Old 07-05-2008, 01:34 AM   #1 (permalink)
Drives: 1992 Stealth RT/TT
AK Stealth TT is an unknown quantity at this point
Default 2nd gen conversion questions
What is required to do a 2g front end conversion. i got a 92 stealth and i wana swap but dont know if i need to do anything special other than buy it and put it on. any info would be appreciated.
AK Stealth TT is offline   Reply With Quote
Old 07-05-2008, 08:22 PM   #2 (permalink)
I GOT BOOST YAY!!!!
Sin'sVr4's Avatar
Drives: Expensive Biatch!!!!
Trader Rating: (14)
Sin'sVr4 is an unknown quantity at this point
Default Re: 2nd gen conversion questions
I just did mine. Check out my thread on 91 To 98 conversion. You need to cut off about 4 inches from your stock 1g bucket. You need to modify the inner bucket wall to fit the light.
I took angle iron, banged it flat and tapped into the existing holes for the bumper. Motivated took about 9-10 hours with 2 people. Unmotivated with 1 will take alot longer. Plus you will have to make sure that the hood lines up and that the lights are lined up properly.
It takes alot of work. ALOT
There is no such thing as LUCK...Luck is when opportunity meets prepardness
Sin'sVr4 is offline   Reply With Quote
Old 07-05-2008, 08:42 PM   #3 (permalink)
LeRoyDL's Avatar
Drives: 1992 R/T TT Conv.
Trader Rating: (51)
LeRoyDL is an unknown quantity at this point
i welded in 2nd gen buckets, alot of work and alot of drilling, cutting and welding.
1992 Stealth R/T
Drive Train/Performance:
Aem FPR (Rob's adapter), DR650r's, Borla Cat-Back, Dejon Intake / Blow Through Setup, GM Maf / Maf-T, Greddy E-Manage (Blue), Greddy E-01 Boost controller, Greddy Type RS BOV,
Maximal Performance Solid Motor Mounts, MSD Ignition Wires, Optima Yellow Top Battery, Spec Stage 3 6 puck Clutch, Walbro Fuel Pump, Wiseco Pistons.
Exterior/Appearance:
1999 3000GT Front Bumper, Headlamps and Turn Signals, Second Generation Stealth Hood, Side Skirts/Door Caps, Rear Bumper and OEM 96 Wing.
Interior:
Cianci Triple 60mm Gauge Pod (matching passenger side replacement), Charcoal roof/pillar conversion, Greddy Counter Weight Shift Knob,
Greddy Silver 60mm P/H/W Gauges (center replacement and gauge pod), LC-1 Wide Band, M515 PDA/MMCD Data Logger,
Seattle Roller Bearing Short Throw Shifter.
Other
List getting to big, really to much shit to list.
Suspension/Wheels:
Black Racing Pro N1 17x9 Wheels, Cusco Front and Rear Strut Bars, Cusco Front Strut mounts, Ground Control Coil Overs (Stock ECS Struts), Stealth TT Brake Upgrade.
Soon To Come:
A drivable car!!!!
To Do:
Finish building/Install motor, Install Water/Meth Injection, Tune Properly, Paint and Install AWD Conversion parts (after motor break in/tuned).
LeRoyDL is offline   Reply With Quote
