Old 03-11-2008, 01:27 PM   #41 (permalink)
Kibwe Walker's Avatar
Drives: 93 RT/tt
Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7
Default Re: Almost 400 AWHP at 14psi, 13Ts
Originally Posted by Jeremy R View Post
that was race gas right?
yes on pump he made 440 @ 18 psi
His - Red 93 RT/tt
Mods: Hallman's MBC @ 16 psi, turbo XS type H BOV, stillen dp, custom exhaust, Spec stage 2 clutch, RPS FW, 3sx lightweight crank pulley, BCP7RES-11 @ .030 gap, autometer gauges, slightly gutted mas, dsm SMIC's, ACPT 1 piece CFDS, Tein S springs, pte 580 inj's, safc neo/SITC, 13t's, hotwired walbro, maximal performance solid motor mounts, DR plenum spacer.
Hers - BPU Green 94 vr4
Kibwe Walker is offline   Reply With Quote
Old 03-11-2008, 01:28 PM   #42 (permalink)
Drives: 93 RT/tt
Originally Posted by moffman93' View Post
Yup I forgot his pump numbers. I was there when he dyno'd it too but I'm drawing a blank here lol.
see post above on stock heads and cams
Old 03-11-2008, 01:33 PM   #43 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (65)
Originally Posted by Kibwe Walker View Post
race gas and 26 psi
What was the difference between Eugene's setup and CANENAC's setup? Since CANENAC made 475/500 or something on the 13T's with (I thought) stock heads.
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 03-11-2008, 01:44 PM   #44 (permalink)
Stealth Aficionado
Drives: 1995 Stealth TT
Trader Rating: (34)
OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7
Damn I need to get on the dyno this year.
Mods:
-.030” over 9:1 engine
-13T’s
-560cc Evo Injectors
–ACPT CFDS
–IPS FMIC
–MAFT-Pro Speed Density
–Soon to be Coil-on-plug
I was trapping almost 116 last year running a fat 10.5 AFR on 16-17psi with a 1.88 60’. I’m really interested to see if the 9:1 build makes any difference.
Nice numbers and good luck.
Tony M.
1995 Dodge Stealth R/T Turbo - 12.46@115.77
2007 Dodge Ram 1500 4x4 - 15.2 mpg
OwnGTP/WantRTTT is offline   Reply With Quote
Old 03-11-2008, 06:06 PM   #45 (permalink)
Drives: 93 RT/tt
IIRC adamvr4 tuned that setup, he had a FMIC (not stock SMIC's), don't remember the inj's size or the piggy back but I am guessing it was a safc because IIRC adam controlled the timing by altering the base pressure with a afpr.
Several people have said in the past that running more than 22 psi with a 15g class tdo4 turbo only hurts power. Eugene was running 26 psi to redline on stock SMIC's. I am pretty sure that was hurting him more than it was helping.
Old 03-11-2008, 06:30 PM   #46 (permalink)
Drives: 93 RT/tt
from adamvr4's thread canenac's mods. I was wrong the exhaust is 3.5" split to 3.
Stock 135k mile old LONG BLOCK
CC / Dejon hard intercooler pipes
Dejon hard intake pipes (dual filter)
FMIC (Don't know what size core...)
Upgraded ignition wires
Iridium plugs @ .028"
Upgraded downpipe
Pitroad-M Exhaust (NICE!!!)
S-AFC
MAF-T
LS-1 MAF in blow-thru
PTE 680cc injectors
SX AFPR @ 36 psi base
EK2 Fuel Rail loop
Polyurethane Motor Mounts
Fidanza flywheel
RobBeck's 13T's
Emissions Reduction
MBC
Old 03-11-2008, 06:32 PM   #47 (permalink)
Keeps 3Ses on the road
xteekayx's Avatar
Drives: anything that rolls
Trader Rating: (15)
xteekayx Level 3xteekayx Level 3xteekayx Level 3xteekayx Level 3
Originally Posted by Predacon View Post
Is 550's really enough for 13T's? I was recommended 660's or higher.
plenty enuff for pump gas power...
Toy:
-= '95 RT/TT =-
xteekayx is offline   Reply With Quote
Old 03-11-2008, 09:53 PM   #48 (permalink)
Slowest 3/S in chicago
DaveSlow's Avatar
Drives: 93 Black VR-4
Trader Rating: (20)
DaveSlow Level 4DaveSlow Level 4DaveSlow Level 4DaveSlow Level 4DaveSlow Level 4
Do keep in mind that just because someone made ONE number with a part doesn't mean that it's perfect or great. In this case, sure bob did make over 500 with a dual core intercooler. That doesn't mean using a different one won't do it. You guys do realize that top core isn't getting ANY airflow at all? Have you ever stood in front of a window that had air blowing through? Did your feet get any airflow?
DaveSlow is offline   Reply With Quote
Old 03-12-2008, 05:46 AM   #49 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (65)
Iridiums?! Huh. Thanks for digging that info up.
Old 04-23-2008, 12:07 PM   #50 (permalink)
Paid Member
jba3's Avatar
Drives: mitsu's stock up ^_^
jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7
Oh just another question - what shop is it at / who is tuning it?
Originally Posted by Silvertsiawd View Post
I launch at about 6K, have an ACT heavy duty clutch.
And its Atlantic motorsports in Maryland. Nice looking shop, very friendly staff, I'm very happy with them so far.
-Dan
Sorry to drag this up from the dead, but SilverTSIAWD, I thought you were tuned by Nick at DTM?
Selling my 95VR4 coupe.
http://www.3si.org/forum/f10/95-3000...10-xxx-439661/
Bought a spyder.
If my posts have been helpful or informative, or even entertaining, rep is appreciated.
