Old 04-28-2009, 04:18 PM   #21 (permalink)
Drives: 94 3000GT SL TT
94ATXVR2 is an unknown quantity at this point
Default Re: 11.95@117 Bone stock SOHC heads/cams/shortblock e85 16psi
Congrats that is awesome. I am getting slicks for my FWD TT in June and hope to hit an 11 sec pass as well. I am getting 26x10 et drags and with the 117-118 mph traps I get consistently, I hope I can get a good enough launch to get in the 11 sec club. Your 1/8 mile and 1/4 mile traps are dead on with mine as well. I trap 87-88 in the 1/8th and 117-118 in the 1/4 so I am praying I can break into the 11's finally. On street tires im still in the low 13's. Congrats again and I am jealous.
Weight = 2860lbs, 396 FWHP, 117.85 trap speed (hks intercooler kit, atx tranny, n/a ecu,front 9b and much more for sale!!)
8:1 TT Engine, 93 TT ECU, TEC-17g's, AWD/FWD 5spd Getrag, Spec Stage 3 Clutch, ebay FMIC kit, Precision 525cc Injectors, Apexi S-afc 2, MBC@ 16psi, 3" Stillen Downpipe, 3" Single Exhaust, HKS SSQV bov, AEM UEGO WIdeband, Hotwired supra fuel pump, IPS Y-Pipe, Dejon tool intake pipes
94ATXVR2 is offline   Reply With Quote
Old 04-28-2009, 08:41 PM   #22 (permalink)
SOHC you in the FACE
Ondontii's Avatar
Drives: Mrs. Officer
Ondontii Level 1Ondontii Level 1
LOL, so today I decided I am building an oil catch pan (required for 11.5 at my track anyways) instead of fixing the oil leaks.
It makes me giggle.
Brent - Great Depression Racing
1992 Duster 11.54@125 22psi BONE Stock 6g72 12 valve - 12.7@114 14psi boost -516whp 519ft/lb 20psi (Old 3.13L built shortblock) - Precision 6765, Tial 38mm open dump, 3" open downpipe, 20x12x3" evo style intercooler, Stock 10:1 diamante 12 valve shortblock with regapped rings. heavily ported heads (+40% on flowbench), Ferrea Competition Plus +2 +1 stainless valves, Nielson Vintage Racing 278 custom turbo cams, RPW cam gears, Custom Ram Style short runner intake manifold, 12 Gal Jaz Fuel Cell, Dual external Walbro GSL392 255HPs, Dual 5/16" feed lines, Trick Flow AFPR, 3 puck solid hub & 3300# DD plate, OBX Torsional Diff, Zeitronix wideband/EGT/Boost, 2100cc 3 nozzle DevilsOwn Meth. Running on 4.0 BAR Megasquirt II, 47# Inj, E70 Fuel
1994 Spirit - 13.987@101.89 - 5psi- 6g72 SOHC, K27 Turbo
http://videos.streetfire.net/video/9...-on_649313.htm
Ondontii is offline   Reply With Quote
Old 04-29-2009, 03:21 AM   #23 (permalink)
Ondontii's Avatar
Using scrap sheet metal etc I built the pan and hangers all tonight. Very happy as now I dont have to worry about getting booted for oil leaks. I probably should fix the cam seal but I hate pulling cam gears.
Less then 4" ground clearance though. Fuh.
Old 04-29-2009, 11:54 PM   #24 (permalink)
Ondontii's Avatar
My oil pan. It needs to be 2" deep to be "7 second legal" but there is no way I was going to get clearance so its slightly more then 1" deep and its not quite level with the ground. Thats fine with me cause it now sorta acts like a belly pan. I had to cut out the corner to allow my wastegate to dump properly to the ground.
Since my e85 motor is a stocker and I dont know how much it can handle, I figured building the pan was better then chasing oil leaks in a motor that might be dead tomorrow.
Cost = free, which is why there is a seam in the middle cause the scrap sheet metal was not wide enough. I came up with the idea around 4 yesterday and after failing to find a good piece of sheet metal (places closed) I went with what I had and finished this around 1 AM. About 5 hours of total work. Looks crappy but I am pretty excited to run my motor now without getting booted from the track, and I know the track manager will be happy about it cause they made a rule that all cars 11.49 or faster must have them. Not quite fast enough to be required but I am actually happy that I have it now even though I complained last year with the new policy. The NHRA rules for a 7 second pan are pretty ridiculous, because they flat out would not work on our cars...we would have tires hitting a "legal" pan. I was originally going to try to tuck it into the engine bay and then i decided to let it hang below so it could catch drips from the edge of the K frame too (just barely reaches pas that inside edge).
