Old 05-13-2008, 07:48 PM   #1 (permalink)
ChampagneR/T's Avatar
Drives: 94 3000gt
ChampagneR/T is an unknown quantity at this point
Default 3sx DP/TP = check engine
So, I installed a 3sx Downpipe and test pipe and now my check engine light is on. I cleared the code at work and halfway home it came back on. I was in a hurry so i didn't pull the code, just cleared it, but i'm assuming its and O2 sensor. What can i do besides getting O2 sims. car is FED-SPEC.
ChampagneR/T is offline   Reply With Quote
Old 05-13-2008, 07:54 PM   #2 (permalink)
Argentine 3KGT
BSAS3000GT's Avatar
Drives: 94 Red VR4
Trader Rating: (29)
BSAS3000GT is an unknown quantity at this point
Default Re: 3sx DP/TP = check engine
car is fed spec? wierd i thought fed specs had only two 02 sensors. If yuo got a check engine light your car should be cali spec then, or maybe you disconnected something at the same time you swapped the parts
--> 1994 Mitusubishi 3000GT VR4 <--
**95 Base 3KGT TT Converted Part out** PM me
BSAS3000GT is offline   Reply With Quote
Old 05-13-2008, 08:53 PM   #3 (permalink)
Drives: 94 3000gt
i'll guarantee it's not cali spec, no EGR, no precat, one sensor before the test pipe. I looked under it and the wire is kinda twisted up would that affect anything.
Old 05-13-2008, 09:37 PM   #4 (permalink)
Damage Control
Stealthee's Avatar
Drives: 1994 Stealth
Trader Rating: (77)
Stealthee Level 7Stealthee Level 7Stealthee Level 7Stealthee Level 7Stealthee Level 7Stealthee Level 7Stealthee Level 7Stealthee Level 7Stealthee Level 7Stealthee Level 7
Unless you damaged the o2 you shouldnt be getting an o2 CEL. Im Cali spec, have gutted precats, 3sx dp, test pipe, and have never gotten an o2 CEL. Never will either.
Take the few seconds to pull the code.
Old 05-14-2008, 05:03 AM   #5 (permalink)
Hubbell86's Avatar
Drives: 1992 Stealth R/T TT
Trader Rating: (6)
Hubbell86 is an unknown quantity at this point
yeah i dont have a problem... no check engine light
1992 Dodge Stealth R/T TT (41,700 original miles!)
Mods: 3sx TP, Emanage Blue, Currently 12 Psi (9bs), FJO A/F KWB4001, Working on 15gs as you read this (400AWHP here i come!!!) Walbro 255, 450cc injectors
1992 Dodge Stealth R/T NA
Mods: 3sx DP, 3sx TP, and Ebay Intake
1/4 Times
92 Stealth - N/A
On Foot - 51.6 Fastest 4x400 in SouthWestern Pa
Hubbell86 is offline   Reply With Quote
Old 05-14-2008, 05:18 AM   #6 (permalink)
Fire-Breathing Dragon
tran03's Avatar
Drives: EVO 8
Trader Rating: (40)
tran03 is an unknown quantity at this point
Definately pull the code first, that way you have a better guess on what's wrong.
Check the actual wiring harness of the o2 sensor when you replaced it going towards the engine bay.
When I changed my DP on mine long ago, I got a CEL too. Turned out while replacing the rear 02 sensors (OBDII, 97 VR4) I pulled a little too hard and the harness popped off.
tran03 is offline   Reply With Quote
Old 05-14-2008, 04:44 PM   #7 (permalink)
Drives: 94 3000gt
pulled the code today and i got:
Code 11: Left front heated O2 sensor fault.
now that doesn't seem like its referring to the one under the car to me. I cleared it again it was good for the first 10 miles home then the code popped up again, and the wires go up inside the car i cant even see the harness connector.
Old 05-15-2008, 02:25 PM   #8 (permalink)
Drives: 94 3000gt
anybody know what sensor it's talking about, i really don't want to pull the bulb.
Old 05-15-2008, 02:39 PM   #9 (permalink)
Damage Control
Stealthee's Avatar
Trader Rating: (77)
Its talking about the o2 sensor. Make sure the wiring isnt damaged.
Old 05-15-2008, 02:46 PM   #10 (permalink)
est. sept, 2000
91vr4n00maxima's Avatar
Drives: slow 97 VR4
91vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 7
you sure the car is fed spec?
if you do infact have 1 o2 sensor you damaged either the sensor or wiring when replacing the parts.
97 VR4 12.417@111.16 9b time. full weight almost BPU
95 mark viii. 14.35@98
03 cobra vert. 4 mods=118mph traps
91 stealth TT. td05 18G, heads/cams, 3000lbs
91vr4n00maxima is offline   Reply With Quote
