (75)
It happend with my HPF disk and my SPEC 3 disk actually.
Old 01-23-2007, 12:53 PM   #10 (permalink)
Trader Rating: (7)
Its not my Daily.. I have a saturn for that. Crappy 1995 SL1 I ride in un-style.
I havent spent the money yet. I just figured that would be the cost of a new clutch and flywheel.
I still have a perfectly good stock clutch and flywheel. I just hate down grading my car.
