Old 04-19-2009, 07:26 AM   #1 (permalink)
SOHC you in the FACE
Ondontii's Avatar
Drives: Mrs. Officer
Ondontii Level 1Ondontii Level 1
Default 11.95@117 Bone stock SOHC heads/cams/shortblock e85 16psi
My version of the video. Includes the smokey first startup.
$90 Junkyard Runs 11's on first pass- Video
Ondonti's 11.95 pass- Video
So after I had some plugs come apart last year that 4 months later I found out damaged my combustion chambers (thinking about a partial fill on the heads too) and I had a junkyard 1997 caravan sohc sitting in my driveway. The 1996+ caravan 6g72's are 9.3:1 compression with the same cams.
I swapped my intake manifold, valve covers, oil pan, turbo setup to the junkyard motor. Got it running on gas and then converted to E85.
I cant run as much boost as I did on the dyno before so i figured with 2100cc's of meth, and e85 needing 30% more fuel flow, I would reduce my boost by about 20% (1/3 my hp comes from meth). This made me feel pretty dang safe on the e85.
I also drove the car a lot harder and this stock heads/cams/compression motor has a lot more power in the lower rpms so I dont bog on shifts. I still have a lot of work to do on driving. I nailed the 1-2 but my 3-4 was a no throttle grandma shift where I got nervous and sorta forgot what i was doing. Hurt my 1/8th and 1/4 traps but not so much the E.T. Its a lot of fun and I don't worry about an expensive motor! I still need the driver mod but I did knock off .8 seconds with basically just a better 1-2 shift (same 60')
This is all with methanol and a rising rate regulator. ECU has no idea what boost is. My megasquirt is currently getting fixed by someone who recently megasquirted their sohc 6g72 (and found a bad injector driver). Luckily he is a professional electronics guy and DIYautotune released the install guide for all SOHC 6g72's (I think the Montero guys are running it already).
So in the future I can get more fuel flow from not needing the rising rate regulator and I am thinking about an inline walbro which will definitly help even while still on the rising rate regulator (though not upgrading the tiny 5/16" lines yet).
I am trying to be very safe, stock 12 degrees of base timing on e85, just seeing how far the motor can go before the top rings butt and I pop a ringland. I dont know if the top ring gaps are larger on the 1996+ caravan motors. My friend who builds crazy 2jz's says he thinks the e85 will allow a lot more boost before the rings expand too much because of how much cooler it runs.
I finally surpassed the quickest (12.6) 3.0 documented and also eclipsed an undocumented car that ran low 12's on some weird Shelby built prototype motor and 20+ pounds of race gas fury.
I followed Ray's advice and took out my 8lb aluminum flywheel and am using an 18 lb stock chrysler flywheel. I also have the good chrysler harmonic balancer on. Trying to be more respectful of the cast crank.
Video
Timeslip
I think the SRT4 was pissssed. We got the same exact reaction time, I killed him on the 60', he gained a little from superior driving, and then I walked away when i finally figured out the 4th gear shift I bet he thought he was going to walk past at the 1/8th. Probably only gained cause I wasn't in gear for a bit. Darned good drag race! My best ever.
He is stage 3 + toys but the 4400' elevation here is nasty on the stage 3 turbo.
Brent
1992 Duster 11.54@125 22psi BONE Stock 6g72 12 valve - 12.7@114 14psi boost -516whp 519ft/lb 20psi (Old 3.13L built shortblock) - Precision 6765, Tial 38mm open dump, 3" open downpipe, 20x12x3" evo style intercooler, Stock 10:1 diamante 12 valve shortblock with regapped rings. heavily ported heads (+40% on flowbench), Ferrea Competition Plus +2 +1 stainless valves, Nielson Vintage Racing 278 custom turbo cams, RPW cam gears, Custom Ram Style short runner intake manifold, 12 Gal Jaz Fuel Cell, Dual external Walbro GSL392 255HPs, Dual 5/16" feed lines, Trick Flow AFPR, 3 puck solid hub & 3300# DD plate, OBX Torsional Diff, Zeitronix wideband/EGT/Boost, 2100cc 3 nozzle DevilsOwn Meth. Running on 4.0 BAR Megasquirt II, 47# Inj, E70 Fuel
1994 Spirit - 13.987@101.89 - 5psi- 6g72 SOHC, K27 Turbo
http://videos.streetfire.net/video/9...-on_649313.htm
Ondontii is offline   Reply With Quote
Old 04-19-2009, 09:55 AM   #2 (permalink)
Supporting Vendor
Trader Rating: (8)
ray pampena Level 1ray pampena Level 1ray pampena Level 1
Default Re: 11.95@117 Bone stock SOHC heads/cams/shortblock e85 16psi
thats pretty damn cool man! gotta love a sleeper like that. the srt guy was thinking hes got that one for sure haha
631-566-5959 631-676-2448
RUN 9s, GO 200PLUS!, 1000PLUS HP! 35K
http://www.3si.org/forum/f10/1000-hp...et-car-483549/
getrag rebuilds and modifications
pampena motorsports race engines, strokers
custom CNC parts
dyno tuning, street tuning. ask me about traveling to tune
pampenamotorsports.com
years of fast cars and excellent feedback!
