850 AWHP - Mustang Dyno - Page 6 - 3000GT/Stealth International Message Center
Old 04-01-2012, 09:32 PM   #51 (permalink)
Z15A Tweaker
Trevor's Avatar
Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4
Feedback Score: 22 reviews
Default Re: 850 AWHP - Mustang Dyno
Originally Posted by TAZmaniac View Post
And I see peak boost a couple of hundreds RPM earlier than you do with a smaller engine ????
Flow, Altitude, and (likely) temperature. Flow wise I'm probably outflowing all but a handful of cars out there at this boost level (and boost is just a funticion of flow resistance). At my altitude the turbo is working just as hard at 33.8 psi as it would at 37.8 psi at sea level. And temperature wise Norway's not exactly know for it's warm weather.
And why is the peak HP as low as 6400 ? cams ??
Probably a combo of the conservative timing up top and the 62mm throttle body, stock intake manifold, and 1.01 AR turbine housing clogging things up.
Which company built your GT42 ?
Garrett built my turbo.
According to my calculations (or rather a friend who knows what he`s doing ) the turbo should easily provide enough flow for a couple of hundred more horses on E85 .......
I'll cut you some slack since it seems you two aren't familiar with Mustang dynos. You (or your smart friend) should do those calculations backwards using my 1728cc injectors at 83.66% IDC. Actually I'll save you the trouble; at 0.78 BSFC & 9.68 cc/min to lbs/hr conversion you'll find that is 1148 crank HP worth of E85. While Garrett likes to under rate their turbos I don't see a couple hundred more HP hiding in there.
BTW...can you post your dyno? I'd like to compare my car to another pegged out single.
96 Dodge Stealth R/T TT
883 AWHP
06 Subaru WRX STi
451 AWHP
Trevor is offline   Reply With Quote
Old 04-02-2012, 12:06 AM   #52 (permalink)
back in the saddle again
niterydr's Avatar
Drives: 92 rt/tt & 02 2500hd
niterydr is an unknown quantity at this point
Feedback Score: 40 reviews
Excellent results Trevor, thank you for sharing the particulars. Best of luck at the track on the 14th!!
-Josh
new project: white 92 rt/tt - project K.I.S.S (more traction, less power)
Last project:
blue 93 rt/tt-SOLD
2005: 11.65@ 127.08mph 92 octane ~ 480awhp
2006: 11.45@ 136mph C-16 ~ 620awhp, traction-less wonder
best dyno: 720.2awhp/592tq.
Dyno numbers were on Dyno Dynamics brand dyno, track times weight: 3780lbs.
niterydr is offline   Reply With Quote
Old 04-02-2012, 01:04 AM   #53 (permalink)
Paid Member
Drives: 92 RT-TT
markoverclock is an unknown quantity at this point
Feedback Score: 47 reviews
IPS single turbo kit?
markoverclock is offline   Reply With Quote
Old 04-02-2012, 01:30 AM   #54 (permalink)
Z15A Tweaker
Trevor's Avatar
Yeah
Old 04-02-2012, 01:55 AM   #55 (permalink)
I'm a Member
Drives: GTO 1996
MichaelMR2 is an unknown quantity at this point
Feedback Score: 6 reviews
Has the stock 6g72 knock sensor picked up anything on the E85? there is whisper that the knock sensor is not tuned for the frequency....you seem to be Mr Experiment at the moment soooo?
Another Day Another Dollar
MichaelMR2 is offline   Reply With Quote
Old 04-02-2012, 02:27 AM   #56 (permalink)
popups FTW
eengler2's Avatar
Drives: 1992 VR4
eengler2 is an unknown quantity at this point
Feedback Score: 3 reviews
Just for fun, since engine size and PR has been discussed, here is a link to a 2l, GT4202 (not the new gtx). 91 Galant VR4: 2L, GT4202, 44psi, E98, built everything - DSM Forums
cliffs:
816awhp. 2l, E98, 45psi (tapering to 42), doesn't hit full boost until 6500ish, peak tq at 7kish (540 vs trevor's 760), revving to 10k. 1.7L makes quite a difference
1992 Kilder Green VR4 - 6G72 Billet td05, E85, AEM
1995 Green Montero SR - 6G74, 32" BFG AT
eengler2 is offline   Reply With Quote
Old 04-02-2012, 04:07 AM   #57 (permalink)
niterydr's Avatar
cliffs:
Off topic:
That car is going through some work and should best its current fastest pass and the previous dyno results. (Best friends car and the one I was referencing on Trevor's other thread). It hit 829awhp/554tq at around 40psi on a local dyno jet last time I was messing with it (last fall). Car was breaking up due to a new head and other changes on the setup that weren't ironed out.
