Old 09-09-2008, 10:42 AM   #1 (permalink)
luvs spyda gal
DuTTch's Avatar
Drives: 2nd gens w/o hoops
Trader Rating: (64)
DuTTch Level 7DuTTch Level 7DuTTch Level 7DuTTch Level 7DuTTch Level 7DuTTch Level 7DuTTch Level 7DuTTch Level 7DuTTch Level 7DuTTch Level 7DuTTch Level 7
Default brick parking lot - oil
Anybody any suggestions how I can clean up the oil stains from cars in my brick parking lot at the hotel. they are starting to show real bad.
thx for the input
DuTTch is offline   Reply With Quote
Old 09-09-2008, 10:53 AM   #2 (permalink)
soccermania688's Avatar
Drives: 1993 Mitsu 3000GT Sl
soccermania688 Level 1soccermania688 Level 1
Default Re: brick parking lot - oil
found this: How to Clean Driveways | Garage and Driveway
just type in google to find more suggestions
Photobucket
soccermania688 is offline   Reply With Quote
Old 09-09-2008, 10:55 AM   #3 (permalink)
Grandpa
EVILTWIN's Avatar
Drives: 07Accord, 03 C5 ann.
EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7
Brake Cleaner will remove grease stains from clothes, carpet etc.
Probably work on brick too. But id test a small area that is hard to see first to see if it removes any color from the bricks.
Set the gearshift, for the high gear of your soul.
Chuck Norris can win a game of Connect Four in THREE MOVES
I'm an Equal Opportunity Annoyer!
EVILTWIN is offline   Reply With Quote
Old 09-09-2008, 11:14 AM   #4 (permalink)
Forest Gump
cbehnken's Avatar
Drives: 1992 Stealth TT
cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7
yep brake cleaner is the best.
Power: DSM 13G/DR650 Combo, EVO 560cc injectors, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback,
no cats, DN Y-Pipe, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead 8.07 @ 85.55 1/8th mile 1.84 60FT
Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, AWS Delete
Drivetrain: RPS Street Max, M.W. 300m O/S, Seattle F&R Poly Mounts
Etc: Roller Bearing Short Shifter Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit
Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing/sideskirts/doorcaps
Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings.
Mobile 1 10w40, Redline MTL in trans, 85w90 Coastal GL5 in transfer case and rear
cbehnken is offline   Reply With Quote
Old 09-09-2008, 12:29 PM   #5 (permalink)
Master of the Universe
ulrich's Avatar
Drives: with head out window
Trader Rating: (9)
ulrich Level 7ulrich Level 7ulrich Level 7ulrich Level 7ulrich Level 7ulrich Level 7ulrich Level 7ulrich Level 7ulrich Level 7ulrich Level 7ulrich Level 7
Take the bricks out and flip them upside down
1997 3000GT VR4
ulrich is offline   Reply With Quote
Old 09-09-2008, 12:40 PM   #6 (permalink)
Hates Gravel
sublime_whatigo's Avatar
Drives: reliable car (nissan
Trader Rating: (24)
sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7
If all else fails a decent pressure washer always does the trick.
92 3000GT VR4
Black Wheel Mafia - Member 002
Matt
sublime_whatigo is offline   Reply With Quote
Old 09-09-2008, 01:34 PM   #7 (permalink)
GTONW is good to go
Colt45_GTO's Avatar
Drives: Black '91 TT
Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7
perfect!
Colt45_GTO
Semper Fidelis
go register at www.gtonw.co.uk
Originally Posted by Stealthee View Post
Seriously. Just like people will talk down to you when you post about getting a ticket.
People on here need to learn when to shut the fuck up and stop being hypocritical.
Old 09-09-2008, 01:40 PM   #8 (permalink)
boosted
gipper72488's Avatar
Drives: 1990 gsx eclipse
gipper72488 Level 7gipper72488 Level 7gipper72488 Level 7gipper72488 Level 7gipper72488 Level 7gipper72488 Level 7gipper72488 Level 7
thx for the input
Fix the oil leak
lol brakecleaner should do it, maybe purple power
I <3 booost. 90gsx. 3inch turbo back magnaflow exhaust,K&N, shortshifter, stage 2 clutch, mbc at 16psi
gipper72488 is offline   Reply With Quote
Old 09-09-2008, 01:42 PM   #9 (permalink)
Banned from Classifieds
smokinvr-4's Avatar
Drives: Smokinvr4@hotmail
Trader Rating: (100)
smokinvr-4 is an unknown quantity at this point
brick is pourous, it absorbs some stuff. They actually make an acid based cleaner you can get at home depot that is specifically made to clean brick.
smokinvr-4 is offline   Reply With Quote
Old 09-09-2008, 03:52 PM   #10 (permalink)
luvs spyda gal
DuTTch's Avatar
Trader Rating: (64)
thanks for y'alls responses
