Originally Posted by mikes2nd
rtv?? um huh? you rtv'ed caps?
What caps?
dont rtv your brakes
Just put the lube in like normal. I know the 3s brakes inside and out.
Put the green grease on the sliders and go. I put a fair amount on the back also to make sure its doesnt squeak...
Ya know how the slider bolt rubber boots snap onto the bolts/caliper for a seal? Well where the boots meet the caliper/bracket I rtv'd around the edges of it so that outside elements can't get in the slider bolt greased area. Is that bad? I would think thats a good thing, but should I remove it and why should I?
