Old 10-04-2008, 11:19 AM   #1 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Feedback Score: 217 reviews
Default 770AWHP 670AWTQ Stock Heads/Cams E90 Blend
So I went and bought E95.
E85 is 85% Ethanol (E100) mixed with 15% 87 octane pump gas.
The E95 I purchased is 95% Ethanol denatured with 5% Methanol. They denature it so the gov't don't tax them on it as drinkable alcohol.
I then mixed 10 gallons of E95 (95% Ethanol 5% Methanol) with 1 gallon of 93 octane.
Had to add 5% more fuel globally due to the higher concentration of Eth/Meth over gas. Then after the 2nd run I pulled out 2% in high boost and higher RPMs to make the 3rd and final run. Pumps running on BAP at 35% and 1000CC injectors base pressure 60psi. IDC is now at 90-95%. EDIT: Just looked at Statistics for the run and it hit 96.527IDC
The Fuel is DONE.
Last run on E85:
745AWHP 640AWTQ @ 32psi.
New run on E90 blend:
770AWHP 670AWTQ @ 33psi and .7 degrees more timing
Still not one drop of coolant push. Low peak cylinder pressure is what Ethanol all about.
The addition of the extra fuel flow and more timing bumped the curve to the left even more. At 4500 RPM she used to have 383AWTQ and now has 423AWTQ.
VIDEO:
YouTube - 3SX E90 770AWHP Stock Heads/Cams
EDIT:
Mod list was asked for so here it is:
-Used 2 bolt from the sandstone I parted
-Used crank I had boxed up in the garage for 4 years now. Had it polished and mag checked for $35 and that's it. NOT Turned, Std bearings
-3SX Custom Forged Rods
-Set of used 3SX/Ross pistons 91mm
-Used stock heads (sandstone and green VR4 partout) Stock used valves. Hand lapped and cleaned up. Stock cams. 3SX Hi Rev Spring Kit. 3rd Gen Lifters
-Fidanza Cam Gears set at +1 int -3 exh and locked down
-AEM, IAT, AEM 3.5 MAP
-PTE 1000CC Injectors
-No gauges except one AEM WB on pillar.
-3SX TD05 manifold kit w/Tial leaded shaft WGs, Precision-Garrett 5027s 48A/R hotside
-CX Racing FMIC kit modified for my setup
-3SX Dual pump Dual Feed fuel system
-Kenne Bell Boost a Pump
-Greddy ProfecII specB
-Stock oil cooler and lines
-3SX Aluminum single pass Radiator 20% coolant 70% water stock rad cap and thermostat
-Slim stock fan moved to other side, Slim aftermarket fan in other location
-HKS Twin Power, MSD Wires, NGK 7 coppers
-Dejon Pre Turbo pipes
-Tial Q BOV
-Krank Vents
-Trans and TC rebuilt by me, shoulda used a better 3rd
-MP TC bracket
-PST Aluminum/steel 2 piece driveshaft
-OEM water pump, OEM oil pump
-Castrol Dyno Oil, Red Line Shockproof Heavy, Penzoil Synchromesh
91VR4-3.0L-Stock heads and Cams-835AWHP 747AWTQ Daily Driver 10.57@141mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
NG09 and NG10 Title Sponsor
3SX Automotive
My 1991 VR4
3SX Performance
3SX Performance Service Email
Carolina 3S Forum
Old 10-04-2008, 11:25 AM   #2 (permalink)
has just posted
dudewutup's Avatar
Drives: 93 vr4 + 95 base
dudewutup is an unknown quantity at this point
Feedback Score: 4 reviews
Default Re: 770AWHP 670AWTQ Stock Heads/Cams E90 Blend
nice numbers man
dudewutup is online now   Reply With Quote
Old 10-04-2008, 11:29 AM   #3 (permalink)
Vr4 Addict
viva le greg's Avatar
Drives: 93 vr4
viva le greg is an unknown quantity at this point
Feedback Score: 2 reviews
very cool stuff
93 vr4
FMIC, IPS DP, Greddy RS bov, Free boost mod, Megan Coilovers, Stage II clutch, AEM dryflow, UP SSK, MSD coils and wires, ngk coppers, BT ground wires, cross drilled rotors, 120k, MP T-case bracket+lo mi T-case
on its way to being installed: 99 lifters, aem tru boost, walbro w/hotwire+install, adj ca's
viva le greg is offline   Reply With Quote
Old 10-04-2008, 11:42 AM   #4 (permalink)
eengler2's Avatar
Drives: '92 VR4
eengler2 is an unknown quantity at this point
Feedback Score: 0 reviews
Great job! Would love to see what it does with some more work on heads...
