91 Rebuild w/ Phantoms - Page 2 - 3000GT/Stealth International Message Center
Old 12-02-2012, 02:57 PM   #11 (permalink)
Drives: 1991 3000GT VR4
codyandrson is an unknown quantity at this point
Feedback Score: 4 reviews
Default Re: 91 Rebuild w/ Phantoms
Couldn't that be fixed with a proper bov setup?
codyandrson is offline   Reply With Quote
Old 12-02-2012, 03:00 PM   #12 (permalink)
Drunk as a lord
Forest Gump's Avatar
Drives: 1995 Stealth TT
Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2
Feedback Score: 100 reviews
no....
Forest Gump is offline   Reply With Quote
Old 02-26-2013, 06:33 PM   #13 (permalink)
Updates: The engine has been pulled (some time ago) and is at the shop being rebuilt. I am picking up parts right now. Already have mckeandevr4 rods and a "new" forged crank, just grabbed the 3sx arp girdle stud kit and should be picking up bearings and pistons soon. I plan to use Pampena pistons since I have heard nothing but good things about them. Picked up stock injectors and maf so I can start it and run everything on a stock setup before I reinstall my HKS VPC and go back to speed density.
Old 02-26-2013, 07:10 PM   #14 (permalink)
[IMG][/IMG] [IMG][/IMG]
Old 02-27-2013, 04:53 AM   #15 (permalink)
Damage that led to rebuild [IMG][/IMG] [IMG][/IMG] [IMG][/IMG]
Old 02-27-2013, 07:19 AM   #16 (permalink)
Drweldin's Avatar
Drweldin is an unknown quantity at this point
Feedback Score: 159 reviews
You might want to think about better gauges if its in the budget. Personally I have the Prosports Premiums and like them....have had zero issues with them and they are affordable. Otherwise I like your choice of components so far....just select your gaskets and seals carefully too....and ditch the phantoms like forest said. Look into a 19T or a DR650 instead.
Drweldin is offline   Reply With Quote
Old 02-27-2013, 08:16 AM   #17 (permalink)
Keeps fragging heads...
2Slow2Tedius's Avatar
Drives: '93 VR-4
2Slow2Tedius is an unknown quantity at this point
You get compressor surge out of too much CFM and not enough exhaust flow. Needs bigger hotside/turbine wheel (one or the other, or both)
Those bearings look absolutely fucked. Worse I've ever seen without being down to the copper consistently.
You definitely need a new oil pressure gauge though. My gauge read like that after new main and rod bearings (at operating temp)
2Slow2Tedius is offline   Reply With Quote
Old 02-27-2013, 09:28 AM   #18 (permalink)
So I dont know for sure that they are phantoms the previous owner just told me that they are "Turbonetics stage 1 twin-turbos with Super 60-S trim compressor wheels" which I think are phantoms? But noone has referenced them as having a turbonetics wheel in them. I just was wondering if they would damage my engine if I put them on after rebuilding it. If I have isses with them then I am more than willing to look at other options but im just not sure what they are capable of. What issues would I be looking at? Just compressor surge? I appreciate all your help, im just trying to figure out where to go from here since I already have the turbo's.
Old 02-27-2013, 11:15 AM   #19 (permalink)
I plan to add at least an oil pressure gauge before i start it up, I already have an apexi boost gauge so that should have me covered well enough to start.
