View Single Post
Old 02-16-2008, 03:41 PM   #134 (permalink)
josevr4
Killer Whale
josevr4's Avatar
Drives: like my mother
josevr4 is an unknown quantity at this point
Default Re: MAFT Gen 2 - Anyone?
Heres my setup. I teed off the front and rear crank case to the vacuum source under the intake mani. i got all my settings in user tune starting at+9 and then changing all the way up to -8% on all my Loads. Mainscale i have set to 0. I now spool my weebit 9bs at 2400ish rpm. Photo-0003[1].JPG And heres my setup
[/SIGPIC]
Dejon dual intakes and Ypipe, Synapse B.O.V., Gen2 Maft w/3.5" sensor(blowthru), RandomTech Cat,3SXdownpipe,Ips singletip exhaust, Maximal solid motormounts,13T's,Gtpro headers(powdercoated) w/precat elims,Supra Fuelpump,550cc's,AEM Fpr,IPS hotwire kit,AEM AFR guage,Newvolt ignition amp,IK27 plugs, Southbend DXD-FE clutch,Fidanza flywheel,SSclutch line,300M output shaft.
289awhp and 298awtq on stock boost @11.3AFRlimited by bad VSS's
on stock sidemounts
Next ported heads and bigger intercoolers
josevr4 is offline   Reply With Quote
