#131 (permalink) | |||||
Yank in Yorkshire
See page two for how prices in the USA compare to other countries.
Jim Matthews - Yorkshire, England, UKTeam3S, 3SI #30, GTOUK #155 http://www.the-matthews.com/stealth.html Jet Black '94 Dodge Stealth R/T Twin-Turbo AWD AWS 6-spd Active Suspension Damping, Ek2MFG dual-flex downpipe, Zorstec custom SS cat-back dual A'PEXi SAVC-R Mk-I, MHI TD04L-13Gs, K&N FIPK, IPS SS Y-pipe A'PEXi SAFC 5-knob, 450cc Black Tops, MirageCorp Logger, DSM SMICs Mobil 1 & Redline fluids, Hotwired Denso 1020 Pump, IPO/SX AFPR SCE 332x32/322x28 cryoed StopTechs, Wilwood proportioning valves Winter: stock alloys 17x8.5-46, Hankook Icebear W300 235/45VR17 Summer: Enkei RPM2 17x9-40, Yokohama AVS ES100 245/45ZR17 Track: Enkei RPM2 17x9-40, Yokohama A-032R Hcomp 275/40R17 My reliable daily driver since Feb 1997! ![]() |
#132 (permalink) | |
The interesting thing about sending your gtech around, is that if it is consistent , then it will be a good comparison between setups, even if not totally accurate.
-Ron
'91 Stealth TT purchased Aug 2004 ![]() |
#133 (permalink) |
Here for the tuna.
Reason I ask is because with the 13T's and boost at 15psi, with the 550cc injectors, I used a gtech and although I did pull a 1.702 60' time in the middle of the highway, it reported my 1/4 mile as 12.88 @ 108 ... this is right after I ran a 12.44 @ 111 at the same boost level (but with stock injectors) at a real track.
I am going to take it to the track with me next time I go, and see how close it is. |
#134 (permalink) | |
We were hoping to get BJMSAM's Gtech "calibrated" at NG, but Murphy's Law beat that plan to a pulp. ![]() |
