#1 (permalink) |
OK well I am overdue on my 60K service (I am currently at 70K) due to money problems because of school and I noticed my water pump start leaking so it has to be the time now.
My question is where do you go to get your parts and what are the prices respectively? Here is what I have for it so far, Prices are from Norco Mitsubishi in California Water Pump MD972005 $117.28 Timing Belt MD193874 $107.90 Tensioner MD319040 $102.44 Timing Belt Tensioner Pulley MD140071 $30.58 Timing Belt Idler Pulley DOHC MD319022 $28.58 Throttle Body Gasket MD180361 $1.94 Intake Plenum Gasket MD143791 $7.66 Spark Plugs(6) Spark Plug Wires Oil Oil Filter MZ690072 $4.60 Fuel filter MB658136 $18.88 PS belt AC belt So I would just like to know where you get your parts from and also if there is anything you can think of adding while its torn apart? P.S. I would also like to give a big thanks out to Tim (eddy) for helping with the list and for offering his services to help me in times of need.
Ken
![]() Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and torque is how far you make it through the wall. |
#3 (permalink) |
Tire Pumper Extraordinair
Cherry Hill Triplex Parts Center - Cherry Hill Dodge, Cherry Hill Jeep, Cherry Hill Kia and Cherry Hill Mitsubishi, 1805 Route 70, Cherry Hill, NJ 08002
I'd add oil pump to the list myself. Ted
1994 Stealth RT
1996 3000GT |
#4 (permalink) |
Twin T3/T4 Turbos
this is just what i would do, but if you add up the prices you listed it adds up to 419.86, and thats not including belts and such, while at IPS (IPS Motorsports) its 383.59, there some things not included in the package but i still thing it'll be cheaper.
Alfredo
94 VR4: (Under the Knife) Twin T3/T4 Turbos (.60 Compressor A/R, .63 Turbine A/R) Wiseco 92.5mm Pistons, 3SX Forged Rods, Polished Crank, Fully Ported and Polished Stage 3+ Heads, 3SX SS Valves, IPS Titanium Springs and Retainers, 99 Big Bore Lifter, IPS 272 Cams, Fidanza Cam Gears, Mitsubishi Timing Belt, Oil Pump, and Water, PTE 880CC Injectors, Aeromotive Fuel Pressure Regulator, Twin Walbros 255, AAM Billet Fuel Rails, AEM EMS, MSD DIS-4 HO, MSD GM Coils, MSD Super Conductor Wires, AEM 3 BAR MAP, AEM IAT, Apexi AVCR, Innovate LM1, LMA-3, XD16, 3SX Braided Clutch Line, Goodrich Brake Lines, Project Mu Brake Pads, Carbon Tech Rotors, ABS Delete, Fidanza Lightweight Flywheel, ACT Heavy Duty Pressure Plate, ACT Modified Street Disc, Rota SVN 18X9 30mm Offset, Falken Azenis RT615, Tein S-Tech Springs, New 6 Speed Transmission, and Transfercase. 95 SL: (Currently On Hold) Single Turbo Conversion, AWD Conversion: GT4088, Wiseco 92.5 Pistons, 3SX Forged Rods, Polished Crank, Port And Polished Head, SS Valves, 99 Lifters, Titanium Valve Springs, IPS 280 Camshafts, Fidanza Cam Gears, Kevlar Timing Belt, PTE 1000cc Injectors, Aeromotive Eliminator Fuel Pump, Aeromotive Fuel Pressure Regulator, IPS Billet Fuel Rails, Emanage Ultimate, MSD DIS 4, MSD Coils, Accel 8mm Wires, NGK IX Plugs, Apexi AVC-R, LM1, LMA-3, Meth Injection Kit, 4" Core FMIC, 4' TBE. Black Wheel Mafia - Member 010 |