ASE master tech, ASE advanced level specialist, Diamond Pro Mitsu master tech
specializing in building FAST STREET cars
ray pampena is offline   Reply With Quote
Old 04-19-2009, 10:24 AM   #3 (permalink)
...feeling very depressed
inperfectdarkness's Avatar
Drives: m*f*ing time vampire
inperfectdarkness Level 2inperfectdarkness Level 2inperfectdarkness Level 2inperfectdarkness Level 2inperfectdarkness Level 2
now if only the sohc 3/s guys could do the same.
inperfectdarkness is online now   Reply With Quote
Old 04-19-2009, 10:58 AM   #4 (permalink)
Broke Ass
Rebel's Avatar
Drives: 92 VRFizzle
Rebel is an unknown quantity at this point
Haha that's cool. I had an 91 shadow...maybe I should have kept it lol.
1992 3000GT VR4 - 12.53@109.75 w/1.77 60ft 13PSI
Mods- Testpipe, Downpipe, Vac Reduction, Gutted Kitties, K&N, Greddy Profec B Spec 2, Egr Block Offs, 13G's, Intrax Lowering Springs, Single 3" Exhaust, Synapse Synchronic BOV, EK2 Mounts, Spec Stage 2 Clutch, IPS Flywheel, BigTyla Grounding Kit, CXRacing FMIC.
Rebel is offline   Reply With Quote
Old 04-19-2009, 11:06 AM   #5 (permalink)
J-Groove Level 3J-Groove Level 3J-Groove Level 3J-Groove Level 3J-Groove Level 3J-Groove Level 3J-Groove Level 3
Damn nice run!
Great work. You know everyone in the grandstands loved that run.
Old 04-19-2009, 11:28 AM   #6 (permalink)
1st NG08 / 2nd NG07 Drags
Drives: 93 VR-4
neverenoughhp is an unknown quantity at this point
congrats brent. great progress on the 60'. im moving away from my alum flywheel in favor of the stocker as well.
11.4 @ 125 w/DR500, DR Stage III heads, 50 Shot, Weight reductions, and no traction.
AutocrossPhotobucket
neverenoughhp is offline   Reply With Quote
Old 04-19-2009, 11:36 AM   #7 (permalink)
Supporting Vendor
Maximal's Avatar
Drives: '91 Stealth "ES"
Trader Rating: (202)
Maximal Level 1Maximal Level 1Maximal Level 1
Awesome! Good to see some impressive numbers from that thing...finally.
1991 Dodge Stealth ES - 12.65 @ 112.71 - Not Exactly Stock
Maximal Performance
Maximal Performance Facebook
Maximal is offline   Reply With Quote
Old 04-19-2009, 12:18 PM   #8 (permalink)
I'm a Troll
Drives: Cherry VR-4
Trader Rating: (16)
drmbldr is an unknown quantity at this point
That was a great race!!
drmbldr is offline   Reply With Quote
Old 04-19-2009, 12:36 PM   #9 (permalink)
DuTTch's Avatar
Drives: 2nd gens w/o hoops
Trader Rating: (89)
DuTTch Level 3DuTTch Level 3DuTTch Level 3DuTTch Level 3DuTTch Level 3DuTTch Level 3DuTTch Level 3DuTTch Level 3DuTTch Level 3
congrats thats good stuff
DuTTch is offline   Reply With Quote
Old 04-19-2009, 01:32 PM   #10 (permalink)
Vette Driver
Tom400CFI's Avatar
Drives: C6 Corvette
Tom400CFI is an unknown quantity at this point
NICE! That was a nice vid. I should have come last night, but I was snowmobiling for the last time of the year. ...and it was worth it.
Car definitely has more in it w/better driving tho (as you know).
Tom400CFI is offline   Reply With Quote
