Old 04-23-2008, 02:01 PM   #31 (permalink)
Yank in Yorkshire
bjmsam's Avatar
Drives: 94 Stealth TwinTurbo
Trader Rating: (12)
bjmsam Level 7bjmsam Level 7bjmsam Level 7bjmsam Level 7bjmsam Level 7bjmsam Level 7bjmsam Level 7
Default Re: 13G vs. 13C Turbos
Can you use your method of generating those compressor map comparisons to lay a 15G, 13T, and 13G map down on the same chart?
I've already posted charts for 13T vs. 13G, 15G vs. 13G and 13T vs. 15G to the Turbocharger Compressor Comparisons page. Three on one chart is pretty busy unless I axe most of the contours (see the 16T vs. 18T vs. 19T chart).
Jim's Stealth in the Bavarian Alps, 2001Jim Matthews - Yorkshire, England, UK
Team3S, 3SI #30, GTOUK #155
http://www.the-matthews.com/stealth.html
Jet Black '94 Dodge Stealth R/T Twin-Turbo AWD AWS 6-spd
Active Suspension Damping, Active Exhaust Delete, 5300K HIDs
Ek2MFG dual-flex downpipe, Zorstec custom SS cat-back dual
A'PEXi SAVC-R Mk-I, MHI TD04L-13Gs, K&N FIPK, IPS SS Y-pipe
A'PEXi SAFC 5-knob, 450cc Black Tops, MirageCorp Logger, DSM SMICs
Mobil 1 & Redline fluids, Hotwired Denso 1020 Pump, IPO/SX AFPR
SCE 332x32/322x28 cryoed StopTechs, Wilwood proportioning valves
Winter: stock alloys 17x8.5-46, Hankook Icebear W300 235/45VR17
Summer: Enkei RPM2 17x9-40, Yokohama AVS ES100 245/45ZR17
Track: Enkei RPM2 17x9-40, Yokohama A-032R Hcomp 275/40R17
My reliable daily driver since Feb 1997!
bjmsam is offline   Reply With Quote
Old 04-23-2008, 02:05 PM   #32 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (62)
I did not see that before. VERY cool stuff. Thanks for making all those!
Now I need to get out my pen and paper and make me some demand lines ...
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 04-23-2008, 03:43 PM   #33 (permalink)
Kibwe Walker's Avatar
Drives: 93 RT/tt
Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7
Those numbers are based on what?
In practice though you are hard pressed to find a 13g or even 13c car that gets over 400 to the wheels on stock heads and cams. 13t's on the other hand don't take much to cross that line as you see 4xx and 115-120 traps all the time and they are relatively new. 13g's have been out as long as the 3s platform and its hard to find any numbers like this without heads, engine work, or nitrous involved in the equation. Hard as I haven't found any today and even looking back on former members who I thought achieved such numbers turns out they had engine modifications and not just bolt on 13g's/13c's.
Unless you have a great deal on them I wouldn't recommend 13g's especially when these days you can get 13t's for the same price if not cheaper and they are that much more powerful. Maybe they shouldn't be for all practical purposes but the numbers that they kick out on average (4xx) seem to say they are. The more I look the more I stick by my original post.
I am looking for any dyno of a 13g car making more than 400 to the all 4 wheels without nitrous or engine modifications. Just bolt on turbo, IC, exhaust, injs, fp, and exhaust because thats all it takes for 13t's to get over 400 to the wheels even on pump gas 16-18 psi. The same settings is landing a 13g/13c powered car in the 350-380 mark and the difference has to be all compressor and compressor housing efficiency since the turbines are the same (L).
ESP / FFT Unichip Stage 2+ DYNO Results.
His - Red 93 RT/tt
Mods: Hallman's MBC @ 16 psi, turbo XS type H BOV, stillen dp, custom exhaust, Spec stage 2 clutch, RPS FW, 3sx lightweight crank pulley, BCP7RES-11 @ .030 gap, autometer gauges, slightly gutted mas, dsm SMIC's, ACPT 1 piece CFDS, Tein S springs, pte 580 inj's, safc neo/SITC, 13t's, hotwired walbro, maximal performance solid motor mounts, DR plenum spacer.
Hers - BPU Green 94 vr4
Kibwe Walker is offline   Reply With Quote
Old 04-23-2008, 03:57 PM   #34 (permalink)
RESIDENT ASSHOLE
DJAuggie's Avatar
Drives: 1996 3000GT VR-4
Trader Rating: (41)
DJAuggie level 6DJAuggie level 6DJAuggie level 6DJAuggie level 6DJAuggie level 6DJAuggie level 6
Nice thread. It's really cool to see another option for turbos in the TD04 class (or turbos in general). I wouldn't touch them until someone else had just because the 15Gs is tried and true and the 13T is cheap and has some good results finally (Took you bitches like years... )
With that said, where did this 17PSI > race gas theory come up? With Timing controllers/FMIC/Injection (propane/alky/water)/etc.. being more and more popular, you can throw that theory out. Personally, I'd go with 13T because of the ability to expand past typical pump gas boost #s.
