View Single Post
Old 02-11-2008, 04:44 AM   #401 (permalink)
3startuna
Damn It!
3startuna's Avatar
Drives: Without Traction
Trader Rating: (14)
3startuna Level 33startuna Level 33startuna Level 33startuna Level 3
Default Re: N/A UPGRADE BIBLE.
yeah yogurt TT is definately the best way to go. but if you are set on an NA build might as well grab the 12:1s with good management
96 3000GT FWD TT -Rebuilt 2 bolt 8:1 block, balanced stock internals, valve job, 99 Lifters, Maximal Performance Motor mounts and valve cover!! Quaife LSD, ACT Max Extreme 6 puck, RPS flywheel, Greddy emanage Ultimate, custom fuel system i designed my self, profec B spec2, walbro 255lph, stock turbos, Nitrous, KNN FPIK, FMIC, FM oil cooler, cusco Oil catch can, stillen DP, IPS 3" single, Full AC delete, stripped interior, Corbeau Forza 2 seat, 2 inch harness, ALL Greddy electronic gauges, brakes: 4 piston calipers from Yogurts TT, Hawk pads, Valvoline DOT 4, Russells steel lines
Coming soon: Tranny number 3
Special thanks: IPS, Maximal Performance, 3SX, Evans Performance and all 3si and FL3s members that sold me parts
3startuna is offline   Reply With Quote
