Old 05-17-2008, 12:39 AM   #1 (permalink)
j sin
gltasn's Avatar
Drives: 95 mitz 3kgt vr4
gltasn is an unknown quantity at this point
Default beware fidanza flywheels! need replacement, pz help!
man am i pissed! i just went though all the trouble with changeing a clutch becaue there was something rattling around and it would keep me from getting into any gear, randomly(see my previous threads). i was sure it was the rps street max that has had some issues with springs comming out. when teamed with td05's ive heard it was pos.
the clutch looked awsome and i was scared i might have tranny problem then there it was... one of the 3 pegs that line up the pressure plate to flywheel had come out. what a stupid fucking problem!!!!!!!!!
i will NEVER use a fidanza again! too much work for something that might fall apart.
i need a new flywheel and would like to hear your testimony's of stock, rps segmented, or ips lightweight steel. i will choose from these 3 unless some wisdom gets dropped on me. thanks for listening! j sin
"If I was as slow as you, they'ed bury me!" terry canfield(dad)
gltasn is offline   Reply With Quote
Old 05-17-2008, 01:02 AM   #2 (permalink)
Regulator...
mikes2nd's Avatar
Trader Rating: (34)
mikes2nd Level 1mikes2nd Level 1mikes2nd Level 1
Default Re: beware fidanza flywheels! need replacement, pz help!
i like my unorthadox
mikes2nd is online now   Reply With Quote
Old 05-17-2008, 02:05 AM   #3 (permalink)
Pucking Legendary
AaronVR4's Avatar
Drives: 3000GT VR4
Trader Rating: (18)
AaronVR4 is an unknown quantity at this point
awaiting to test my rps billet...
AaronVR4 is offline   Reply With Quote
Old 05-17-2008, 02:18 AM   #4 (permalink)
Low and Slow
kywhitelightning's Avatar
Drives: 98 VR-4
Trader Rating: (6)
kywhitelightning is an unknown quantity at this point
Have an RPS segmented, been in for about a year and a half and no problems. The one difference between the fidanza and the RPS is that the RPS is a little heavier. Personally, if Matt M. sells it and recommends it, it's a no brainer. My .02
kywhitelightning is offline   Reply With Quote
Old 05-17-2008, 06:29 AM   #5 (permalink)
Now with100% less Stealth
leet's Avatar
Drives: 95 NSX
Trader Rating: (24)
leet is an unknown quantity at this point
I had the same thing happen
no more stealth
leet is offline   Reply With Quote
Old 05-17-2008, 07:43 AM   #6 (permalink)
1/24/09 SBC :-**
Drives: '92 3000gt VR-4
axispiral is an unknown quantity at this point
i need to here more, i just put one in a few weeks ago . . .
FMIC, coming soon
axispiral is offline   Reply With Quote
Old 05-17-2008, 10:23 AM   #7 (permalink)
j sin
gltasn's Avatar
thanks for the reply! hopefuly you'll be ok. i bought my findanza years ago. they may make them better now but, if it does fail, it shouldnt hurt anything. just a serious pain to get to. im triing to make you feel good. did it work? just drive it like you would normaly and if you ever have an issue plz pm me and let me know. j sin
Old 05-17-2008, 11:19 AM   #8 (permalink)
Cant get there from here!
speedy25's Avatar
Drives: Various Japanese
No problems with mine. Sorry to hear of your troubles. That was something that shouldnt have happened. I hope you took a LOT of pictures and talked to their customer service for compensation for defective product.
-SP
Old 05-17-2008, 12:31 PM   #9 (permalink)
leet's Avatar
Drives: 95 NSX
Trader Rating: (24)
not true, when mine shot out 2 of the alignment pins it punched a hole in the bellhousing, I got lucky where it hit because it just barely missed causing damage to where the front diff sits, so I was able to just get the hole welded
I still lost all of my gear oil on the ground though
so has anyone else had bad luck with the fidanza flywheel?
Old 05-17-2008, 12:44 PM   #10 (permalink)
leet's Avatar
Drives: 95 NSX
Trader Rating: (24)