I've never heard of a guy on 3SI going: Man I wish I went with the smaller turbos. Well, except Innovator but he was/is/always will be a retard.
DJAuggie is offline   Reply With Quote
Old 04-23-2008, 04:42 PM   #35 (permalink)
Drives: 93 RT/tt
IIRC Trevor and a few others went the otherway going backwards from something larger than evo3's too.
Old 04-23-2008, 10:40 PM   #36 (permalink)
Yank in Yorkshire
bjmsam's Avatar
Trader Rating: (12)
Those willing to make that kind of investment tend not to bother with 13 or 15 class turbos (19T and TD05 options seem most popular for that crowd).
Again, dyno numbers are comparable only when the runs are back-to-back on the same dyno with the same operator. What does the demand curve look like for 400 AWHP at 14 psi? Trap speed seems to be a more consistent metric, as it removes many of the variables that impact dyno numbers and elapsed times. Speeds measured with the same model of G-Tech accelerometer would be suitable for comparison IMO. Jack's runs were surely on race gas at higher boost, so this is just an example and not particularly useful for the 17 psi comparison I proposed:
Originally Posted by xwing View Post
all stats are NO nitrous in this letter, except as noted
13G's went 12.000 and 119.381 best mph, on 4/8/95; about 500 hp at the wheels; overall, gained about 110 hp with 13G over 9B, but given other changes 13G likely ~100 hp better than 9B.
13G best ET was 11.702 @ 118.061 on 6/6/96; this was through traps in 3rd gear, on the rev limiter. I was the first 3000GT in the 11's 5/17/95 with an 11.937@118.338. --I think 13G can be good for about 510hp at wheels maxxed out with standard stuff.
I have yet to see a satisfactory technical explanation that would substantiate the claimed performance differences at 17 psi. Perhaps it's time to move this to the Advanced Technical Discussions forum to solicit additional input?
Old 04-24-2008, 12:30 AM   #37 (permalink)
Drives: 93 RT/tt
Jack also went 10's with 15g's with minimal mods+nitrous. He even had the stock DP and catback
The only thing more impressive than Jacks Times is Ray Pampena running 11 flat at 120 with 15g's without nitrous. I mean talk about your freak runs. All other times in that area have traps of 8-10 mph faster.
Still scratching my head over that one. As far as I know that car was stock weight with minimal mods and a hacked stock MAS, go figure.
As far as 13g's are concerned, I don't even need back to back, I am looking for a single dyno, anywhere on the planet where someone made 4xx to the wheels with 13g's and simple bolt ons. Just one as 13g's have been around for 10+ years while 13t's have been around for 3-4 years.
Great drivers aside 13t's and other 15g class turbos can and do make 4xx with minimal mods even at lower boost numbers. I mean the record for 13t's is 472 and that was running 22 psi on a stock engine. 20-22 psi is all it takes for 450ish WHP out of a 15g class setup and bolt ons (IC, FP, inj's, exhaust). 16-18 psi lands you in the 400-440 area based on other supporting mods.
Old 04-24-2008, 12:43 AM   #38 (permalink)
Drives: 93 RT/tt
I got these in 5 minutes of searching for 13t stuff. I have looked several times today and have NOT found anything of 13g's anywhere near this. I will be happy with just 401 AWHP because I think they can do that much. Just looking for numbers from someone who has a pair. Crap Phalse ran 11.7 with a 9b/13g combo and he trapped 117ish IIRC so there has to be a dyno somewhere. You found one bjmsam?
13T's on the dyno, 445awhp 455 awtq
jrod track results
I beat my 13T record
13T Tuning -- Dyno Results Soon
Old 04-24-2008, 12:51 AM   #39 (permalink)
Drives: 93 RT/tt
Phalse ran a 11.8 with a 9b/13g combo on 450 cc inj's and trapped 114 but his 60's were 1.59 and 1.6's .
http://www.3si.org/forum/f13/11s-fin...on-come-76645/
Old 04-24-2008, 09:51 AM   #40 (permalink)
Yank in Yorkshire
bjmsam's Avatar
Trader Rating: (12)
Again, I am looking for "back-to-back quarter mile trap speeds for 13G and 13T cars with similar mods running 17 psi," not elapsed times or dyno measurements for maxed out setups. As you can see here, "freak runs" have little impact on trap speed, which is why it's a better metric for comparing power. Phalse trapped 114 mph with one TD04-9B and one TD04-13G, so Jack's consistent 118-119 mph traps with two TD04L-13Gs and little else seem reasonable, but those runs do not meet the stated criteria since they involved higher pressures and race gas.
