Old 05-14-2008, 03:20 PM   #11 (permalink)
Staying in the Family
jandoaudio's Avatar
Drives: 95 RT/TT
Trader Rating: (12)
jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7
Default Re: Any other Poly Mount Options?
I exchanged a few pm's with paul, they are in the works he just has a lot of other things going on right now Anyone know if 3sx will sell just the inserts?
95 RT/TT Stock
92 VR4 Blacked out with a 98 conversion
dr900's
Stage 3 Heads
98 Jeep TJ
35's
Locked with all the toys
Cheap, Fast, Reliable.... You can only have two
jandoaudio is online now   Reply With Quote
Old 05-14-2008, 06:37 PM   #12 (permalink)
Former DSMer - now VR-4er
James92TSi's Avatar
Drives: #388 Red
Trader Rating: (11)
James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7
Is Seattle going to be making poly replacement bushings for the stock mounts (like what Prothane makes for other cars) or is he doing complete mounts?
Weren't Bob EK2's mounts actually a Seattle design that he licensed/arranged for Bob to manufacture?
'91 3000GT VR-4 Down for now, but she will be back.
'03 G35 Sport Coupe Hates daily thunderstorms.
James92TSi is offline   Reply With Quote
Old 05-14-2008, 09:10 PM   #13 (permalink)
jandoaudio's Avatar
Drives: 95 RT/TT
Trader Rating: (12)
My understanding was that seattle was making complete mounts, I'm not sure about bobs other than I wish he still made them
Old 05-14-2008, 09:36 PM   #14 (permalink)
3Sfever's Avatar
Drives: '91 Stealth TT
3Sfever Level 33Sfever Level 33Sfever Level 33Sfever Level 3
Originally Posted by jandoaudio View Post
Any other options? I was going to pour my own but I don't think I can get the appropriate preload on the polyurethane to prevent deformation unless I press them in.
I poured my own this week. I was also a little concerned with the poured urethane holding up, so decided to give it some help. On the rear mount (which has a smaller diameter sleeve than front for some reason) I increased the surface area of the sleeve. I took 2" diameter aluminum stock, cut to the same width as engine mount ring, drilled a hole in center, installed the original sleeve with some J-B Weld to secure it. Then poured urethane between the aluminum "hub" and the mount ring.
It seems to be very stiff. I guess only time will tell if it holds up.
-Ron
'91 Stealth TT
purchased Aug 2004
3Sfever is offline   Reply With Quote
