04-22-2008, 11:32 AM
#5 (permalink)
Drives: 94 VR-4
Re: Clutch Dragging!?
Yea just what I was afraid of with regards to the clutch. The fluid is full and hasn't changed levels at all. Master cylinder is not leaking anywhere visibly. The issue with the starter is a first for me. It NEVER made this noise until about a week ago and then it stopped. Now it is back much much more prominent. Like I said the most baffling part is it appears to be affted somehow by the clutch. More investigation is needed I guess.
EDIT: Also wanted to mention that I am thinking maybe the flywheel is warped...? So when i disengage the clutch it is like throwing it out of whack and causing the teeth to catch on the starter wheel...? Would this make sense or be plausible?
Mod List: K&N cone, DNP Y-Pipe, TurboXS RFL BOV, Custom down pipe and full 3" exhaust, Apexi AVC-R Boost Controller @ 15PSI, Apexi SAFC-II, 450CC DSM Blacktop Injectors, MSD 8.5MM wires w/ NGK copper plugs, Spec Stage 2+ clutch, RPS Billet Flywheel, Custom stereo system, Seibon Carbon Fiber Hood, Enkei 18"x8.5" RZ-5 wheels w/ Falken Ziex 912, AEM WB 02, HHH Hybrid Logger w/ wideband integrated, VAC reduction, EGR delete w/ blockoffs, Mcculloch 10,000K HID low beams
