Re: Back from the track - Another 13T car in the 11s
Originally Posted by disturbedkorn
The reason I asked that question is because the stock ecu runs fairly rich and expects moderate to low load at redline. If he's pulling 40% out, then his VE is choked, he has high fuel pressure, or more likely now that I've put some more thought into.....he has a boost leak or leaks.
It is looking like my rear Dejon intake pipe (partially) popped off my rear 13T's compressor inlet. Wouldn't be the first time either.
Originally Posted by HLxDrummer
Well I've only read a few comments so far (don't wanna forget what I was going to say lol) but congrats! 11's is pretty awesome, especially for basically having upgraded turbos, injectors, pump, and (assuming) SAFC and minor stuff. Seems pretty consistent too. My Dad's friend put a ton of money into his race only car to hit 12.0 lol He has a car in the 9's now but still..
I can't believe your car and clutch hold that many clutch dumps. I assumed you did the quick slip but you just dump it and it's fine? I would LOVE to be in the car when you do that haha And you just bought a OEM disc? Why not use the RPS disc?
Also, if your going to 3SPA let me know. I don't really have the money for gas (tuition went up, needed a new driveshaft, etc.) and don't know if the car will make it but if your going I'll probably try and make it out.
Flat black is looking good also : )
Make another post once you get some race gas in there!
Thanks Louie. Yeah I just rev and dump ... seems to work out well. I got an OEM disc because the disc that comes with the RPS Max 'full face' kit is basically just a marked up OEM unit anyway ... I was considering picking up a 6 puck but now I really don't see the need.
I'll probably head down to the 3SPA thing (two weeks right?) - if there's anything I can help you with to get your car good to go, let me know.
Originally Posted by Monochrome
Way to go man.
Wasn't so hard was it.
Thanks man. Wishing I had that JDM gearing though ... that 3-4 shift right at the end really sucks.
Originally Posted by Hym3n
I second the RPS Maxx street clutch being an awesome choice, love it love it love it.
Does this car have an aftermarket fuel pump? Are you on stock motor mounts? Going solid may help your front wheelspin.
Yep it has a hotwired Walbro 341, full set of Maximal solids. The intrax springs really compress in the rear, so they may be unloading the front causing the wheelspin ... who knows.
Well I'm pretty sure I'm going so hopefully I'll see you there! I've never been in an 11 second car haha
I don't really have anything to work out except find a cheap Evo DV to get rid of this SSQV, put my TC brace on, and pressure test again. The car also runs really rich (at least at WOT), like .99-1.01V's, which I have no clue why but it drives fine.
About the clutch, so you just bought the RPS pressure plate? That's a good idea if so, I didn't know you could buy just the pressure plate.
I'm still out there preaching that subframe bushings can go bad and cause wheel hop. If motor mounts using the same rubber can cause such havok, there is no reason the subframe bushings wouldnt do the same to a lesser degree.
Green 1995 3000GT // 15t Turbos // ATX to MTX // NA to TT // FWD to AWD // Purchased 11/12/02
White 1999 3000GT Black Dash/Tan Leather Interior // SOHC // MTX // Stock Daily Driver Purchased 7/25/07 <-- Click Here Join FL3S
Originally Posted by 92rtawd
Nice job. Seriously. Congratulations on getting your setup worked out so well.
Edit: I'd rep you if I could.
Thanks man.
With your 450s, I hope they work out for you. Just doing a couple calcs, to match my 95% IDC @ 40psi base with 550cc injectors, you'd be looking at running about 54psi base pressure with 450cc injectors. I think I remember Matt M. saying he has run way more rail pressure than that so I think you'll be fine!
Congrats again!
Haha yeah for sure man. We can go for a spin. You sure your SSQ isn't leaking? That'd explain your rich conditions for sure. Hopefully the Evo BOV fixes things for ya.
And yeah with the clutch, just an RPS Max pressure plate.
Thanks man.
I personally would not recommend that.
At only 15psi of boost, you're looken at 69psi of fuel pressure in the stock rubber lines, gaskets, o-rings... That's pushing it a bit.
