Old 04-27-2008, 10:36 AM   #81 (permalink)
Silvertsiawd's Avatar
Drives: 1991 TT Stealth
Trader Rating: (6)
Silvertsiawd Level 1Silvertsiawd Level 1
Default Re: Almost 400 AWHP at 14psi, 13Ts
Rain. Sucks. Alot. Track is closed.
-Dan
1991 Dodge Stealth R/T Twin Turbo
Hallman MBC, HKS Boost Gauge, K&N FIPK, BOZZSPEED cromoley light weight flywheel, ACT heavy duty street clutch, Carbon Fiber Driveshaft, ATR 3 Stainless Steel Downpipe, ATR 3 Stainless Steel exhaust system, Stillen Cross-drilled Rotors, Stillen Metal Matrix pads, Goodridge Stainless Steel braided brake lines, Unorthodox Underdrive pulley, Tein Flex Coilovers, Custom Ram Air, HKS inline Fuel pump
Non-Performance: NR White Face gauges, Erabuni Rear bumper, Custom Refit leather seats and interior, Tinted Windows, Stealth ChromPlug Sound- Sony equalizer, JBL amp, Infinity 12" sub, speakers, Sony MD player, Sony 10 disc cd changer.
Silvertsiawd is offline   Reply With Quote
Old 05-12-2008, 12:56 AM   #82 (permalink)
Mr. Cheese
92RT-TT's Avatar
Drives: 92 RT/TT & 92 RT/TT
Trader Rating: (16)
92RT-TT Level 792RT-TT Level 792RT-TT Level 792RT-TT Level 792RT-TT Level 792RT-TT Level 792RT-TT Level 792RT-TT Level 792RT-TT Level 792RT-TT Level 792RT-TT Level 7
Dan... this is completely random.. but one of your post's said you were going to ditch your dsm smic for a front mount, did you do that and if you did, wanna sell me your dsm smic? Pm me and let me know please. Thanks
1992 Dodge Stealth RT-Twin Turbo
64,000 miles, Stored Winters, AEM Tru-Boost, Greddy Type S BOV, DNP Hardpipes, Palm MMCD, Tein S-Tech Springs, Brembo Rotors, MSD Wires, K&N FIPK, EGR Delete, Vacuum Reduction, Cianci 3 Gauge A-Pillar, 5zigen FN01R-C 18x9.5's wrapped in BFG KDW 265-35-18's. 13% Tint, 12 Disc CD changer, 3 1/2 inch Custom Exhaust.
DD-Pearl White 92 Stealth TT-85,000 on it, BPU 270 awhp, 307 awtq on 8-23-08
92RT-TT is offline   Reply With Quote
Old 06-08-2008, 01:08 PM   #83 (permalink)
Paid Member
jba3's Avatar
Drives: mitsu's stock up ^_^
jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7
Track times! And did you install the FMIC? Shoot me a PM about it. Going to install mine this week hopefully.
Selling my 95VR4 coupe.
http://www.3si.org/forum/f10/95-3000...10-xxx-439661/
Bought a spyder.
If my posts have been helpful or informative, or even entertaining, rep is appreciated.
Old 06-08-2008, 04:34 PM   #84 (permalink)
Trader Rating: (6)
I didn't install the FMIC myself so I can't help you there. I'm going if weather allows it this friday. This weekend is a pro event so it's not open to street cars.
Old 06-08-2008, 05:21 PM   #85 (permalink)
Killer Whale
josevr4's Avatar
Drives: like my mother
josevr4 is an unknown quantity at this point
By what RPM's do you 13T guys reach full boost? Im getting my installed next week.
[/SIGPIC]
Dejon dual intakes and Ypipe, Synapse B.O.V., Gen2 Maft w/3.5" sensor(blowthru), RandomTech Cat,3SXdownpipe,Ips singletip exhaust, Maximal solid motormounts,13T's,Gtpro headers(powdercoated) w/precat elims,Supra Fuelpump,550cc's,AEM Fpr,IPS hotwire kit,AEM AFR guage,Newvolt ignition amp,IK27 plugs, Southbend DXD-FE clutch,Fidanza flywheel,SSclutch line,300M output shaft.
