Bought the $3k high mileage VR4 .... pls help - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 02-03-2017, 10:13 PM   #1 (permalink)
AlexxRyzhkov is an unknown quantity at this point
Feedback Score: 1 reviews
Default Bought the $3k high mileage VR4 .... pls help
Well shiet.
Preface: Car is a 1991 VR4. 180k miles.
Drove the car and the clutch pedal felt like complete ass. My friend's had exact same issue and we had to bleed it and it was fixed. Clutch literally wasn't disengaging even when floored. I said "quick easy fix " and bought. Dude took $3250 for it (with fancy subs and touch screen radio)
We went to Wally world and got some tools/fluid. Bled clutch, lots of air in system, pedal felt amazing. Leaking a ton of something. Probably oil. Start car up, feels like ass again. Still barely disengages. Said screw it and drove it home.
Was driving in 5th, gassed it and when it hit 2.5k RPM it just shook the whole car really hard. Later I was gassing in 2nd and when I hit 5k RPM I heard a "beep" sound and at 5.5k RPMs it just starting stuttering and breaking up. Thanks car. Apparently the weird beep is the clutch check valve?
When gassing in neutral, it revs up and drops down really hard. If you rev it up high enough, it'll literally almost die. Smells like she's burning oil. Checked Y-Pipe and no oil in it, she's dry. VSS?
Turbo's are stupid loud also, maybe a exhaust or boost leak? The whole exhaust looks custom.
Oh and it's got some fancy blow off valve, and literally inside the hose that connects to it and the intake, was a random piece of hose, partially blocking the BOV. Fun. I can't hear the blow off sound... ?
Whatever. Got a VR4 with mint interior, decent exterior, BBS wheels, and a fancy radio for a little over 3k. I excepted issues, and I got issues :/
For real, help me
AlexxRyzhkov is offline   Reply With Quote Quick reply to this message
Old 02-03-2017, 10:53 PM   #2 (permalink)
Forum user
ga94vr4 is an unknown quantity at this point
Feedback Score: 7 reviews
Default Re: Bought the $3k high mileage VR4 .... pls help
Get some pictures of the engine bay, get a video of the issues. It sounds like the motor mounts could be bad and the mass air flow sensor plug is hitting the clutch booster line on the passenger side. BUT that is speculation and a quite common problem.
ga94vr4 is online now   Reply With Quote Quick reply to this message
Old 02-03-2017, 11:19 PM   #3 (permalink)
I will get pics tomorrow, I'll video some stuff but I'm not driving this thing till I get the clutch fixed.
Also I'm confused about the brake/clutch booster. The hose going from intake plenum to brake booster is really badly kinked, and has no check valve? Would this be causing problems?
Also Imma swap the BOV for a stock one and see what happens.
Old 02-04-2017, 07:55 AM   #4 (permalink)
Warzone's Avatar
Drives: 1992 3000GT VR4
Warzone is an unknown quantity at this point
Feedback Score: 3 reviews
For the clutch, the pedal needs adjusted.
This is for a DSM but works the same on a 3/S
as far as the beep though, there is nothing related to the engine or drivetrain that should or would beep in the car.
Your best bet is to return the car as stock as normal as far as things that can affect how it runs. blow off valve, tuners, etc. and start from there.
Get yourself a boost leak tester and perform a boost leak also. That can resolve a world of issues.
1992 GTO SR 240whp N/A "GT3-RS"
1992 Sandstone VR4 Wannabe 400R "GT2"
1987 Chrysler Conquest TSI
Warzone is offline   Reply With Quote Quick reply to this message
Old 02-04-2017, 09:30 AM   #5 (permalink)
3SNY - HondaTurtleFTW
FluffyCow's Avatar
Drives: 92 VR-4
FluffyCow is an unknown quantity at this point
Feedback Score: 11 reviews
https://www.youtube.com/watch?v=vYJxQyjIhUw
It's not a beep per se but it does sound like one when you have the check valve in backwards. I've done that myself.