On topic:
What is amazing is to see the extra displacement and how it shifts the torque curve to the left on Trevor's setup. The GVR4 is a drag car and doesn't drop below torque output once its off the line, Trevor's car is ONE HELL OF A STREET CAR as well as a monster at the track.
Old 04-02-2012, 05:09 PM   #58 (permalink)
Z15A Tweaker
Trevor's Avatar
New mod list:
4” intake with K&N filter in the front wheel well
Garrett GTX4202R Turbo w/1.01 Turbine Housing (HPC Xtreme Coated)
IPS Motorsports FMIC & Piping
Tial Q Series BOV (Black Spring)
62mm RC Engineering Throttle body
Ported Upper Intake manifold
IPS Motorsports Race Spec CNC'ed Heads (Ray's Head fix)
Ferrea Double Valve Spring Kit w/Titanium Retainers
Brian Crower "280" Race Cams
“Big Bore” Lifters
Denso IK02-24 Iridium Racing Plugs
HKS Twinpower Ignition
Custom Wiseco Forged Pistons (93.5mm 9.0:1) w/”XX” ring package
Trend Performance 0.220" Wall H13 Tool steel wrist pins
Pauter 6G74 Rods
Pampena Motorsports 90.0mm 4340 Billet Crankshaft
Mitsu Debonaire 6G74 Block
AEM EMS (v1)
Dual in-tank Aeromotive Stealth 340 pumps
40A Kenne Bell Boost-Pump actuated by the AEM (BAP controller in center console and green "on" LED above radio)
80A / 4-Gauge Pump Power system
220A Mechman Alternator
Odyssey PC925 Battery
-8 AN Feed / -6 AN Return
FueLab 5" Fuel Filter (stanless 40 micron)
3SX Fuel Rails
1699cc Fuel Injector Clinic Injectors (actually run at 45 psi base for 1728cc/min effective)
FueLab Fuel Pressure Regulator
IPS Motorsports Single Turbo Headers w/HPC Xtreme Coating
Dual Tial 38mm Wastegates w/23.2 psi springs
Turbine Housing Blanket
IPS Motorsports 4" Downpipe w/HPC Xtreme Coating (Random Tech 4" 9000 series cat when needed)
Custom Stainless Single 4" Catback with Burns Ultralite Muffler
ClutchMasters 850 series Twin Disc Clutch w/TD7 "Race" discs
Kormex Limited Slip Front Diff
Supercar Engineering 7075-T6 Shift Forks
Supercar Engineering Torsen Center Diff
Custom 6061-T6 Bellhousing Beef-Up Plate
300M 25 spline output shaft
PST One Piece Carbon Fiber Driveshaft
Summit Racing Driveshaft Loop
Pampena Motorsports 300M rear Axles
18x9 Buddy Club P1 QF wheels in gunmetal (14.8 lbs/ea)
BF Goodrich G-Force Drag Radials on all four in 275/35/18 flavor
Porterfield R4-S Pads & Cryoed Rotors
Castrol SRF Brake Fluid
3SX Motor Mounts w/HARD compound urethane
3SX Dual Pass Radiator
IPS Motorsports Aluminum Radiator Piping
Derale 16925 12” Pusher Fans
Mugen 164F Thermostat
Straight water w/Redline Water Wetter
Custom Radiator Ducting
Stant Racing 23 psi Radiator Cap
Dual Setrab Oil Coolers w/AN Lines
Redline Fluids thruout the driveline
Redline 5w-50 Oil
Mobil1 oil filter with a FilterMag
JIC FLT-A2 Coil Overs
Five Defi Link System 52mm gauges in imperial units with V.2 control unit and master caution light
Stewart Warner 40 psi boost gauge
Dual Innovate LC-1 Wideband O2's feeding the AEM
Dynotune Mini Square Wideband Display
HKS EVC Pro Boost Controller
RJS 5 point harness
Custom chromoly 5 point rollbar (roughly 59 lbs)
Corbeau A4 Seats
Nothing in the back but plastic trim on the sides & carpet on the floor, and a sub...
GT300 Style Fiberglass hood
Fiberglass Hatch
Carbon Fiber Sunroof
Old 04-02-2012, 05:14 PM   #59 (permalink)
popups FTW
eengler2's Avatar
Drives: 1992 VR4
^weak. Need pics!
Old 04-02-2012, 05:50 PM   #60 (permalink)
Al-key-haul
Intropy's Avatar
Drives: 2G RT/TTs
Intropy Level 1Intropy Level 1
Feedback Score: 55 reviews
Originally Posted by Trevor View Post
New inverse mod list:
Unibody
Fixed.
AEM s2 EMS | E316Gs | E85
Intropy is offline   Reply With Quote
