Cant Install Fuel Pump - 3000GT/Stealth International Message Center
Old 04-14-2012, 06:19 PM   #1 (permalink)
Drives: 1994 Stealth TT
DodgeStealth is an unknown quantity at this point
Feedback Score: 0 reviews
Default Cant Install Fuel Pump
Hey guys i got everything ready to install fuel pump, arc 2, hotwire kit but the problem was i got in the back and couldnt unhook the fuel line from the sending unit!! It was rusted and or stuck. I sprayed some pb blaster on there let it sit, still nothing, almost bent the metal line off. Any tips on getting the dang thing off?
DodgeStealth is offline   Reply With Quote
Old 04-14-2012, 06:23 PM   #2 (permalink)
3000GST VR2?
Thump`Master's Avatar
Drives: Yes
Thump`Master is an unknown quantity at this point
Feedback Score: 14 reviews
Default Re: Cant Install Fuel Pump
I can tell ya what I did... lol I cut the hard line and spliced it with some rubber FI hose.
Thump`Master is offline   Reply With Quote
Old 04-14-2012, 07:01 PM   #3 (permalink)
AF Medic
NickS VR4's Avatar
Drives: 01 Eclipse GT,94 VR4
NickS VR4 is an unknown quantity at this point
Feedback Score: 5 reviews
I know i'll be tackling this soon, but have you tried ATF & Acetone mix?
Mitsubishi ASA Price List
1994 VR4 3000GT #2 - Under Restoration
2001 Eclipse GT
2005 Civic EX SE - Totalled
1994 VR4 3000GT - Sold
NickS VR4 is online now   Reply With Quote
Old 04-14-2012, 07:33 PM   #4 (permalink)
Curmudgeon
Steve '93ES's Avatar
Drives: '92 ES, '92 TT
Steve '93ES Level 2Steve '93ES Level 2Steve '93ES Level 2Steve '93ES Level 2
Feedback Score: 1 reviews
That's because it doesn't disconnect there!
Neither the hose fitting, nor the "fitting" on the end of the pipe spin. Neither end of the hose spins like a garden hose. You have to get under the car and disconnect the other end of the hose from the hard line just forward of the tank. Once you do that then you can pull the pump assembly, hose and all, out of the tank and put it on a bench were you can get some support on the pipe and turn the hose off the fitting.
Keep in mind that only the small nut on the hard line spins. You need to hold the hose end still with a wrench and spin the hard line nut off. Use a flare nut wrench or you'll destroy the nut. You'll also want to spray down the nut with PB, that bastard's on there tight and years of road crap make it even tougher to get off.
While you have the hose off you might want to find a place that makes hydraulic hoses and ask them to re-build it. They won't have the fittings but with a little coaxing they can cut off the barrel crimps and replace the 20 year old rubber using new crimps and the old fittings.
Good Luck!
Steve '93ES is online now   Reply With Quote
Old 04-14-2012, 07:39 PM   #5 (permalink)
gs1000kat's Avatar
Drives: 92 RT/TT,99 VR4
gs1000kat is an unknown quantity at this point
Feedback Score: 80 reviews
Good Luck!
^This. Everything else working out?
"I never knew I could drive like that. I was going faster than I've ever gone before, and yet, it all seemed to be happening in slow motion. I was seeing three and four moves ahead, weaving in and out of lanes like an Olympic skier on a gold medal run. I knew I was challenging the very laws of physics."
gs1000kat is online now   Reply With Quote
Old 04-14-2012, 08:51 PM   #6 (permalink)
Haven't tried to install anything else yet, i was bummed out when i couldn't figure out why i couldnt get the fuel line off. Now i know lol.
Old 04-14-2012, 08:58 PM   #7 (permalink)
gs1000kat's Avatar
lol..Yeah, it's a bit tricky, but once you now the trick it's not too bad. I did the same thing the first time I changed out a fuel pump. I'm sure a lot of people have.
Old 04-14-2012, 09:41 PM   #8 (permalink)
andronitrate's Avatar
Drives: 97 vr4
andronitrate is an unknown quantity at this point
Feedback Score: 3 reviews
had same problem when i went to install my fuel pump, apparently my hatch was leaking and water sat on top of tank, had to visit a junk yard and get a tank that was useable.
funny gif Pictures, Images and Photos
andronitrate is offline   Reply With Quote
Old 04-14-2012, 10:45 PM   #9 (permalink)
BrianWSNC Level 1BrianWSNC Level 1
I cut my line and replaced it too. OEM replacement hose is close to 100.00 bucks
BrianWSNC is offline   Reply With Quote
Old 04-14-2012, 11:23 PM   #10 (permalink)
Curmudgeon
hydraulic hose guy was <$20....
