I must agree that the GTR posting quicker times then those high end super cars is impressive but I would think the ring is the absolute worst place to compare different car's performances. Since its so long doesnt driver abilities and the sheer luck that you dont screw up once in the entire 7min lap kind of mess up the times? Like if one driver can corner .1 seconds faster then another driver the course is so long that becomes a big deal. And not to mention last time I looked up lap times for the ring they are missing a bunch of very high end cars.
You bring up good points, but then again consider these:
That course is used as a de facto "benchmark" for all kinds of high end cars. The drivers that are hired to run those lap times know it like the back of their hand, and it's not like they just do one lap per car either. Also the longer the track is the larger the sample is to compare. So, comparing the fastest lap times of various cars at the 'Ring is a very fair/balanced way to compare the performance in my opinion. How else could it be done? I am sure there are lap times at other (shorter) tracks that are very impressive too.
'99 Trans Am - SLP lid, Magnaflow catback
'92 3000GT VR-4 - BPU - sold March '06
A dyno can nearly spit out any number its operator wants to see. The 120ish trap speeds show its real power. From a roll on, a mildly(i mean very very mildly) tuned Vette would pull one pretty hard.
Jason
How are you comparing a stock base that weighs 3900lbs Skyline to a tuned C6 z06 that weighs ~3300lbs? Roll Racing is not a concern to the Nissan and their engineers! That car has proved it self on the drag strip and on the track.
It's an amazing car but I would never believe that it would be the fastest road car ever...extraspecially with McLaren F1s still running around.
1993 "dove gray metallic" Stealth R/T Turbo
For Sale! 6-speed transmission conversion, 2g front brake conversion, AWS delete with SK VR4 radius rod mod(BIG thanks to Joe G.'s website! )Kormex front LSD, Port matched Upper Intake -> Ported and port matched lower intake -> DR stage ]l[ heads, DR650Rs, ARC2 w/ 87mm MAF $ ARM1, Denso 255 hotwired, 720cc inj. fed by a Home made dual feed system for $800 w/ single hotwired intank pump, DR Weldin DSM sidemounts, DNP Y-pipe, 3SX poly motormounts, Vac hose reduction,, Chipped stock ECU -9000rpm rev limiter, Blitz DSBC in stock tape deck, VDO boost gauge, GREDDY EGT gauge, ATR downpipe - Borla catback w/ custom 3" flanges (3" all the way through), RPS flywheel, RPS clutch, Tein S-tech springs, Saner front and rear sway bars, Cusco adj. rear sway bar, 3SX adj. upper control arms, STEDEBANI front poly suspension bushings, 1995 VR4 front brake caliper conversion, Stillen Rotors,SCE extended wheel studs WELDED IN - THANKS SUPERCAR ENGINEERING! in NEW OEM hubs, Porterfield R4S pads, SILKOLENE brake fluid, Pro N1s w/ S03 Potenzas, 17x9 FNCRO1NFC01RN 5Zigens w/ NITTO 555Rs, POR15 on everything and a ton of new stock stuff For Sale...
This car modded will be insane. I dont care what you guys say. Facts are facts and you all know everyone driving a sports car isnt a race car driver, but those that drive the GTR will look like it :P
This hype is going to send the GTR prices threw the roof. And you whine about poopra prices :P
Once again, incredible times from the GT-R. Once again, the narrow minded people come up with every excuse in the book to down play the results. This is the history of the GT-R in a nutshell.
