View Single Post
Old 03-13-2008, 12:36 PM   #17 (permalink)
Boostaddict
Super Member
Boostaddict's Avatar
Drives: First e16g 3/S
Trader Rating: (36)
Boostaddict is an unknown quantity at this point
Default Re: Intake temperature?
If you are measuring at the mass the thread should probably be called under-hood temps, not intake temps. To me intake temp implies the actual charge temp going into the engine, which most of us measure at some point close to the intake manifold (via ait sensor). Low underhood temps are good if you have an efficient intercooling setup... a crappy intercooling setup will still result in high intake air charge temps regardless of under-hood temp
Quaife Front LSD for AWD
Ksport Suspension Kits
Specializing in 3/S Suspension, Billet Transmission Shift Forks, 300M Output Shafts, Front AWD and FWD LSD, Transmission Rebuild Parts, STOPTECH Brake Kits, Big Reds, and Custom Brake Upgrades! More Products to Come.
1993 3000GT-VR4: AEM EMS, etc
663 awhp, 607 tq (retired tdo5-e16g's)
10.835@132.69 -26psi
Boostaddict is offline   Reply With Quote
