Old 08-22-2009, 03:55 AM   #21 (permalink)
DirtyWhiteVR4's Avatar
Drives: 3KGT VR4
DirtyWhiteVR4 Negative 1
Default Re: Active Aero question
My rear doesnt work either, when i bought the car about a month a ago and it worked perfectly took it home tried it and it doesnt work ever since then only the front works, theres no red 'aero' light in the cluster
any info on that?
1993 3000gt VR4--77K--
K&N filter--Dowpipe--test pipe-HKS catback (like stock)--Hks SSQV bov--boost mod--@ 11 psi
DirtyWhiteVR4 is offline   Reply With Quote
Old 08-22-2009, 04:08 AM   #22 (permalink)
ganesht's Avatar
Drives: several vr4s
Trader Rating: (8)
ganesht is an unknown quantity at this point
any info on that?
im willing to bet its the wing clips that are busted.. if you have someone hit the aa switch, while you stand behind the car ill bet that you can hear the rear aa motor turning, but the wing its self doesnt move.. another test would be to see if you can tilt the wing yourself.. normally when the clips are good they won't allow you to tilt the wing..
if thats the case then you have to get the replacement clips from 3sx..
the lack of the red aa light means the computer thinks everything is ok, which means the rear wing's motor and switches are good, its just that th wing has been disconnected from the motor..
My triplets
91 vr4 w/ 15Gs
Back Home!
92 vr4 fiji blue w/ spun bearing
91 vr4 fiji blue 100% stock
Sold
FS: Luxury Liner Pro 36 sq. ft
FS: NEW Cianci Performance Front & Rear 3 Point Strut Bars
ganesht is offline   Reply With Quote
Old 08-22-2009, 04:17 AM   #23 (permalink)
Drives: 3KGT VR4
thanks for the response
i do always hear something in the back, every time i press the aa switch
but i have tried pulling it my self up, it wouldnt work,
Old 08-22-2009, 04:23 AM   #24 (permalink)
ganesht's Avatar
Trader Rating: (8)
well if you hear a clicking sound then thats the relays in the aa computer.. if its a spinning motor sound then you most likely need clips..
Active Aero Rear Wing Clip*-*Mitsubishi 3000GT*/*Dodge Stealth
