#21 (permalink) | |
TEXAS!! FIGHT!!
Forget the upgraded heads. You can always upgrade the heads later. It's a 1-2 day job with the engine IN the car. You can have the damaged combustion chambers in your current heads welded and ground smooth or you can get some parts-car heads and transplant some of the components from your heads onto them. Either way, I wouldn't spend more than $1000 total on your "new" heads. What makes you say there is excessive transaxle backlash? You have a 5 speed, don't worry about the transaxle reinforcement. My bell housing is still not reinforced (although I might be regretting that soon). It's the 6 speeds that split them apart at your power levels. The RPS 6 Puck is pretty good, but I remember hearing that IPS is selling a clutch that supports around the same power for around the same cost. I'd contact Jeff because a lot of people have issues with the RPS 6 puck. Take your time on this decision. With rebuilt heads (new valve stem seals) and a new bottom end, your 120k would be limited to only: new oil pump, new water pump, new timing belt, new timing belt pulleys. Good call on the beater. 1) Actually, yes. The machine shop would undoubtedly recommend a slight over bore, so the machine shop costs would be significant. 2) 1G stock pistons are actually stronger than 2G's. The 1G's actually have a thicker upper ring land. How old is your knock sensor? Had it seems dependable in the past? Mine has never let me down and always produced knock counts when I expected it. Since you have E16G/DR800 dreams, stock pistons would be unwise, but stock rods will be unwise as well. It might be time to sit back and really contemplate what you want out of this car and what you can afford. I'd set-up a spread sheet to analyze all of your options.
PEARL WHITE '93 VR-4 // Under Construction. Looking forward to lighting up the drag radials
E16G's: 10.573 @ 135.01 (Trevor owns me )E16G's: 11.28 @ 124.7 (Pure pump gas ET record )14B's: 11.10 @ 127.3 (AWD 14B ET record. Take THAT, Trev! 9B's: 12.78 @ 107.1 Congrats to the current top 10 members!! DynamicRacing: US 3S Top 10 Fastest List |
#22 (permalink) | |
The Merkel shortblocks are definitely reasonably priced and they would be ideal from a performance standpoint. I'll talk with Jeff tomorrow am to see what the deal is with the core charge.
The other option is a used 4 bolt longblock that comes with DR stage2 heads for $1700. This seems like the most economical option for getting my car going quickly. However, I would really like to upgrade the bottom end, as I really don't want to have to do this all over again if/when I go bigger turbo. Then again, pulling the motor to add some DR800's/E16G's is probably easier than doing the "in-car" install and maybe I could upgrade the bottom end at that time? I'm bored of my maxed out DR650R's and I would like to move up to something bigger, problem is I just can't do it all in one shot. I have an awful clunking, not only when shifting, but also when cruising at low speeds at <2000 rpm that causes the car to jerk violently back and forth. I have replaced my rear dif (everything is within spec), carrier bearings, double checked lash in the transfer case, had new VCU dowel pins made (to take up the slack in the 18 spline VCU holes), installed solid rear dif. bushing and solid motors mounts and I still have a horrible clunking. It has gotten slightly better after all of these mods, but it is definitely still there. I took my car into the dealer and they confirmed that the only place I have an excessive lash is from within the transaxle. Plus, there definitely has to be something wrong with the transaxle (even though it shifts great). At <2000 rpm I can hear this strange metal on metal noise, similar to lightly touching metal to a grinding wheel, that tells me something is definitely amiss. Quote:
I have a broken ear on the bell housing that came off with very minimal force and I was thinking I might have them weld on some sort of reinforcment plate while they are repairing the ear. I believe it was the original (17 year old knock sensor). Up until this event it always seemed reliable for detecting knock, but I did have an issue with phantom knock at cruise in the 2600 - 3500 rpm range, which I never could figure out. Maybe its related?
#23 (permalink) |
If you have the room to store your car, buy a beater and take your time with the rebuild. That way you won't have to put every penny into the car to get it running and you can still enjoy life.
There's some good deals in the for sale section if you have patience. Good luck. |
#24 (permalink) | |
#25 (permalink) |
No beater then.....a set of new Wisco forged pistons with rings about $650.00. Slight overbore and hot tank the block about $200.00. Rebalance the rotating assembly assuming you have a good useable crank about $275.00.
Resize the stock rods with new ARP bolts around $300.00. Or...a new Mitsu shortblock with cast pistons, around $2700.00. Hey, I'm getting fat and losing some hair, married, had kids AND have the mini van! But I also have my toys yet, lol. Last edited by 1stStealthN/A : 07-13-2008 at 07:30 PM. |
#26 (permalink) | |
Forest Gump
In my mind run stock bottom end or upgrade both pistons and rods. I've had enough detonation to melt a spark plug on this car and still at 145K miles it has great compression. I'd rather not have the piston slap that forged engines have when they are cold.
![]() Power: DSM 13G/DR650 Combo, DSM 450 cc bluetops, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback, no cats, DN Y-Pipe, Polished Plenum and Valve Cover, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, AWS Delete Drivetrain: RPS Street Max, M.W. 300m O/S Etc: Roller Bearing Short Shifter Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings. Looking for 2nd gen Stealth or 3000GT rear bumper my sideskirts and door caps for sale, PM me. |
#27 (permalink) |
I talked with Mike @ IPS (Jeff is on holidays) and he said that the core cost is not included in the price of the shortblocks.
In addition, if I wanted a forged crank I would have to pay for the cost of the crank and I'd have to pay to repair any damage to my block. I have a feeling this would increase the cost dramatically, so it looks like I'm just going to go with the used longblock for the time being. With regards to the clutches, he said that the Southbend > RPS clutches and I'll be getting the low down on their whole line up later this afternoon. Its a really nice day out today, so I'm going to screw off to the lake for the day. Will look at pulling the motor tomorrow as the forecast is calling for rain. |
#28 (permalink) |
Broken ring land, been there myself. If your on a budget you can probably get away with replacing that one piston, quick hone and be done with it. If your lucky nothing happened to you heads and/or turbo's.
----------------[2007 Ride of the Year
![]() "Stroke" her I did. Retired - TD04 WRX19t's = 513awhp @ 18psi on PUMP ![]() |
#29 (permalink) |
Wanted: Traction Problems
do you have 2 EGT probes or just 1?
was it reading #3? I dont get this, this probably wasn't caused by too much power, and it sounds like your tune was rich enough. Plus IIRC the Meth should have helped with knock and lowered EGT's. So what was the cause? could #3 just have not received the same fuel as the others and just ran lean? this scares me...Im about to run 6 EGT probes, if I can figure out a way to do it.
++++++++++JUNE 2007 RIDE OF THE MONTH+++++++++++
![]() Slideshow1..........Slideshow2..........My Photobucket..........My ImageStation.........MOD LIST Questions about the silver car?.....Rear message board info.....Turbo oil cap info.....nicest ass |
