Bought the $3k high mileage VR4 .... pls help - Page 2 - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 02-04-2017, 03:00 PM   #11 (permalink)
AlexxRyzhkov is an unknown quantity at this point
Feedback Score: 1 reviews
Default Re: Bought the $3k high mileage VR4 .... pls help
Alrighty, so here's some pics:
Engine bay is pretty meh
Ghetto air intake, gonna buy a K&N filter
Something blocked off, what's this for? Also the coolant resevior is empty and the line to radiator is disconnected
Not good lol
Anyone know what this is for?
Pulled the ECU, seems to be fine. No leaks, no smells
AlexxRyzhkov is offline   Reply With Quote Quick reply to this message
Old 02-04-2017, 06:28 PM   #12 (permalink)
3SNY - HondaTurtleFTW
FluffyCow's Avatar
Drives: 92 VR-4
FluffyCow is an unknown quantity at this point
Feedback Score: 11 reviews
I forget where that pre turbo pipe line goes. Mine was blocked off with a bolt covered in sealant
Sent from my SM-G935P using Tapatalk
1991 Dodge Stealth ES
- The car that started the 3S obsession
Mods: Open air filter, "resonator" bottle removed
1991 Fiji/Mystic Blue R/T TT 1 of 235(paint/R/T TT only, can't find more info, VIN is a 1 of none number)
Sold 6/19/11 to my923ksl
1992 silver VR-4 - 1 of 152 identical
Show: 99 Sails, 99 rear garnish, 2nd-gen steering wheel, Kaze exhaust cover, Pioneer Premier h/u, aftermarket speakers(Alpine type s's I think), 10 inch JL W1 sub in spnallb corner box.
Go: 15G Turbos, FMIC, ATR DP, ACT clutch, 3-inch singleshot(Currently off car due to bottoming out), no cats, HKS SSQV BOV, PWR rad, Ksport coilovers, 3sx rear adj. control arms, fECU w/ FPR solenoid as BCS, Cianci gauge pod w/ Defi D-series(Boost, EGT, oil pres), 93 shifter.
1987 Dodge Ramcharger - The back-up plan. Mods: Non-computerized timing, custom white gauge faces and red LED illumination, cat-back straight pipe, Chevy seats, Ford running boards, and Mopar everything else.
Wife's ride: 2014 Hyundai Sonata 2.0T --still waiting for permission to mod.
FluffyCow is offline   Reply With Quote Quick reply to this message
Old 02-04-2017, 06:43 PM   #13 (permalink)
Another update, I connect the vacuum line to the Y-pipe, and the other line I ghetto rigged on (I hotglued it.... dont judge). Did some pulls and no stuttering or bogging, but it doesn't seem to pull as hard now. Maybe it was overboosting? or maybe just resetting the ECU is doing that.
Old 02-04-2017, 06:46 PM   #14 (permalink)
Forum user
ga94vr4 is an unknown quantity at this point
Feedback Score: 7 reviews
The preturbo pipe fitting is for the charcoal canister, put a proper plug on it so it does not suck in unmetered air. I would remove that ghetto intake filter reducer and install something proper. That adapter could be causing turbulence inside the already sensitive mass air flow sensor. IIRC that top solenoid is your boost solenoid.
That ecu also looks like it may have had a cap replaced before. Get some better pictures of the throttle body area and the mass air flow sensor area, the back of the plug mainly.
ga94vr4 is offline   Reply With Quote Quick reply to this message
Old 02-04-2017, 07:05 PM   #15 (permalink)
I'll try to get some tonight. Whatever solenoid that was, I probably should order a new one.
Also the transmission is a bit notchy, I've been considering putting some Synchromesh fluid in it, although it seems a bit controversial on here. What are your guys' opinions on this?
Besides that, I've noticed going on/off throttle is a bit jerky. Now this is pretty normal in 1st or 2nd gear, but it's happening in 4th and 5th gear too. Thoughts?
Last of all, why are my turbo's so damn loud. Boost leak? Exhaust leak? My friend's 9bs aren't nearly as loud
Old 02-04-2017, 08:30 PM   #16 (permalink)
se7enisninja's Avatar
Drives: 92 3000gt vr4
se7enisninja is an unknown quantity at this point
Feedback Score: 2 reviews
Your car probably has wicked boost leaks based on the pics I've seen. Looks like someone did some parts of a vacuum delete such as the missing charcoal canister. My turbos screamed like a banshee from one of my boost leaks but I'm worried because your wastegate lines were disconnected from the turbo. Could've overboosted and caused some damage.
se7enisninja is offline   Reply With Quote Quick reply to this message
Old 02-04-2017, 08:31 PM   #17 (permalink)
I'm quite partial to redline driveline fluids. My transmission shifts buttery smooth.
Old 02-04-2017, 08:43 PM   #18 (permalink)
Yeah it does worry me about the boost leaks, I'm definitely getting a boost leak test done ASAP
Old 02-04-2017, 09:03 PM   #19 (permalink)
^^My name is April^^
dbest671's Avatar
Drives: Spyder VR4/SRT8/CTSV
dbest671 Level 2dbest671 Level 2dbest671 Level 2dbest671 Level 2dbest671 Level 2dbest671 Level 2
Feedback Score: 92 reviews
the vacuum line on the back of the y-pipe goes to the waste gates IIRC
dbest671 is offline   Reply With Quote Quick reply to this message
Old 02-04-2017, 09:07 PM   #20 (permalink)
Super Duper Mod
lawdogg's Avatar
Drives: deals
lawdogg Level 3lawdogg Level 3lawdogg Level 3lawdogg Level 3lawdogg Level 3lawdogg Level 3lawdogg Level 3
Feedback Score: 109 reviews
Good - to be extra sure it's good, if you know anyone with the same ECU in their known running car, put it into that car and see if it still runs OK.
Originally Posted by GTO Assassin View Post
Originally Posted by ray pampena View Post
Cant we all just smile and get along?
No!
lawdogg is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
