Old 07-04-2008, 11:28 AM   #1 (permalink)
TurboVR4's Avatar
Drives: 1995 VR-4
TurboVR4 is an unknown quantity at this point
Default Brake Squeal
Okay I've reinstalled my pads twice and my brakes still squal worse than ever. Front ceramic, rear semi-metalic. Can someone tell me what I'm doing wrong?
The rear pads had two shims installed initially and I put them both back on when I replaced the pads the first time(I applied brake-quiet gel in between the pads and shims). Does the brake-quiet stuff go btwn the pad and shim, or btwn the back of the shim and brake piston?
I removed the smaller shim to see if that helped, but it did not. Should I continue to use both shims in the rear, or just the larger one that covers the whole pad?
And what about the rubber around the caliper pistons - should I clean or apply lithium grease around those seals?
'95 VR4: Billet grill, K&N FIPK, short throw shifter, MBC, Greddy BOV, Syncromesh fluids, HHH Logger. .
TurboVR4 is offline   Reply With Quote
Old 07-04-2008, 12:10 PM   #2 (permalink)
resident evil
wraith's Avatar
Trader Rating: (16)
wraith Level 2wraith Level 2wraith Level 2wraith Level 2wraith Level 2wraith Level 2
Default Re: Brake Squeal
I use Permatex brake quiet in a spray can and all the shims and I spray the back of the pad and the shims. Have you bed the brakes in? Sometimes the bed in compound on the pads squeal until you burn it away.
wraith is offline   Reply With Quote
Old 07-04-2008, 04:39 PM   #3 (permalink)
TurboVR4's Avatar
Drives: 1995 VR-4
Yeah, the pads have about 1k miles on them. . . Any suggestions?
Old 07-04-2008, 05:09 PM   #4 (permalink)
Profesional Insomniac
veerfour05's Avatar
Drives: 93 VR4
veerfour05 is an unknown quantity at this point
Did you just replace pads or did you do anything with the rotors.
veerfour05 is offline   Reply With Quote
Old 07-04-2008, 06:16 PM   #5 (permalink)
TurboVR4's Avatar
Drives: 1995 VR-4
I installed new rotors and pads together about 1k miles ago. They seemed fine at first, but have been squeaking for the past 6 months or so. .
Old 07-04-2008, 06:19 PM   #6 (permalink)
Member
massstealth's Avatar
Drives: 06 Camry
Trader Rating: (16)
massstealth is an unknown quantity at this point
you might have to chamfer all the edges of the brake pads. The harsh right angle can make noise.
Bob
Rear ended by homeless drunk driver July 12 04
Please wait 13 seconds..
RPS full face clutch, Fidanza flywheel, ATR downpipe, TurboXS dual stage boost controller, K+N fipk, Turboxs h34 bov, Kormex 25 spline, recall transfercase. 180k service done thanks Clint. Soon>>>Hotwire + fuel pump, water/meth
Image hosted by Photobucket.com
SOLD
Now driving 38mpg Escort
massstealth is offline   Reply With Quote
Old 07-05-2008, 11:01 AM   #7 (permalink)
TurboVR4's Avatar
Drives: 1995 VR-4
Is it a good idea to put lithium grease around the rubber seal surrounding the brake piston? That rubber gasket looks a little worn. . I was concerned about spraying brake cleaner on it for fear it would only wear it out faster - thought?
Old 07-05-2008, 07:28 PM   #8 (permalink)
Member
Drives: 06 Camry
Trader Rating: (16)
I wouldnt put anything on the boot. Would just attract dust. Best to just spray brake parts cleaner.
