Old 09-23-2008, 06:12 PM   #1 (permalink)
Drives: 94 3000gt SL
94greenGT is an unknown quantity at this point
Default AMP wiring!!! help
Sorry to post this here but i wasnt getting any reponses in audio.......Does anyone have any pictures of where the ran their battery cable through the fire wall to to the trunk??? I dont know where to go through at......if know pictres please someone explain. Thanks
94greenGT is offline   Reply With Quote
Old 09-23-2008, 07:26 PM   #2 (permalink)
Oh SNAP!!!
mywetdream's Avatar
Drives: 94 TT, 69 427 vette
Trader Rating: (19)
mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7
Default Re: AMP wiring!!! help
there is a acess point close to where your battery is at...run the wire through there...and take out your passenger side seat..pull the door sill up.....there will be some white plastic ...run your amp wire there..and to the back...have it pop out under your back seat...and then to your amp...
If you feel I have answered your question..leave me some rep...thanks
**1ST place RMG 07 best engine**
Like the snake the BITE must be felt and not seen, goin super, until then super slow want some!!!
1st car with the Enkei RZ-5 18''x8.5''
*534x306*
1994 Dodge Stealth R/T TT~Pearl Yellow
mywetdream is offline   Reply With Quote
Old 09-23-2008, 08:24 PM   #3 (permalink)
looking at the cowl panel behind the battery where is this access point????? Also how do i get it into my interior without taking out the blower motor under my dash??
Old 09-23-2008, 08:31 PM   #4 (permalink)
Oh SNAP!!!
mywetdream's Avatar
Trader Rating: (19)
look under your dash there is a black panel under glove box...look around pull it out..and you should see that hole..there...
