#41 (permalink) |
AEM Veteran
What was your ignition timing like around the point of failure?
Years ago, I tore a rod in half on my stock engine (stock rods, pistons, turbos, etc). I was using an AEM, full-blast 9B turbos, and spraying a TON of pure methanol (around 1000cc/min). The car was pulling smooth and clean when suddenly it felt like it hit a wall. Turns out that a rod had twisted 90 degrees and then sheared apart, splitting the piston in half. The ring lands on the piston were intact and the piston face didn't show signs of significant detonation. Later looking at the log of the failure, the knock sensor didn't show even a hint of knock until it went nuts from the half-rod hitting the block over and over. Just before this, I saw a huge spike in MAP and AIT - it pegged the MAP sensor, and AIT went up to something like 100+ degrees at the same time. A harddrive crash lost the log. ![]() My theory on the failure cause? The waste spark lit off the methanol charge in the intake manifold. If ignition timing is LESS than 16 degrees BTDC, then the waste spark will occur AFTER the intake valve on that cylinder has started to open, potentially exposing the intake charge to the spark. If it's open enough...BOOM. Here's a diagram of the stock cam timing to illustrate (courtesy of Jeff Lucius's always excellent stealth316.com): ![]() - Brian
Brian Geddes
'94 Danube Blue VR-4 Replacing everything that moves. '94 Pearl Yellow VR-4 It's dead, but its drivetrain lives on! |
#42 (permalink) | |
Supporting Vendor
#43 (permalink) | |
Ignition timing just before the event was 11*.
#45 (permalink) | ||
AEM Veteran
You're exactly right that increasing your base fuel pressure and leaning out a notch would increase timing. My solution has been to use a 50/50 water-meth mix. You still get fantastic cooling and some extra fueling, but the mixture doesn't seem to be ignitable. Reading the old WWII research papers, this is the mixture that they found to yield the best knock suppression results. |
#46 (permalink) | |
If your theory is correct, then you`d think spark blow out would also be able to cause this sort of phenomenon. When the spark `blows out` it would leave a loaded cylinder, which would be burnt by the wasted spark. If this is the case, then I`m wondering why we don`t see this happening more often.
I apologize, my apostrophe key is broken, hence the ```` |
#47 (permalink) | |
Supporting Vendor
#48 (permalink) | |
AEM Veteran
First, methanol ignites much more easily that gasoline, I believe. Secondly, in your "blowout" scenario, by the time the intake valve opens most or all of the unburned fuel/air mixture will have already been pushed out the exhaust port. Third, with methanol injection your entire intake plenum is filled with methanol mist. It's when the flame carries back from the intake valve into the plenum (and back down into other cylinders on their intake stroke!) that you get into trouble. With normal gasoline injection, the fuel is sprayed directly at the back of the intake valve, so this isn't a possibility. Last edited by FWombat : 07-16-2008 at 11:45 AM. |
#49 (permalink) |
I understand what you are saying, but I have a hard time believing it is just a coincidence that I had a number of these strange backfire type events in the days prior to the failure (I even had one occur the day before while in 1st gear). The way those backfire events felt, I`m sure they had enough punch to crack a piston. Similar to fuel cut they were able to stop my car dead in its tracks at WOT, except this definitely wasn`t fuel cut.
#50 (permalink) |
From what I`ve found tuning for fixed rate methanol injection 2nd gear is useless, I logged my car on a few 1/4 mile runs and 3rd gear was leaner than 2nd for some reason.
I suggest the first time you get on it after a tune you keep a beady eye on the AFRs in the higher gears. I`m building an audible warning circuit for when afr`s drop leaner than 11.5:1 with meth active, this will also kill the boost controller.
JDM GTO TT, Emanage Blue - 450`s Hotwired Walbro - Gutted MAS - K&N Blitz SSBC - Aquamist Water Injection |
