#21 (permalink) |
Scanned through that thread again and it turns out Fastoldguy's setup isn't exactly stock heads and cams. He has 1mm oversized valves, 8.5:1 pistons, and clipped 13g's and it was 410 AWHP and 429 lb/ft of torque.
His - Red 93 RT/tt
Mods: Hallman's MBC @ 16 psi, turbo XS type H BOV, stillen dp, custom exhaust, Spec stage 2 clutch, RPS FW, 3sx lightweight crank pulley, BCP7RES-11 @ .030 gap, autometer gauges, slightly gutted mas, dsm SMIC's, ACPT 1 piece CFDS, Tein S springs, pte 580 inj's, safc neo/SITC, 13t's, hotwired walbro, maximal performance solid motor mounts, DR plenum spacer. Hers - BPU Green 94 vr4 |
#22 (permalink) |
Yank in Yorkshire
I'm asking for "back-to-back quarter mile trap speeds for 13G and 13T cars with similar mods running 17 psi" because dyno numbers and elapsed times are too unreliable for comparison.
BTW, last time I asked him, Lane didn't know whether he had TD04 hybrid 13Gs or TD04L factory 13Gs.
Jim Matthews - Yorkshire, England, UKTeam3S, 3SI #30, GTOUK #155 http://www.the-matthews.com/stealth.html Jet Black '94 Dodge Stealth R/T Twin-Turbo AWD AWS 6-spd Active Suspension Damping, Ek2MFG dual-flex downpipe, Zorstec custom SS cat-back dual A'PEXi Super AVC-R Mk-I, MHI TD04L-13Gs, K&N FIPK, IPS SS Y-pipe A'PEXi Super AFC 5-knob, 450cc Black Tops, MirageCorp Logger Mobil 1 & Redline fluids, Hotwired Denso 1020 Pump, IPO/SX AFPR SCE 332x32/322x28 cryoed StopTechs, Wilwood proportioning valves Winter: stock alloys 17x8.5-46, Hankook Icebear W300 235/45VR17 Summer: Enkei RPM2 17x9-40, Yokohama AVS ES100 245/45ZR17 Track: Enkei RPM2 17x9-40, Yokohama A-032R Hcomp 275/40R17 My reliable daily driver since Feb 1997! ![]() |
#23 (permalink) |
Unless there is something like the official post your times up from the NG you won't see anything like that.
From that thread whatever he has they are clipped though, and he has oversized valves with some port work to get that 410 AWHP running 20 psi. |
#25 (permalink) | |
Yank in Yorkshire
#26 (permalink) | |
Here for the tuna.
#27 (permalink) |
Yank in Yorkshire
My point is that such marginal differences in density up to 17 psi (~350 cfm per turbo) should not have a significant impact on performance. Also, consider where on these curves most of the time is spent while driving, or even racing; it's interesting to note that up to and including the flow my engine demands at peak horsepower (~300 cfm per turbo at ~6000 RPM), 13Gs are marginally more efficient than 15Gs!
![]() ![]() Last edited by bjmsam : 04-23-2008 at 01:53 PM. Reason: added note about efficiency up to peak power |
#28 (permalink) |
Here for the tuna.
Ah, yes! I have not ran the numbers through myself but that's very believable. As you increase the PR from 17psi, I would expect the 13g efficiency to fall off very quickly though, where the 15g / 13t is still well in stride.
I thought to mention, did you see the recent thread where 400awhp was achieved with 13T's - at only 14psi?! |
#29 (permalink) | ||
Yank in Yorkshire
#30 (permalink) |
Here for the tuna.
You and me both.
![]() Can you use your method of generating those compressor map comparisons to lay a 15G, 13T, and 13G map down on the same chart? Here is a 13T compressor map: http://i36.photobucket.com/albums/e1...13TCompMap.jpg |
