Yes this turbos make good power but need to run high boost last time I recall our motors have a tendency to lift the heads at high boost if not fix like Ray does it, so I dont see a stock bottom end 6g72 running twin hx35 full or hybrid making more than 600awhp in the 25-30 psi range I hope im very wrong in my calculations because I have a similar setup altho 3.7 stroker ,but to take advantage anything passed 30 will be killer.
My dsm feels very good with my pump tune@22psi but when I crank it to 35 is a blast yet im running a garrett .82 a/r turbine housing.
Once I head back to the shop I post pictures of my HX35/40pro setup I did clip the turbine wheel 7* to lighten it up a bit.
