Go Back   3000GT/Stealth International Message Center
View Single Post
Old 06-17-2008, 09:14 PM   #3 (permalink)
lDoomZdaYl
doing the impossible
lDoomZdaYl's Avatar
Drives: Her Crazy
Trader Rating: (7)
lDoomZdaYl is an unknown quantity at this point
Default Re: Will a motor from a non turbo work in a turbo car?
that depends on your definition of "work".
Yes, it will run if you swap the accessories and turbos/manifolds over.
The compression is 10:1 vs the 8:1 of the turbo motor and this will require a tuning and running less boost than the 8:1 motor can.
Well said.
lDoomZdaYl is offline   Reply With Quote
