#41 (permalink) |
Here for the tuna.
The only way to make a statistically accurate comparison is to sample the population of 13g applications and sample the population of 13t applications, and then compare your bell curves.
There are so many variables when comparing two different turbos at the same pressure. Temperature, air density, heat soak'd intercoolers, timing advance, skill of driver, hell even headwind vs. tailwind will alter the results of such a comparison. If we can use this thread as home base to gather #'s for the population comparison, sure. But finding two different cars holding the exact same boost through the RPM range, shifting at the exact same points, with the exact same 60's and exact same AFR's and timing advance through the ENTIRE run, except one is running 13g's and the other 13t's is not something I ever see happening. |
#42 (permalink) |
I have no doubt of Jacks times or even 13g potential, I am just looking for my own numbers and 1 dyno would do it for me.
When playing with automatics or whatever trapspeed can be fairly consistent since it removes the human factor/error out of the equation. On the other hand with manuals trapspeed can be effected greatly by the drivers shift method and speed especially with a TC'ed car. Trap speed is a indicator of your AVG hp over the 1320 but the more time you spend shifting can have a effect on that average. Lift to shift and what not. Also various locations will have a effect on trap speed with the amount of boost being run too in that 17 psi at 4k ft isn't the same as 17 psi at sea level and that will effect trap speed and power. I wish it were that simple but there still are alot of variables. What I am driving at here though is a simple bolt on setup. I can't find ANY dynos, time slips (ET. or TRAP), that show a 13g car with simple bolt ons making what 13t's and 15g's do even at lower boost levels where they are suppose to be equivalent. Why is that? IDK, maybe because most 13g's out there are bastardized versions without the L turbine. I just want 1 objective number showing a 4xx AWHP from anywhere on the planet on a stock engine, stock cams, bolt on 13g's, FP, inj's, intake, and exhaust because thats all it takes for 13t's and 15g's to get over 400 to the wheels and thats all it takes to see 116+ traps. Not that I haven't seen traps like that from 13g's but 100% of the time there is some other engine modification (heads, cams, compression), or even nitrous. Have you found any because there have to be some even across the pond where some Euro specs came stock with 13g's.
His - Red 93 RT/tt
Mods: Hallman's MBC @ 16 psi, turbo XS type H BOV, stillen dp, custom exhaust, Spec stage 2 clutch, RPS FW, 3sx lightweight crank pulley, BCP7RES-11 @ .030 gap, autometer gauges, slightly gutted mas, dsm SMIC's, ACPT 1 piece CFDS, Tein S springs, pte 580 inj's, safc neo/SITC, 13t's, hotwired walbro, maximal performance solid motor mounts, DR plenum spacer. Hers - BPU Green 94 vr4 |
#43 (permalink) | |
Man we must have been on the same wavelength for a sec or two there. |
#47 (permalink) |
Off topic
That show is horrible. Yeah you beat by 10 carlengths on that last run so I am going to need 11 carlengths so I got a shot and we are racing for slips.PUCK THAT. Run what you brung, start at this line and 1320' later we will see who calls a cab. I wouldn't bring anything out there I wouldn't mind losing though (foxbody and run through Jegs, and Summit seems reasonable and cheap). That and I am not giving a inch. |
#48 (permalink) | |
Here for the tuna.
#49 (permalink) | |
Warning: I'm an asshole
1992 3000GT VR4
![]() ![]() --Completely rebuilt 5/06-4/07. Everything new. For a list see: http://www.3si.org/forum/showthread.php?t=372579 --First time on dyno: 364AWHP@16psi with a 10.3AFR (now tuned at 11.4-11.6 with timing control, time for another dyno run soon) --Mods: DR Stage I heads, 3rd gen lifters, TD04L 13Gs, DSM SMICs, PTE 550s, Apexi SAFC, Apexi SITC, Walbro FP, IPO hotwire, Robbeck adapter & AEM FPR, 3SX underhood fuel gauge, 3SX fuel rail loop, DN Y-pipe, HKS SSQ BOV, K&N FIPK, Greddy Profec Spec S, AEM WB02, Autometer C2 boost, egt, oil press & water temp gauges, MSD wires, NGK BCP7ES's, TEIN FLEX coilovers, Maximal performance control arms, solid engine mounts & powdercoating, RPS Streetmax Clutch, RPS Flywheel, NBT Tranny (cryotreated OS, shift forks & rails), updated speedo gear, solid shifter bushings, full 2nd gen brake conversion, 3SX SS brake & clutch lines, Carbotech Panther+ pads in the front & Bob Cats in the rear, 3SX clutch vac delete, EGR delete, vac reduction, Ebay DP, gutted pre cats, Bronze FN01RCs 5Zigen 18x8.5 + 30 offset, Pirelli P-Zeros, engine dress up kit, Bigtyla ground wire kit. --Daily Driver: 98 Malibu, 4cyl, auto |
#50 (permalink) | |
Yank in Yorkshire
Agreed! Then we can get back to determining why there is a difference, if any.
Jim Matthews - Yorkshire, England, UKTeam3S, 3SI #30, GTOUK #155 http://www.the-matthews.com/stealth.html Jet Black '94 Dodge Stealth R/T Twin-Turbo AWD AWS 6-spd Active Suspension Damping, Ek2MFG dual-flex downpipe, Zorstec custom SS cat-back dual A'PEXi Super AVC-R Mk-I, MHI TD04L-13Gs, K&N FIPK, IPS SS Y-pipe A'PEXi Super AFC 5-knob, 450cc Black Tops, MirageCorp Logger Mobil 1 & Redline fluids, Hotwired Denso 1020 Pump, IPO/SX AFPR SCE 332x32/322x28 cryoed StopTechs, Wilwood proportioning valves Winter: stock alloys 17x8.5-46, Hankook Icebear W300 235/45VR17 Summer: Enkei RPM2 17x9-40, Yokohama AVS ES100 245/45ZR17 Track: Enkei RPM2 17x9-40, Yokohama A-032R Hcomp 275/40R17 My reliable daily driver since Feb 1997! ![]() |