eengler2 is offline   Reply With Quote
Old 10-04-2008, 11:44 AM   #5 (permalink)
Administrator
HilbillyHomeboy's Avatar
Drives: Tin Indian
HilbillyHomeboy Level 2HilbillyHomeboy Level 2HilbillyHomeboy Level 2HilbillyHomeboy Level 2HilbillyHomeboy Level 2
Feedback Score: 39 reviews
How much does the E95 cost? Available "at the pump" like E85?
That's pretty amazing, especially for stock cams.
Jeremy
92 Stealth AWD GT42 10.73...142.21mph (SOLD)
There are TWO ways to succeed in life:
1. NEVER tell anyone everything you know.
HilbillyHomeboy is offline   Reply With Quote
Old 10-04-2008, 11:47 AM   #6 (permalink)
Jeremy
Don't think you can find it at the pump, notice I didn't sneak in the "pump gas" in the title of this one
E95 is $155 for 55 gallons.
There is NO way it would make this power on Race gas. Stock heads and cams just can't flow enough air. It's getting it's airflow via the Ethanol which is one of the highest oxygenated fuel there is. I can't beleive it has done what it has. Little 3.0L 2 bolt with stock heads and cams. It's funny cuase she just idles nice and quiet like a stock car. LOL
-Chris
Old 10-04-2008, 12:05 PM   #7 (permalink)
1stStealthN/A's Avatar
Drives: 92 VR4, 92 StealthTT
1stStealthN/A is an unknown quantity at this point
Feedback Score: 6 reviews
Nice. Any trouble with oil contamination? What oil are you using?
Thanks for all the research results you're providing to the 3Si community.
1stStealthN/A is offline   Reply With Quote
Old 10-04-2008, 12:09 PM   #8 (permalink)
The MoonShine Man
jrod's Avatar
Drives: on TE37's
jrod Level 1jrod Level 1jrod Level 1
Feedback Score: 42 reviews
Man this shit is getting me pumped. I will be at the track with my e85 converted car next Friday. Cant wait.
TheOnePercent.net
Midweststreetcars.com
Home of the Fastest Street cars.
jrod is offline   Reply With Quote
Old 10-04-2008, 12:20 PM   #9 (permalink)
Civics taste like chicken
Drives: like crazy again
Turbo79 Level 1Turbo79 Level 1
Feedback Score: 16 reviews
Chris - this is awesome. You've made me drive around and try to find E85 near me. Closest pump is $4.05 a gallon. That is MUCH lower than the 100 octane I've been putting in lately. This is definitely in my future.
Thanks for the great research
Turbo79 is offline   Reply With Quote
Old 10-04-2008, 12:25 PM   #10 (permalink)
15t's ... ? yep
DigiiManDan3KGT's Avatar
Drives: 80Gig WesternDigital
DigiiManDan3KGT is an unknown quantity at this point
Feedback Score: 7 reviews
christwagons
Green 1995 3000GT // 15t Turbos // ATX to MTX // NA to TT // FWD to AWD // Purchased 11/12/02
White 1999 3000GT Black Dash/Tan Leather Interior // SOHC // MTX // Stock Daily Driver Purchased 7/25/07
<-- Click Here Join FL3S
DigiiManDan3KGT is offline   Reply With Quote
