#31 (permalink) | |
1992 Stealth RT/TT:
#32 (permalink) |
Wanted: Traction Problems
he had them flow checked
PTE 780cc injectors for sell
++++++++++JUNE 2007 RIDE OF THE MONTH+++++++++++ ![]() Slideshow1..........Slideshow2..........My Photobucket..........My ImageStation.........MOD LIST Questions about the silver car?.....Rear message board info.....Turbo oil cap info.....nicest ass |
#33 (permalink) | |
Sleeper VR-4
Tommy
#34 (permalink) | |
July 2003
I've been driving a fully forged bottom end for the past 4-5 years (since I was forced to rebuild due to a stupid local shop spinning a bearing on my car from joyriding in it WITHOUT my permission when I took the car in for some suspension part replacements ).I have ZERO piston slap with the off-the-shelf Ross 6g72 pistons when cold and I daily drive this car even through the winter. When I took the block to get it machined, the shop called me back and asked me if I intended to run nitrous on the car. I said no and asked why. They said they bore for looser tolerances for nitrous due to the higher temps (and resultant piston expansion). Since I wasn't going to run nitrous, they called Ross and checked what the allowable tolerances were and bored to that (OTS Ross pistons require an overbore anyway due to being 93mm IIRC). Max
1994 3000GT VR-4. Hobbies... what are hobbies? Oh, those things people do when they're NOT working on their cars?
#35 (permalink) | |
Forest Gump
The bottom line is really I don't see a point in running forged pistons with stock rods or even if you are under 500AWHP or so. Sure, there are ancillary benefits such as cooler running pistons, maybe slightly less prone to detonation, etc, but as far as straight durability and reliability I don't see the benefits. Most of the rebuilds I see blown up on here are the people who went stage 3 everything as soon as their stock motor wore out. Too many people feel the need to upgrade when they really just needed new or rebuilt factory items.
![]() Power: DSM 13G/DR650 Combo, DSM 450 cc bluetops MAXED out, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback, no cats, DN Y-Pipe, Polished Plenum and Valve Cover, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, AWS Delete Drivetrain: RPS Street Max, M.W. 300m O/S Etc: Roller Bearing Short Shifter Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings. JEDI MASTER SAFC NARROWBAND BASED TUNER, LORD OF THE DANCE ALSO |
#36 (permalink) | |
If it is possible to crack a piston without breaking it and then being able to limp around on it for a week, only to have it fragment later while at full boost, then perhaps I can lay blame on the check valve solenoid of my meth kit. Approx. a week before this fateful event, the valve seized which resulted in the worst knock I have ever seen, ie. 24 counts x 6 - 7 data points (in 1st gear). I later repaired the valve (it just needed to be loosened off 1/2 a turn), only to have the motor frag. on my first WOT run after the repair. As far as finding a new motor, the deal for $1700 turned out to be too good to be true... bit of a mixup between myself and the seller. Back to the drawing board. Really need to figure out where I'm going to go with this car and where I am going to find the cash. Maybe I'll try the bank for a line of credit. lol. ![]()
#37 (permalink) | |
Supporting Vendor
#38 (permalink) |
Supporting Vendor
PS. i think dex found the culprit to his engine failure guys. A piston is just like anything that can crack. Say you have a glass vase. And it cracks. The vase can remain in tact cracked fro some time, but the more you handle it, the more prone it is to coming apart where it cracked. I think a stock motor would be fine for your dex as long as you dont have your nozzle sticking again
#39 (permalink) |
I got working on pulling the motor today. The motor is _nearly_ ready to come out, just need to get my hands on a cherry picker, which won't be possible until this weekend.
One thing I was't sure what to make of was the fact that when I drained my oil, there was more coolant in my oil than there was oil in pan. In addition, there was fair sized chunk of metal that became lodged in the drain hole. |
#40 (permalink) |
Not sounding good at all. Blown head gasket and probably that one piston has a hole in it.
----------------[2007 Ride of the Year
![]() "Stroke" her I did. Retired - TD04 WRX19t's = 513awhp @ 18psi on PUMP ![]() |
