Old 07-10-2008, 09:27 AM   #31 (permalink)
MI SCUZI! MI SCUZI!
NeoValentine's Avatar
Drives: Twin Turbo SL
Trader Rating: (43)
NeoValentine Level 4NeoValentine Level 4NeoValentine Level 4NeoValentine Level 4NeoValentine Level 4
Default Re: Car still having issues. p0300 p0173
NEW ECU INSTALLED AND!!!!! still getting the fucking code... So not happy...
R.I.P. Beastly-SRT 2/21/08 9:04AM-2/21/08 2:27PM
NeoValentine is offline   Reply With Quote
Old 07-10-2008, 09:34 AM   #32 (permalink)
Boost Happy
Black_Sunshine's Avatar
Drives: a japanese dodge
Trader Rating: (70)
Black_Sunshine Level 7Black_Sunshine Level 7Black_Sunshine Level 7Black_Sunshine Level 7Black_Sunshine Level 7Black_Sunshine Level 7Black_Sunshine Level 7
any way to log your car?
Black_Sunshine is offline   Reply With Quote
Old 07-10-2008, 09:59 AM   #33 (permalink)
MI SCUZI! MI SCUZI!
Trader Rating: (43)
I have a data logger that logs about 90 seconds... Seeing as this happens so randomly hard to pin point when to turn the logger on and get the code.
Old 07-10-2008, 12:05 PM   #34 (permalink)
Boost Happy
Trader Rating: (70)
try reinstalling the 360's and remove the safc.
Old 10-10-2008, 10:17 AM   #35 (permalink)
MI SCUZI! MI SCUZI!
Trader Rating: (43)
I did a full check of the CAS and timing and it was all spot on... I guess my last resort is the MAF. Any one else got any ideas on why I'm getting this damn misfire code?
Old 10-10-2008, 01:12 PM   #36 (permalink)
3SNY - HondaTurtleFTW
FluffyCow's Avatar
Drives: 91 ES, 91 R/T TT
FluffyCow Level 7FluffyCow Level 7FluffyCow Level 7FluffyCow Level 7FluffyCow Level 7FluffyCow Level 7FluffyCow Level 7
Put your car as back to stock as possible and see if it still happens. If worst comes to worst, start methodically with everything you HAVEN'T changed and work from there. Switch out the injector harness, then your maf, etc. I'm fairly certian you'll find that it has to do with your SAFC not working right.
1991 Dodge Stealth ES
- The car that started the 3S obsession
Mods: Open air filter, "resonator" bottle removed, first-gen VR-4 rims.
1991 Fiji/Mystic Blue R/T TT 1 of 235(paint/R/T TT only, can't find more info, VIN is a 1 of none number)
mods: RPS full face clutch, Fidanza flywheel, ATR downpipe, TurboXS dual stage boost controller, K+N fipk, Turboxs h34 bov, Kormex 25 spline, recall transfercase. 180k service done thanks Clint. Soon: water/meth injection
1987 Dodge Ramcharger - The back-up plan. Mods: Non-computerized timing, custom white gauge faces and red LED illumination, cat-back straight pipe, Chevy seats, Ford running boards, and Mopar everything else.
FluffyCow is online now   Reply With Quote
Old 11-13-2008, 10:16 AM   #37 (permalink)
MI SCUZI! MI SCUZI!
Trader Rating: (43)
I put back in the 360CC injectors and the SAFC-2 is 0'd out, it's still throwing the code, should I remove the SAFC2 from loop completely? It's currently inline using a boomsland harness.
Old 11-13-2008, 10:45 AM   #38 (permalink)
Boost Happy
Trader Rating: (70)
yeah, i'd take it out.
Old 11-14-2008, 08:05 AM   #39 (permalink)
MI SCUZI! MI SCUZI!
Trader Rating: (43)
Ok I'll pull it tonight, any other thoughts from others out there please? I'd like to get rid of this issue so I can smog my car and drive her again, before I get mad and sell her.
Old 11-14-2008, 08:12 AM   #40 (permalink)
Forum user
donniekak's Avatar
Drives: 92rt/tt
donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7
Double post ftl.
donniekak is offline   Reply With Quote