289awhp and 298awtq on stock boost @11.3AFRlimited by bad VSS's
on stock sidemounts
Next ported heads and bigger intercoolers
josevr4 is online now   Reply With Quote
Old 06-08-2008, 07:44 PM   #86 (permalink)
Kibwe Walker's Avatar
Drives: 93 RT/tt
Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7
15 psi at around 2700 rpms based on exhaust work and whatever you have them set to by 3k-3100 rpms. I have seen as high as 24 psi with them.
His - Red 93 RT/tt
Mods: Hallman's MBC @ 16 psi, turbo XS type H BOV, stillen dp, custom exhaust, Spec stage 2 clutch, RPS FW, 3sx lightweight crank pulley, BCP7RES-11 @ .030 gap, autometer gauges, slightly gutted mas, dsm SMIC's, ACPT 1 piece CFDS, Tein S springs, pte 580 inj's, safc neo/SITC, 13t's, hotwired walbro, maximal performance solid motor mounts, DR plenum spacer.
Hers - BPU Green 94 vr4
Kibwe Walker is offline   Reply With Quote
Old 06-09-2008, 06:39 AM   #87 (permalink)
USMC
vr4_rider's Avatar
Drives: 3/S
Trader Rating: (12)
vr4_rider Level 1vr4_rider Level 1
I don't see how it's possible to get 15psi by 2700.
Stock is 9psi by 2800.
How do you do it?
Also, I see full boost around 3200.
vr4_rider is offline   Reply With Quote
Old 06-09-2008, 07:16 AM   #88 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (65)
I also see 15psi by 2700, if not sooner.
Stock is garbage. Removing intake and exhaust restrictions makes 9b's spool a heck of a lot faster than that.
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 06-09-2008, 08:51 AM   #89 (permalink)
Drives: 93 RT/tt
lets be clear about something, NOTHING OUTSPOOLS 9b's, and I mean nothing.
With the usual open intake and downpipe with gutted precats I could get 10 psi at 2k rpms doing a 3rd gear pull, the slightest load increase on 9b's would result in full boost. If it weren't for the sound you would think it was almost super charged.
It was sort of pissing me off they were so fast because anytime you hit the gas they would spool up and I could look at the A/F guage lock in the green area. I mean it took real effort to get good gas mileage with those ultra fast spooling 9b's. Probably would have been worse had I had the catback then too.
13t's brings the car back to stock spool characteristics as in the car down low acts like a completely stock 3s (intake, cats, and exhaust), spool wise that is. Fun starts at 2500 rpms but thats where the comparison ends. 13t's are violent sort of especially once you creep up there in boost. Floor it and there isn't anything gradual about it. They are more of a on off switch. Floor it and you are gone and most things just start fading away when you go WOT.
Old 06-09-2008, 10:05 AM   #90 (permalink)
TPW Educator
LVA3KGT's Avatar
Drives: with EDFC at 0/0
LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7
I see what you mean by "violent". When I compared his 400awhp dyno chart to my 390fwhp chart, it shows me with 50 more whp at 3000RPMs, but by 400RPMs, we are both at 300whp. So in that 1000RPM span, his rate of accelration was much faster than mine.
For reference, here is the chart I was comparing. My dr500s @17psi.
97 SLtt
World's fastest fwdTT 97SL in Phoenix
410 Ft/lbs of torque-steer and 390HP to the front wheels, making 1-3 gear useless @17psi. Built and tuned by 3SX
(Firebird) = Best 60ft 2.4 Best ET 13.8 , best trap 110.8MPH , picked up almost 30mph on the big end of the track.
3SI member # 5422
LVA3KGT is offline   Reply With Quote
