Old 01-22-2007, 12:09 PM   #1 (permalink)
1fstascar's Avatar
Drives: Just a V6.
1fstascar is an unknown quantity at this point
Default aem uego dual sensor
anybody have a wiring diagram for a first gen, the aem came with an adapter to plug right into the ems goes into pins 80-91
"Mustangs are like tampons, every Pus*y has one"
1fstascar is offline   Reply With Quote
Old 01-22-2007, 12:58 PM   #2 (permalink)
High-Fivin BAMF
talskinyguy's Avatar
Drives: with 714ft/lbs
Trader Rating: (23)
talskinyguy Level 7talskinyguy Level 7talskinyguy Level 7talskinyguy Level 7talskinyguy Level 7talskinyguy Level 7talskinyguy Level 7
Default Re: aem uego dual sensor
I pulled power from the stock O2 sensor plugs and ran the sensor voltage back through the stock connectors also.
talskinyguy is online now   Reply With Quote
Old 01-22-2007, 02:38 PM   #3 (permalink)
1fstascar's Avatar
Drives: Just a V6.
well i already ran the aem wires, just need the pin out puts. anybody??
Old 01-22-2007, 02:47 PM   #4 (permalink)
***** User
Tricky222's Avatar
Drives: 91 VR4
Trader Rating: (63)
Tricky222 Level 1Tricky222 Level 1
stealth316.com has the pin outs
I dunno why you just didnt search:
ECU Pinouts
ecu pinouts
http://www.3si.org/forum/showthread....ht=ecu+pinouts
That whatcha lookin for?
Tricky222 is online now   Reply With Quote
Old 01-22-2007, 04:06 PM   #5 (permalink)
1fstascar's Avatar
Drives: Just a V6.
did search why are those pin out diagrams on 316 different then the ones aem gives
Old 01-22-2007, 04:08 PM   #6 (permalink)
1fstascar's Avatar
Drives: Just a V6.
and none of the links really helped
Old 01-22-2007, 06:31 PM   #7 (permalink)
***** User
Tricky222's Avatar
Drives: 91 VR4
Trader Rating: (63)
well tell us what pins/wires youre wanting
Old 01-22-2007, 06:55 PM   #8 (permalink)
Canadian Speed Junky
Coal's Avatar
Drives: '92 Dodge Stealth TT
Trader Rating: (9)
Coal is an unknown quantity at this point
The 316 pinout is the same, it's just listing everything for the stock ECU. I linked you to the AEM EMS pinout in the last thread you made. Pins 55 and 56 are the only ones I can see indicated for 02s. I have the narrowband outputs going to those with the stock ecu.
The wideband outputs should go to those pins on the EMS. I haven't been home much, haven't been able to search around to confirm, but that looks like the only way it could be.
ET: 13.29
Coal is offline   Reply With Quote
Old 01-22-2007, 07:04 PM   #9 (permalink)
1fstascar's Avatar
Drives: Just a V6.
the aem uego came with an apadapter that plugs into pins 80-91 on the aem ems i need to know which wires on the aem uego go to which pin in that adapter theres 16 pins and only like 8 wires which 8 pins
Old 01-22-2007, 07:12 PM   #10 (permalink)
Coal's Avatar
Trader Rating: (9)
Mine didn't come with any harness/adapter, strange.
