#41 (permalink) |
more pics!
1992 Stealth R/T
![]() Drive Train/Performance: Aem FPR (Rob's adapter), DR650r's, Borla Cat-Back, Dejon Intake / Blow Through Setup, GM Maf / Maf-T, Greddy E-Manage (Blue), Greddy E-01 Boost controller, Greddy Type RS BOV, Maximal Performance Solid Motor Mounts, MSD Ignition Wires, Optima Yellow Top Battery, Spec Stage 3 6 puck Clutch, Walbro Fuel Pump. Exterior/Appearance: 1999 3000GT Front Bumper, Headlamps and Turn Signals, Second Generation Stealth Hood, Side Skirts/Door Caps, Rear Bumper and OEM 96 Wing. Interior: Cianci Triple 60mm Gauge Pod (matching passenger side replacement), Greddy Counter Weight Shift Knob, Greddy Silver 60mm P/H/W Gauges (center replacement and gauge pod), LC-1 Wide Band, M515 PDA/MMCD Data Logger, Seattle Roller Bearing Short Throw Shifter. Suspension/Wheels: Black Racing Pro N1 17x9 Wheels, Cusco Front and Rear Strut Bars, Ground Control Coil Overs (Stock ECS Struts), Stealth TT Brake Upgrade. Soon To Come: A drivable car!!!! To Do: Finish building/Install motor, Install Water/Meth Injection, Tune Properly, Paint and Install AWD Conversion parts (after motor break in/tuned). |
#42 (permalink) |
Doesn't look like there is a convertable top mechanism in there at all...just an open racer style cockpit.
----------------[2007 Ride of the Year
![]() ![]() "Stroke" her I did. Retired - TD04 WRX19t's = 513awhp @ 18psi on PUMP ![]() |
#43 (permalink) |
VR4 owner since 1993
Hack-job or not, I'll give whoever did it props for the effort.
If I ever get the time necessary for such project, I'll show you guys how it's done right. ![]() Longitudinally mounted rear-engine (8A80 perhaps), TT, w/AWD and a few other ideas. Ah, to have time. Of course by that point, 99% of the people here now will be long gone and I'll be puttering around this board by myself. ![]() -JD
John Davidson JD's VR4s Mem#0092
![]() ![]() ![]() ![]() 2006 Liquid Platinum Metallic M45 Sport 1993 Caracas Red 3000GT VR4 (JD-01) All factory options. Apexi SAVC-R, Greddy BOV, 17x9 Volk Challenge wheels (Chrome w/Black Diamond lip), Firehawk SZ50 275/40 zr17 tires, Porsche/Brembo 993 "Big Red" 4-piston front calipers - OEM Porsche pads, '94+ 2-piston rear calipers - Porterfield R4S pads, '94+ Porterfield Cryoed/Crossdrilled rotors, SS brake lines, K&N Intake, Borla Exhaust, Cusco rear strut-bar, Custom TEC front strut-bar, battery relocation kit, Snake Eyes Mod. -In the works: Boost,A/F,Twin EGT gauges, customized cockpit layout, stereo upgrades, alarm upgrades, downpipe, precat/cat removal, cool air intake?, AEM?, Air/Liquid Intercooler?, CFDS?, etc. Previous Autos: 1995 Yellow 3000GT VR4 Spyder (former JD-02) Customized 1999 Dark Toreador Red Clearcoat Metallic Ford Expedition (AWD too!) Eddie Bauer 4x4 1992 Sandstone Gray Metallic 3000GT VR4 (former JD-02) 1989 Black Nissan Maxima SE 1977 Black Pontiac Trans Am |
#45 (permalink) |
Go Phillies!
wow just wow
04 SRT-4 Electric Blue- Sold wtf!
1991 3000GT VR-4 Sold 4 Bolt main conversion, Blitz dual SBC spec r, 3'' Air Filter, Blitz SuperSound BOV, VDO Boost gauge, Polished Y-Pipe, Kormex output shaft and Input spool, Accel spark plug wires with NGK Platinum plugs, 3rd gen lifters, drilled and slotted rotors, blacked-out snakes & turns, Mirage Corp. OBD1 datalogger cable w/Palm m100 Gone: 95 3000GT SL, 94 3000GT, 92 Stealth RT/TT |
#47 (permalink) | |||
TD05. that is all
<--replacing psychotherapy since 1860 Quote:
![]() Psychology, Help me, help you, stay sane. ![]() |
#48 (permalink) | ||||
Head of Society of Bob
#49 (permalink) |
Looks like a base since it has no ECS caps on the front struts. They might have been swapped for other struts though....can you make out if it as the brake lines that run to the ABS pump in the front?
That red thing is blocking a view.
#50 (permalink) | |
broke joke
everyone always tossin around the wrong slogans. 3000gt - 'the poor mans testarossa' i read that before i had a 3/s; still sux we got the testarossa b/c we are faster than that pos anyway. ![]() I think its interesting and if it was all polished and pretty there wouldnt be so many haters.
92' firestorm VR-4 - complete 96' JDM drivetrain - 92' electronics/sensors - UR cam gears, flywheel - DNP pipes - Stillen intake, rotors - 3sx downpipe, steel braided lines, subframe/diff bushings, control arms, plennum spacer - Tein s - denso IK24 - Apex'i AVC-r - MP solid mounts - Spec 3 - Vacc reduction
Deleted - ALL emissions, AA, antenna, rear wiper, front washer bottle, batt relocate, 4WS |
