Bought the $3k high mileage VR4 .... pls help - Page 4 - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 02-17-2017, 09:46 AM   #31 (permalink)
under the knife again
Spankytaco's Avatar
Drives: 93w92engineFWDATX
Spankytaco is an unknown quantity at this point
Feedback Score: 4 reviews
Default Re: Bought the $3k high mileage VR4 .... pls help
If its not a DD fix it man. Looks clean.
Where is the car at?
Spankytaco is offline   Reply With Quote Quick reply to this message
Old 02-17-2017, 10:13 AM   #32 (permalink)
StealthyRT's Avatar
Drives: 92 RT/TT & 91 SL
StealthyRT is an unknown quantity at this point
Feedback Score: 10 reviews
Seriously, a rebuild CAN be done for cheap if you are not planning on building a monster.
1.You can get refurbished forged cranks for 300
2.and then just get a set of used pistons/rods for 150.
3.Gaskets, fluids, bearings 200
4.Timing belt stuff 200
5. Oil pump 150?
We are looking at about 1000 max, and honestly it would be fine.
I rebuilt the spun bearing motor on the SL I bought for 600 and it runs great.
-Shane
1992 Stealth TT
Rebuilt Motor, Test Pipe. Obx Down Pipe, Gutted Pre-Cats, Poly Mounts, EGR delete, Walbro 255, Greddy type-s, Profec B spec II, Tein S-Tech Springs, 3sx Pre Turbo Pipes, B&M 11x10 Oil Cooler, 99 Lifters, Forged 93 Crank, 3sx lightweight pully, GM 3" maf w/ MAFT, 98sl Flashable ECU, 550cc Delphi Injectors
1991 3000gt SL ATX swapped to MTX
Rebuilt Motor, 99 Lifters, Prothane Engine mounts, Test Pipe, 3SX STS, ̶t̶r̶a̶n̶s̶l̶a̶b̶ ̶s̶h̶i̶f̶t̶k̶i̶t̶, TT Plenum, intake resonator delete, 3SX Light Weight Flywheel, TT 1G Brakes, Clutch Damper Delete, Eibach 2810.140 ECS Lowering Springs
2003 SVT Focus - SOLD FINALLY
WTB:
StealthyRT is offline   Reply With Quote Quick reply to this message
Old 02-17-2017, 11:16 AM   #33 (permalink)
Drives: 1992 3000GT VR4
Fawnzee92 is an unknown quantity at this point
Feedback Score: 0 reviews
Default
Never heard of rod knock going away at higher rpm, always just got louder for mine
Fawnzee92 is offline   Reply With Quote Quick reply to this message
Old 02-17-2017, 11:49 AM   #34 (permalink)
AlexxRyzhkov is an unknown quantity at this point
Feedback Score: 1 reviews
5. Oil pump 150?
I do want to make more power, although I'm not sure whether I should consider building it out or just running stock internals. Part of me wants to save up a ton of money and build the motor to run 600+ whp. But realistically I'll probably just do a stock rebuild if the block is in decent shape
Edit: one of my mechanic buddies looked at it and said it was "definitely spun a bearing". ehhh
AlexxRyzhkov is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