Airdam not installed. That hangs MUCH lower then the pan and the pan is tilted towards the bottom so it should act a bit like a belly pan.
Old 04-30-2009, 09:45 PM   #25 (permalink)
Gas Cyphoner
SUPERTOM's Avatar
Drives: SOHC Stealth, c5
SUPERTOM is an unknown quantity at this point
git er dun
PERFORMANCE:RiPP Headers,Maximal Catback,MSD(6AL Box,Blaster Coil,Wires),3SX Pulley,DOHC TBw/plenum port & coolant bypass,K&N filter w/HomeDepot pipe, Supermac coldair box, Topline GroundWires, Ek2 Plenum Spacer
WEIGHT LOSS:Removed (AC,SRS,crash bars,rearseat,tar, GasTank Shield,extra wires).MOMO street racer gt seats,Hawker 12lb.battery. Hollowed trunk/trunklid,replaced random unseen bolts w/zipties, solid motormounts,CF Evo hood, Took a big dump -->
SUSPENSION:Ground Control, New KYB's, Front/Rear Strut bars, Dohc rear Anti-sway bar, Irotors brake upgrade kit
SUPERTOM is offline   Reply With Quote
Old 05-03-2009, 10:15 PM   #26 (permalink)
1994 stealth sohc 5spd
93stealthsohc's Avatar
Drives: 1994 dodge stealth
Trader Rating: (-1)
93stealthsohc is an unknown quantity at this point
what are all the modifications you have exactly?
93stealthsohc is offline   Reply With Quote
Old 05-04-2009, 12:50 AM   #27 (permalink)
Ondontii's Avatar
Well my built list is pretty much my sig.
BTW, anyone trying e85, I suggest you replace your fuel lines. I never owned this car until 4 years ago but someone definitly got the stock lines gunked up.
2 weeks after running 11's my injectors are all gunked up, stuck, etc. car barely made it home from 2nd place hot rod at cinco de mayo car show here in SLC.
Not sure of a good place to fix the injectors yet. I got a link from someone to witchhunter in Bothel washington (like 5 minutes from my parents) but thats not close to me and 110 bucks plus shipping. Anyone think I can find a lower price? I will call around for local places.
Fixing the stupid injectors will cost way more then the stupid engine I ran 11's with
Old 05-04-2009, 01:15 AM   #28 (permalink)
Drunk as a lord
Forest Gump's Avatar
Drives: 1992 Stealth TT
Trader Rating: (59)
Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2
a little cheaper and these guys do really good work:
Fuel Injector Cleaning and Testing
Power:13Ts, 550s, AEM FPR, Emanage Blue, K&N, Downpipe, ATR Catback, DevilsOwn meth, UDP, SSQV, EVC5, Walbro, IK24s
Best 1/4 12.62 @ 111.9 2.0 60 FT Best 1/8th 8.00 @ 87.24 1.80 60FT
Suspension: Konig Villians, Pilot A/S, Tein S-Techs, Hawk HPS Pads, 2G brakes AWS Delete
Drivetrain: ACT HDMM, 300m O/S, PST 2 piece Al/Steel Driveshaft, F&R Poly Mounts, EK2 ExoCage
Etc: Leatherseats.com Charcoal/Grey Interior, 99 front end/lights/wing/sideskirts/doorcaps, Scanmaster3, AEM UEGO, 3sx single pass 2" radiator
Samco rad hoses, Smokin'vr4 sub box with 10" MTX sub, Pioneer Amp, JVC KD-ADV49
Ball bearing STS
Forest Gump is online now   Reply With Quote
Old 05-04-2009, 01:18 AM   #29 (permalink)
Forum user
donniekak's Avatar
Drives: 92rt/tt
donniekak Level 1donniekak Level 1
If you find a good place to get the injectors fixed pm me. My galant has the same problem. My injectors are leaking and when i turned the car off i got about 1oz of fuel in each cylinder overnight. Now i have to rip it apart and hone the block for new rings. It sat with e-85 in it for a month during my holset build. I looked an black goo is clogging my injectors. Maybe i'll just see it as a forced upgrade to 1600's an ss lines.
donniekak is offline   Reply With Quote
Old 05-04-2009, 01:56 AM   #30 (permalink)
Ondontii's Avatar
starting a car with leaky injectors suuuuucks.
The trick ive been trying is unplugging the injector harness and then clipping it back in while someone is busy clearing the plugs by already trying to start it. Even that is super sketchy. Glad I got home without a tow. Started misfiring 15 blocks from my house
I had to get a jump at the show cause I killed the tiny battery.