Sent from my SM-G935P using Tapatalk
1991 Dodge Stealth ES
- The car that started the 3S obsession
Mods: Open air filter, "resonator" bottle removed
1991 Fiji/Mystic Blue R/T TT 1 of 235(paint/R/T TT only, can't find more info, VIN is a 1 of none number)
Sold 6/19/11 to my923ksl
1992 silver VR-4 - 1 of 152 identical
Show: 99 Sails, 99 rear garnish, 2nd-gen steering wheel, Kaze exhaust cover, Pioneer Premier h/u, aftermarket speakers(Alpine type s's I think), 10 inch JL W1 sub in spnallb corner box.
Go: 15G Turbos, FMIC, ATR DP, ACT clutch, 3-inch singleshot(Currently off car due to bottoming out), no cats, HKS SSQV BOV, PWR rad, Ksport coilovers, 3sx rear adj. control arms, fECU w/ FPR solenoid as BCS, Cianci gauge pod w/ Defi D-series(Boost, EGT, oil pres), 93 shifter.
1987 Dodge Ramcharger - The back-up plan. Mods: Non-computerized timing, custom white gauge faces and red LED illumination, cat-back straight pipe, Chevy seats, Ford running boards, and Mopar everything else.
Wife's ride: 2014 Hyundai Sonata 2.0T --still waiting for permission to mod.
FluffyCow is offline   Reply With Quote Quick reply to this message
Old 02-04-2017, 12:39 PM   #6 (permalink)
Super Duper Mod
lawdogg's Avatar
Drives: deals
lawdogg Level 3lawdogg Level 3lawdogg Level 3lawdogg Level 3lawdogg Level 3lawdogg Level 3lawdogg Level 3
Feedback Score: 109 reviews
You need to pull the ECU and look at the caps.
Originally Posted by GTO Assassin View Post
Originally Posted by ray pampena View Post
Cant we all just smile and get along?
No!
lawdogg is offline   Reply With Quote Quick reply to this message
Old 02-04-2017, 01:19 PM   #7 (permalink)
Ok so the clutch adjustment fixed the clutch problem, however the clutch seems kinda heavy. Clutch booster? It at least shifts fine.
In 1st gear it puts to redline with no issues, but in any other gear it bucks and stumbles.
Where is the check valve for the clutch booster?
Also no CEL is on
Old 02-04-2017, 02:12 PM   #8 (permalink)
Drives: 93 Stealth RT/TT
jonezj is an unknown quantity at this point
Feedback Score: 6 reviews
These cars have heavy clutch pedal feel when the clutch booster IS working even on stock clutch. Get yourself a bov out of an evo. Its metal, doesn't leak, oem fitment, and pretty cheap.
Do a boost leak test and you'll surely find a ton of issues. Clutch boost check valves leak a lot. I just capped mine off
Sent from my LG-H820 using Tapatalk
'93 Dodge Stealth RT/TT - 61k original miles, Silver
'11 GMC Acadia Denali AWD - Black, Daily
'10 Mini Cooper Clubman JCW - 6sp/LSD,Brembo's, Wifemobile
RIP 2010 - '92 Eagle Talon TSI - Black, ~350awhp
"Once that first bullet goes past your head, all the politics go right out the window."
jonezj is online now   Reply With Quote Quick reply to this message
Old 02-04-2017, 03:17 PM   #9 (permalink)
Super Duper Mod
lawdogg's Avatar
Drives: deals
Originally Posted by AlexxRyzhkov View Post
Also no CEL is on
If this was meant to address the ECU issue, it doesn't matter. Pull the ECU.
Old 02-04-2017, 03:24 PM   #10 (permalink)
^^My name is April^^
dbest671's Avatar
Drives: Spyder VR4/SRT8/CTSV
dbest671 Level 2dbest671 Level 2dbest671 Level 2dbest671 Level 2dbest671 Level 2dbest671 Level 2
Feedback Score: 92 reviews
Park it for the time being.
Check:
1. ECU like lawdogg said
2. timing belt, tensioner, oil pan, crank pulley
3. spark plugs- at least the front to see the condition
4. find the source of leaking fluid
5. Boost leak/pressure test
dbest671 is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
